11
Everything posted by mcbrat
good idea on some limiting straps... I ran a clocked torsion bar, on top of a 3" lift, and used these shocks. Also carried heavy loads at time, and some good wheeling. after 6,000 miles, one of my torsion bars twisted in half...
are you running Jerry's kit with the 5 speed to use the stock linkageand 4wd shifter? if not, you should be fine. I have a 5" lift (though less at the tranny crossmember, and I just have stock 5 speed D/R linkage, with zero problems. (82 Brat) the back part of the linkage with the rubber block I have bolted to the body still. I believe if the rubber part seperates, it makes it difficult/impossible to get into some of the gears... at least I read that on here, so I drilled a hole through both metal plates, and the rubber block, and have a nylocked bolt loosely tightened through them just to keep them together so I don't "lose" them on the trail.
the blue one....
1986 Brat. Bought in 1999. Had 75k miles on it.... just turned over 90k last month
make sure your disty adjustment is tight. I had one "slip" and had to floor it to start....
i am having problems finding rims
mcbrat replied to doubi2's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I think I'm gonna be selling these... Genuine Subaru 14" Chromed Alloys. Need $400 shipped though.... (wheels only, no tires) -
EA81 power steering and lift kit ????'s
mcbrat replied to ettev's topic in Old Gen.: 80's GL/DL/XT/Loyales...
^ what he said.... -
yes. for the sticking at high idle, others on the board have had the ASV system go bad, and have plastic sucked into the carb, making it do that.... make sure nothing is blocked in the throat of the carb....
the dead spot/feathering through, sounds similar to a problem I had with my first brat. I put a can of seafoam in the gas tank, and added some to the carb throat trying to clean it out.....
bump for some awesome midwest wheeling.....
since they are alloys, you'd need to drill the hubs and drums on the soob and do the 6 lug conversion....
or even the ones of the unfinished death hatch?
///pics\\ Roxys Roof Rack
mcbrat replied to mykingcrab's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Can you remember what all was lost.? other vinyl shops could get the same material, but I'd guess it be unlikely to see the exact same thing on another car in your area -
how many turns out is your idle mixture screw? (mine have never been in the "normal" range of turns.) how many turns on your idle speed screw after it contacts the throttle lever?
I think I like that better than my Yakima basket.... nice decals too -
Lug nuts on pugs keep coming loose.
mcbrat replied to civilpd's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the pug alloys take ball seat lug nuts, not the standard taper. -
yeah. OBW now lives in STL, and the 6 lug wheels got traded for a set of chrome 8 luggers.
good to see you got it home... you have just as many soobs as I do now and it does spread I've have 35 soobs in the last 10 years
Documented: The 1970 FF-1 Project car...
mcbrat replied to Kostamojen's topic in Historic Subaru Forum: 50's thru 70's
I voted for the white bottom, yellow top.there's just something I really like about that combo.... -
Is there a demand for bolt pattern adaptors?
mcbrat replied to RenaissanceMan's topic in Old Gen.: 80's GL/DL/XT/Loyales...
awesome!!! -
nice pics. glad to see you kept the round headlights
