Everything posted by nipper
P0400, P0115, P0420 codes
nipper replied to Roamer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere are two sensors, one front one rear. Most likely its the front one (which should be OE and not aftermarket). The 400 i get too, just am waiting till spring to trouble shoot it. Or to go to a junkyard and just replace the one of two parts it may be. nipper
3 cylinders
nipper replied to destey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat he said. i just took an educated guess
3 cylinders
nipper replied to destey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou need air, compression, fuel and spark to make it go bang. Odds are it has no compression. Since subarus dont loose compression to rings often, I am going to say its a burned valve. nipper
97 Outback - seized cam, looking for opinions
nipper replied to mtskibum16's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXits well known. 1996: First year for the 'real' Outback. Also first year for the 2.5L engine, which in '96 runs on premium fuel and is only available with an automatic transmssion. The manual uses the 2.2L engine and has the hill holder clutch. http://www.cars101.com/outback_archive95-97.html
nipper replied to mtskibum16's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA 96 2.5 engine requires premium fuel. Keep that in mind. nipper
mysteries thumping sound?
nipper replied to sleepylegacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSquirrel?
Anyone have any ideas? fuel related or head gasket?
nipper replied to bmxbandit's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you actually want to save this car or keep driving it into the ground? Personally I wouldnt do a HG on a car with 200,000 miles on it and not well maintained (sorry a CEL on for 6 years is not well maintained). The restored selaing of the valves could cause oil blowby (burning). I would look for another engine if this is true. It is going to cost in the 1500.00 range to fix the car if it is done properly. nipper
nipper replied to bmxbandit's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo tell me, if you have a hang nail do you fix it with a heart transplant? At 200,000 miles there can be any number of things wrong with the car. I agree with everything the poster above said. Alos ANY CAR at 200,000 miles can blow a HG, so dont just go blaming it on the poor sooby! Now back to the question at hand. Have you filled the tank since then to see if it happens again? When was the last time the car had a tune up? Any mechanic that just "thinks" it is a HG should be ran away from. You have to do a compression test and an exhaust gas test in the coolant. When was the last time the timing belt was changed? When was the last time the coolant was changed? Any CEL light? You MIGHT have a bad HG, but the symptons dont match it.
nipper replied to Roamer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXClear the codes and let us know what comes back. Car is due for an O2 sensor so 420 is a real possability. 400 is an egr circuit code 115 is an engine temp sensor code. nipper
abs light
nipper replied to logic23's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmmmmmmmmmmm brains.
nipper replied to sleepylegacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYear and miles please? nipper
My new 2010 Outback - 2" hitch
nipper replied to MtnBikerChk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX?? I installed a hidden hitch on my 97, it was very easy. I just dont understand what you mean by 2" aside from the reciever. The Hitches on the link say they are 2"
CEL with Speedo problem
nipper replied to urabus1995's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI dont read profiles since mileage changes over time. Is this car OBDII compliant?
nipper replied to MtnBikerChk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI love hidden hitch. Are you talking about a 2" ball?
nipper replied to urabus1995's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCant tell you a thing without knowing year, model, mileage, engine, and transmission. nipper
blower makes whirring noise. 05 outback
nipper replied to gritle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUsed to be fropm behind the glove box, most likely still there. nipper
nipper replied to gritle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMaybe it digested a leaf. Usually this is as simple as some dirt in the HVAC box. It should be easy enough to drop the blower motor, but DO wear a dust mask. There can ba a lot of icky things in there. nipper
Is it possible to replace the timing belt without pulling the engine?
nipper replied to Kwhistle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIve never heard of anyone pulling an engine for a subaru timing belt. nipper
Did a little maintenance on the brakes
nipper replied to subaruplatt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOne thing that has always bugged me (I'm not picking on anyone, just an observation). Not everyone has compressed air available to them. Not everyone has multiple cars to take things someplace where compressed air is available. Not everyone has someplace to store a air compressor. nipper
car died on hiway won't restart
nipper replied to Tahoe Subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour going to have to replace the belt. When the belt is off any damage/wear to the idlers will become more obvious. It rare for a failure this early, but this is a used car and you dont know its maint history. Lest hope that isnt so far out that the valves are bent.
nipper replied to subaruplatt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSticking calipers. At ever brake job the pins need to be cleaned and lubricated, if not this is what happens. nipper
nipper replied to subaruplatt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can replace pads per axle in pairs. Your pads were wearing odd because your calipers are seizing. You need to remove the pads, get the calipers off the sliding pins, then clean and lubricate them. Rotors can last the life of the car or 2000 miles depending upon driving habits, the alignment of the planets, and your good luck. nipper
98 Outback EJ25 Big Trouble
nipper replied to doogymon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.lovehorsepower.com/SubaruDocs/TimingWaterPump.htm Thats for a 1995 but notice the main pulley how differnt they are. your main pulley failed. nipper
nipper replied to doogymon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXStep one remove pulley and replace it. Step two rwplace covers and inspect timing belt and cross fingers. If the pulley is tight, thats a GREAT thing. if it is loose thats bad. nipper
nipper replied to doogymon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm going to be the optimist on this one. I think the main pulley seperated and for some reason walked backwards into the timing belt cover. But this raises another issue, what condition is the timing belt in? nipper
