3
Everything posted by ford'ssubaru's
Leaking coolant from intake gasket?
ford'ssubaru's replied to LucasP's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Absolutely right. Turn a little back tighten. Turn a little tighten. Reinstall with Copper coat or Never Seize.^^^^^^^ -
Oil Stop Leak EA81 Yay or nay?
ford'ssubaru's replied to Zosojojo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Stop leak a very bad idear listen to the above. -
retiring the 91 loyale. fwd gave out
ford'ssubaru's replied to Stenwood's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Listen to the above. Thought the same thing in my early years. -
ej22 swap no spark on cylinders 1 and 2
ford'ssubaru's replied to Tye's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Judging by the schematic and the legend. W is constant battery voltage. Y is your ignition battery voltage or excite wire. BW sais other current....... Try leaving that disconnected. -
Rear Axle for 4WD Wagon
ford'ssubaru's replied to RonVee's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I cracked up when you said out of warranty.....LOL. Where are you checking? I have gotten them for older roo's at NAPA and Federated? -
I like E6000. Gorilla glue make a bubbled up big mess.....
Coolant goes through the intake.... Replace with OEM Subaru gaskets and it will be fine. -
1990 Loyale Tranny Conversion
ford'ssubaru's replied to ford'ssubaru's's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That was what I was thinking too..... Thanks Tye.- 2 replies
- 4wd switch
- Tranny coversion
(and 1 more)
Tagged with:
Just got a '91 Loyale.
ford'ssubaru's replied to '91Loyale's topic in Meet n' Greet. Your USMB Welcome Center
Yep, -
EA82 SPFI Loyale Won't Start
ford'ssubaru's replied to jread's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Be sure and disconnect clean and reconnect and ziptie those round engine harness connectors. I mean push the snot out of them. -
Fuel pumps on these are really convenient...
Hello All, So I successfully converted to a dual range transmission. So it drives awesome! Problem is that the 4wd light does not work? So I have 3 other single range transmissions on the ground. The switches look the same but won't work? Any idears? Thanks, Eric
- 2 replies
- 4wd switch
- Tranny coversion
(and 1 more)
Tagged with:
Isolate your alternator. Just connect your battery + charge wire. The T connector has two wires. The top part of the T is ignition hot or excite wire. Connect a hot wire directly to the top part of the T to battery. Check out put of alternator at alternator with battery connected to positive and not. Be careful. Also be sure that your grounds are good and making contact. Block to body, block to battery. Cheers, -
Is the alternator brand new or is it rebuilt from auto-zone or something. Take your alternator to your local Battery Systems. This sounds like an incorrectly assembled alt. Overvoltage is everbit as damaging as undervoltage. Get this checked thoroughly before you do to much more troubleshooting. Just Me Though. Cheers, -
1990 Subaru Loyale Speedometer cable!
Thanks All! -
Listen to the above. Start by double checking timing. Also the coil packs don't like to be fired without a solid ground when testing. Many a new coil pack has been roasted by improper grounding. How are you testing your spark? Screwdriver in wire is not a good idea. You should use a proper spark tester or solid alligator clips on base of plug to block. Cheers, -
Rust at center. Of roof fun top brat
ford'ssubaru's replied to kgrove56's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Uhmmm, In case you were not aware rust is everywhere in Michigan. Every car has a rust problem in Michigan.... Anyways depending on the severity and location it can be done by welding and bondo. It all really depends on your skill level and patience. Cheers, Eric -
A little heat from a propane torch does wonders........
Hello All, So I went through the 139 posts on Speedometer Cables on the site. Well I found a couple of really good ones. What a pain in the backside. I am not very agile these day and found it easier to remove the front seat. I removed the covers under the steering wheel and dropped the computer down. I could now feed the cable through and actually see the back of the cluster. It was kinda high up there but with my mobility issues I could see it go into the hole. I was pretty happy. Have Fun Ya'all!
Subaru Techinical Training Center
I am working in Denver for a couple of weeks...........Do you have a shop floor scrubber that needs repaired?.........LOL. -
1987 gl wagon 1.8 ?
ford'ssubaru's replied to Killjoy6970's topic in Old Gen.: 80's GL/DL/XT/Loyales...
My 87 is carbed. Runs awesome though. Cheers!
