25
Everything posted by nipper
12 is low, even at altitude. The idlers and tensioner NOt being replaced is a mistake on somebodys part, as even subaru recomends replacing them When you dont in 5-20000 miles they let you know they should have been replaced. http://www.classictruckshop.com/clubs/earlyburbs/projects/vac/uum.htm My next step would be a compression etst, but i wonder if you have a tensioner or idler going bad and allowed to TB to jump. nipper
Bench testing is such BS. Have them test it on the car, thats really the only way to test it. They need to use an analog (looks like a big metal cheese greter with jumper cables) tester. You have a bad Alt and may have to buy another one that is built from a reputable shop. I dont know what the online suppliers get for a reubuild for your year (www.1stsubaru.com) etc. If you are not getting full output above 1800 rpm (14 voltish) and everything on, the alt is fried. nipper
First justy, new here
nipper replied to 96subie96's topic in Meet n' Greet. Your USMB Welcome Center
Google Dustys Justies too. His prices are HIGH on some things, but he has lots of useful information. One thing i have been educated about, if you change the oil often, dont push them too hard, they will run a long time. nipper -
BROTHER! I just got an 89 2wd CVT. http://subarujusty.proboards20.com/ good source. They have some weaknesses, like the oil pump and the water pump. install a oil pressure gauge and replace the oil pump innards with every timing belt change. Ebay is a good source for parts. There seems to be two generations of them, well 2 1/2. 89 is one dividing line and 90 i think is fule injection. nipper -
Did the donor engine run? Hard start and smoking, this should be a no brainer. Stop just replacing parts and think about it. It is hard to start, cranks for a while, and smokes once it starts. Runs fine when warmed up. How about a bed negine temp sensor. It is flooding on startup, hence the hard start and the smoke. nipper
Ok back up. They replaced 1 tire? Tires should be replaced in sets of 4, two, one per axle if in a pinch (unless wear is within 1/4 inch circfrance on the tires). NO NO NO Or did the replace 1 wheel? There are no Universals that fit this car because they arent servicable. Also it is rare that three of the four go bad. Get a second opinion. Also a bad uni vibration does not appear this way. It starts at high speed then slowly drifts down. I dont like anything you have been told. nipper
I dont get something. The roads are icey, the car is having traction issues for whatever reason. Yet someone is complaining that other drivers are passing him? Thats not the point of safe winter driving. The point of it is to drive at a speed you feel safe in the car, not the speed you want to drive at. i have people pass me all the time on the parkways around here, and 70% of the time a few miles up the road the wrong end of the car is pointed to the sun. nipper
Cams hydraulic Chain-drive 4x4, about 7 feet of up OR down motion on each tire: specs below Engine is a fuel injected Ford 5.0 V8 out of a '93 cobra mustang, c4 transmission and t-case out of an early bronco. 9" w/ 5.38 gears and ARB air locker mounted in the center (below driver) running chain gears on the ends where the swing arms pivot. Swing arms are hydraulically controlled individually or together, and there is coil spring and shock suspension as well. large chains running inside the swing arms turn hummer gear reduction (2:1) hubs at each wheel. tires are 39.5". The steering is linked through the swing arms as well and the steering box is mounted just infront of the axle below the driver. body construction is steel tubing (mostly DOM) and the total weight is 5900 LB.
