nipper
Everything posted by nipper
  1. Go to an autoparts store that reads codes for free and see if it works for them. nipper
  2. Headgaskets should be OE, everything else should be a name brand. Felpro has lets say 20 engineers to cover every gasket they make for every car ( I worked for a major auto parts mfg and we only had 5 for our entire product line). Subaru being OE will either asign an engineer or a group of engineers to evaluate a high cost part to see why it is failing. Aftermarket will not, since they usually see engines at the end of thier lives. OE will constantly evaluate untill they solve the problem. Aftermarket will sit on the stock. Once a problem is solved, OE will put out a notice that all A Hg's are now superceeded by Revision H HG. They will tell all dealers to remove the old design and return them or destroy them. An aftermarket supplier will rarely if ever do that, and whoever has them on thier shelves will run down the inventory untill they have to order H. that may mean going through A B C D etc. Thats why you buy OE. Also the deeper in the engine and the nore critical the part, thje more risky and foolish it is to rely on a cheap part. nipper
  3. Buy it on line. Use a good wrench or socket. use penetraiting fluid. You may get lucky and it may come right out. nipper
  4. Remove the drive belt and start the car. If it goes away BINGO nipper
  5. Do a search on Head Gaskets it will be explained. Just ive explained it a few too many times this week, and am tired of retyping I ned to make a memo with that and keep it on my puter. This is only for specific gaskets.
  6. Yes. Have a machine shop check them for flatness. They will take a minimal slice to clean them up (surface finish is importnat to sealing, just cant scrape them anymore). If there is any runout the shop will take care of that too. nipper
  7. Headgaskets from Subaru otherwise don't do the job. Spark plug bucket seals should be from subaru. May as well change plugs while your at it, and a new pcv valve. the very first thing you do after you remove the radiator is to flush it out. Oil + old antifreeze + air = glue. Plug wires? The timing belt kit looks good, I wonder where he is sourcing the parts from. I dont trust ebay parts for criritcal stuff. nipper
  8. http://www.ultimatesubaru.org/forum/showthread.php?t=106709 FWD Auto (Remeber i still have a nerve damage .. I can always upgrade later). I gave up on finding a 4wd. It's not home yet, as it has a safe warm garage for winter. I did lots of research and surprsingly if you cut the maint intervals in half they will go over 100K (including the autos) if you understand the car.
  9. They MAY hit each other. Sometimes you get lucky. Bottom end will be fine, top end may need work. A snapped belt is actually better then a jumped belt. When the belt snaps everything stops. Just throw a belt on it and take a compression test as a starting point. Stranger things have happened. nipper
  10. One goes to thecrankcase one comes from the valve covers. Im guessing that he isnt stalling its from the valve covers. nipper
  11. Heheh 2.89 on this island But I also bought a Justy to work around that. nipper
  12. Time is miles. 1 month = 1000 miles per subaru. I would change it. It's not his wallet that takes the hit if it jumps. ALso inspect your tires for dryrot if they are original. Alos change all your fluids for the same reason. nipper
  13. If someone doesnt chime in, trace it back to its source and take a pic, then I can tell you. Otherwise wait till the sun comes up and I'll look on mine. nipper
  14. In your case I would skip the Waterpump idler and tensioner as they are most likely good as long as you do the next belt sooner then 126,000 miles. I would still replace the cam and main seals and reseal the oil pump. nipper
  15. An annoying CEL that wont go away and I can't reset, but on some days I can. My EGR works. I have had a slight drop in MPG but it is winter so im not to worried. nipper
  16. Anytime someone says "recirculatory" it means EGR valve. Exhaust Gas Recirculation valve. And it does have a solenoid that is pricey (i need one) but not that pricey. nipper
  17. At 200K your looking for a lower mileage engine. I wouldnt turbocharge an engine with 200K unless you are replacing the rings and bearings. Go with a 2.2 a turbo. It can handle being blown much better. Go with what Eric said. nipper
  18. Dollar wise penny foolish. The best way to solve this issue is replacing the front O2 sensor. Yes you can use a cheap antifolwer, but that is only a fix by moving the O2 out of the exhaust stream. You asked if tha antifowler makes the light goes out, and by your followup it sounds like this may be the route you will take due to the high cost (compared to a fowler) of an OE O2 sensor. Since no one has really checked to see how this affects gas mileage performance (which your running a little rough can be caused by a bad O2 sensor) nor catalyitc converter life (which is not a cheap part), i do not recomend it for a front O2 sensor. A shop may try to sell you a cat (the lazy-shops diagnostics). nipper
  19. How many miles. Do a search on Oxygen Sensor, but odds are thats what it is. nipper
  20. If it is cheap enough, just buy it and pull the codes. It can be an EGR issue, or a Evap issue (gas smell). Fuel smell can be as simple as the hoses to the FI leaking. Only thing that costs that much to fix is a cat. nipper
  21. From expierience these are best OE Head gaskets (2.2 and 2.5) T-stat Ignition cables Spark Plug bucket Gromits Front O2 Sensor nipper
  22. Timing belt Water Pump cam Seals Main Seal front re-seal the oil pump Tensioner Idler Accessory drive belts Get an OE t-stat just because. Also replace the rad cap since it is old. Tuneup Stock plugs Factory wires Fuel filter Air Filter PCV Valve OE wires Then your good for another 106K Before you start, wash down the bottom of the engine and trace your leaks. If you need vlave cover gaskets they should be OE alone with spark plug bucket gromits.
  23. Headgaskets should be OE, everything else should be a name brand. Felpro has lets say 20 engineers to cover every gasket they make for every car ( I worked for a major auto parts mfg and we only had 5 for our entire product line). Subaru being OE will either asign an engineer or a group of engineers to evaluate a high cost part to see why it is failing. Aftermarket will not, since they usually see engines at the end of thier lives. OE will constantly evaluate untill they solve the problem. Aftermarket will sit on the stock. Once a problem is solved, OE will put out a notice that all A Hg's are now superceeded by Revision H HG. They will tell all dealers to remove the old design and return them or destroy them. An aftermarket supplier will rarely if ever do that, and whoever has them on thier shelves will run down the inventory untill they have to order H. that may mean going through A B C D etc. Thats why you buy OE. Also the deeper in the engine and the nore critical the part, thje more risky and foolish it is to rely on a cheap part. nipper
  24. Like i said 185 +/- 5psi is normal. sheesh no one listens. And the PROPER WAY of doing a compression test is you do ALL the cylinders, remove ALL the plugs and crank with a fully charged or boosted battery. You do one test dry, then a second test is done after squirting some oil in the cylinders. This is called a wet and dry test.They did an improper compression test. I also doubt they really checked the timing marks. This dealer was useless. Also this is something any decent shop could have checked. nipper
