Everything posted by nipper
Release lever grease. What's your favorite flavor?
nipper replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPepermint.
97 Legacy Code 0420 Cat Conveter
nipper replied to eppoh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGary with his attitude, i would just let hime spend the 850.00 ffor that cats and find out that wont fix his problem. i also wouldnt tell him to use a search to find the 100's of discussions on cats and O2 sensors. I also wouldnt tell him that the 420 code 99% of the time refers to a tired Front O2 sensor which needs to be OE. I also wouldnt tell him that there is a second O2 sensor behind the cat that can be replaced with a generic aftermarket sensor. Nosirreebob i wouldnt tell him a blasted thing. nipper
Uh oh..dash warning lights!
nipper replied to Megell's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGot to love a man with style :lol:
nipper replied to Megell's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would test it at the battery, but your way isnt horrible, your voltage regulator is out of wack. Them not having a mechanic nor having the tester (which is a basic tool for an alt shop as it only takes 1 minute to run a test) is inexcusable. At that high a voltage you are damaging the battery. I dont like this shop. nipper
99 Legacy OBW 2.5 rough idle
nipper replied to Zuber's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDont drive the car untill this is figured out, i would even be hesitant to start it. remove the TB covers and see whats going on.
nipper replied to Zuber's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX12 is low, even at altitude. The idlers and tensioner NOt being replaced is a mistake on somebodys part, as even subaru recomends replacing them When you dont in 5-20000 miles they let you know they should have been replaced. http://www.classictruckshop.com/clubs/earlyburbs/projects/vac/uum.htm My next step would be a compression etst, but i wonder if you have a tensioner or idler going bad and allowed to TB to jump. nipper
nipper replied to Zuber's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI am interested in the idlers and tensioner, were they replaced?
Head gaskets or not?
nipper replied to RussellW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThats a head gasket. They like to tease you alot. When you do it also do an oil change. nipper
nipper replied to Zuber's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGet yourself a cheap vacume gauge and let us know exactly what it is reading. Also any odd noises from the front of the engine? When the timing belt was replaced, what else was replaced? Any new axles of late?
FIXED!! Trany delayed forward engagement
nipper replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHrmph. nipper
nipper replied to Megell's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBench testing is such BS. Have them test it on the car, thats really the only way to test it. They need to use an analog (looks like a big metal cheese greter with jumper cables) tester. You have a bad Alt and may have to buy another one that is built from a reputable shop. I dont know what the online suppliers get for a reubuild for your year (www.1stsubaru.com) etc. If you are not getting full output above 1800 rpm (14 voltish) and everything on, the alt is fried. nipper
nipper replied to Zuber's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSwap wires around and see if it moves. What kind of plugs are in the car? how is the gas mileage? Check the coil connections. Is there any oil on the spark plug boots? and welcome to the board.
U Joints what years will fit
nipper replied to imprezaII's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell thats what we get for driving them untill the doors fall off nipper
First justy, new here
Google Dustys Justies too. His prices are HIGH on some things, but he has lots of useful information. One thing i have been educated about, if you change the oil often, dont push them too hard, they will run a long time. nipper
BROTHER! I just got an 89 2wd CVT. http://subarujusty.proboards20.com/ good source. They have some weaknesses, like the oil pump and the water pump. install a oil pressure gauge and replace the oil pump innards with every timing belt change. Ebay is a good source for parts. There seems to be two generations of them, well 2 1/2. 89 is one dividing line and 90 i think is fule injection. nipper
92 Legacy Relay Clicking Stalls Engine
nipper replied to gandalfthew1te's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere is no such thing as a "brand new" altenator. Unless the rebuild came from a local shop or subaru, it is most likely not fully rebuilt either. Check the Alt never assume. nipper
nipper replied to imprezaII's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFor anyone else how may need a driveshaft and does a search, people seem to like these guys http://www.wholesaleimportparts.com/driveshafts.php nipper
nipper replied to imprezaII's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo. Just get a used one. After all this is done then it still has to be balanced. Too much work, too much cost and not something one should do in the garage. nipper
nipper replied to imprezaII's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe are welded/stacked to the driveshaft. There are no snap rings to get the caps out. You must replace the entire Universal, inclding the knuckles. Technically anything is servicable and a good driveshaft shop can rebuild them, but it will cost $$$ to do it. Just better off geting a used one.
nipper replied to gandalfthew1te's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat may be the main relay, not sure. Is it the same one that clicks when you turn the car on? Check your battery cables and Alt output. nipper
nipper replied to imprezaII's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCanadian eh? Find a good used one. As that rebuild price was from a place in texas. A used one will last for quite sometime at 1/3-1/5 the cost. nipper
Excessive cooling system pressure - causes ?
nipper replied to cagranitz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNew Cap nipper
96 Outback swap from hell
nipper replied to 3Pin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid the donor engine run? Hard start and smoking, this should be a no brainer. Stop just replacing parts and think about it. It is hard to start, cranks for a while, and smokes once it starts. Runs fine when warmed up. How about a bed negine temp sensor. It is flooding on startup, hence the hard start and the smoke. nipper
nipper replied to imprezaII's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPS if it is the shaft a used one will work well, or you can get a rebuilt one for about 350.00. nipper
nipper replied to imprezaII's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk back up. They replaced 1 tire? Tires should be replaced in sets of 4, two, one per axle if in a pinch (unless wear is within 1/4 inch circfrance on the tires). NO NO NO Or did the replace 1 wheel? There are no Universals that fit this car because they arent servicable. Also it is rare that three of the four go bad. Get a second opinion. Also a bad uni vibration does not appear this way. It starts at high speed then slowly drifts down. I dont like anything you have been told. nipper
