Everything posted by nipper
Getting those transmission blues...
nipper replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFlush with a machine is fine, drain and fills are fine, chemical flushes are bad. Have yet to see a modern subaru tranny fail from a flush that wasnt going to fail to begin with. You may want to find a (God help me for saying this) a good tranny shop or better yet a dealer. Dealers dont like selling transmissions. Leave the car overnight and have them throw a set of pressure gauges on the car. They should be able to see this happenening on the gauges. nipper
Timing Belt Covers for off road
I would say use them if your running where anything can pack in the belt, like snow, or thick mud. nipper
Not blowing heat
nipper replied to rburrill22's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRut roh. Is the new t-stat from subaru? Also replace the cap. This car is old enough to have a clogged radiator. Are you consuming any coolant or pushing any out? nipper
nipper replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen in doubt, flush the tranny. This should be done every 3/36K miles. It can make the world of differnce. You can also clear the learning memory to see if that helps.
Water pump or clogged radiator?
nipper replied to hustle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell if you are due for a new timing belt go ahead. But a failed water pump or a clogged radiator would cause an over heat condition, not to seem to act too cool. You should check the egnine temp sensor to see if it is reading properly. The ECU may be getting wrong data.
nipper replied to hustle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXoops sorry I forgot this is an obdI. What is the outdoor temp? nipper
nipper replied to hustle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs your CEL on? Can you see fluid flowing with the cap off? Do you have a code reader so we can see what temp the ECU is seeing? How do you know the t-stat is ok? Just for the heck of it replace the radiator cap. nipper
nipper replied to hustle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou do realize that hot water goes into the bottom of the radiator and cooler water comes out the top? And that cooler can seem downright cold depending upon the air temp going through that radiator. I'm with GD on this one, what is the problem? If it is cold enough outside, Blu's T-stat wont open up (but engine temp gauge is normal), but i will have plenty of heat. The heatercore is just a small radiator. nipper
no heat
nipper replied to derby's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXClogged radiator?
alternator compatibility?--anyone rebuild one b4?
nipper replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe reasons why Alts go bad the first time are usually the voltage regulator or rectifier. I would replace the brushes too if you are so inclined to rebuilding it. They arent hard to rebuild. nipper
Tire Size dicontinued? What to use instead?
Can you drive down to the states and buy a set? nipper
nipper replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou asked about an interchange, not a rebuild. I have rebuilt them. I have stopped since sometimes costs more to rebuild them then what one can or is willing to buy one for. Why not call a subaru parts supplier and ask them? But since the voltage regulator is differnt I would say they may not be good matches. This is for a 2000 Legacy: Voltage regulator, legacy, 2.5l 00-04 $179.35 $129.13 Bearings, front, legacy 95-00 $20.68 $14.89 Rectifier, legacy 00-03 $115.51 $83.17 Bearings, rear, legacy 95-04 $38.92 $28.02 Brushes, legacy 00-04 $13.22 $9.5
Powersteering antifreeze?
nipper replied to Uberoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhere did the waterpump come from? nipper
Subaru made Wards top ten engine list
http://www.autoblog.com/gallery/wards-10-best-engines-of-2010/#9 :banana:
Wont start after refuel
nipper replied to peter 1982's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust for gigles, check the charcoal canister and see if it feels heavy. It may have sucked up gas and that can cause problems. Just a longshot but a cheap and easy thing to check. nipper
I Hate My Legacy!!
nipper replied to Bucky92's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI didnt even know you had a legacy! nipper
nipper replied to peter 1982's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLets attack the stalling issue first. My 97 will do this starting issue on ocassion. I am 98% sure with Blu its a dying crank position sensor. There arent many things that will make a no start condition on a subaru (crank sensor engine coolant sensor). The stalling I would think may be a coolant temp sensor. These will not always throw codes. Since these are intermittent issues, throwing parts at these would not be a bad thing (as they arent terribily expensive used). nipper
nipper replied to Uberoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow old is the waterpump? If the coolant was truly frozen (at the number your speaking of it would just be slush) then you may have bigger problems. I am thinking that your waterpump is just old and tired and the bearing may have seized. nipper
nipper replied to Uberoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow about just a tired PS belt? If the fluid was "frozen" it would not thaw out for quite some time. This sounds more like a bad belt. nipper
aftermarket T-stat....?
nipper replied to Loyale93v's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAftermarket is junk. Use OE nipper
Splash sheilds?
nipper replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere is no rhyme or reason to who has them and who doesnt. Personally i think some of them get "lost" at the dealerships. Alot of them get lost in deep snow or wheelin. nipper
98 Legacy Outback (EJ25) #2 and #4 spark plugs... how the hell
nipper replied to Kwhistle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWe dont like you anymore Unless your talking about a 360 then just go away hehehehe
nipper replied to Kwhistle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust have no children, mother in laws, or ministers within earshot when you do it. There are some very good how to's on here, just search for them. nipper
- ned to know
Brake Issues (Pins, rotors, pads)
nipper replied to MischivousSlpwlkr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat exactly do you mean by you can't get the caliper off. The pins are cheap enough to replace if they are really bad. nipper
