Everything posted by nipper
Outback steering rack or inner tie rods?
nipper replied to P K's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPull back the boot and watch the tie rod as you shake the wheel. It doesnt take much play at the tie rod to make it feel like there is alot more play then it appears. nipper
Any Diesel Reliability Reports from Across the Pond?
nipper replied to daehttub2000's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo such thing........yet. i have the feeling they are testing the CVT with a diesel. They were having problems making a torque converter small enough that could handle the torque. nipper
nipper replied to P K's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI will remember that i have two of them as Dad's Dad was a plumber. And a bus driver And a fireman. nipper
nipper replied to P K's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThats what i did after i broke it loose. nipper
nipper replied to P K's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIts just where the flats line up on the tie rod. I have used colorful language on this part. It is a simple job, except for that. I have been able to hold the wheel alignment. nipper
nipper replied to P K's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXInner tie rod. The biggest fight you are going to have is the Inner Boots. You may want to replace them both, as they are inexpensive, and both of them are of equal age. They have a locking tab which can be annoying. Getting a bite on the tie rod ends can be "interesting". Count the 1/2 rotations when you unscrew then from the outers. Compare the new ones to the old ones and make sure the threads start at the same places. If they don't (not a big deal) mark where the threads start on the new ones compared to the old ones and start counting there. For the record, a bad rack (this goes for all cars) will leak out the inner tie rod boots, or have ver little boost when cold (winter), almost feel like it is binding, then get better as the car warms up. Subarus if they do go bad usually leak at the innner tie rods. nipper
nipper replied to daehttub2000's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThats my thinking. There have been some complaints that 1st gear may not be a low enough ratio. Sooby may have thought with the engine torque they could get away with a taller gear, but the clutch is taking the brunt fo the abuse. Another clue is that some people have noticed that the sweet spot for starting from a stop takes a little getting used to.
nipper replied to daehttub2000's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSeems there are some reports of premature clutch failures over the pond. nipper
Hillholder Sticking
nipper replied to Urban Coyote's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhehehe i can't keep these things straight in my head sometimes nipper
Aerodynamics
Sorry but you are mistaken. Euro test cycle is very different from US EPA test cycle, to reflect the different driving styles of the two countries. Also there is a difference between fuels of the two countries. It is an apple and oranges comparison. Also you can not quote a test rating number then compare it to real world driving. And there are plenty of places in the USA where you can drive steady state at a given speed limit. Smarts were never really meant for highway driving (Though i have seen one or two). Aerdynamics of cars doesnt really start to come into play untill over 35mph (maybe 40). For real world testing air temp only has a minor affect on the coast down test. I would worry more about wind affecting the test then anything else. nipper
Leaking brake lines
nipper replied to DaveSluder's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHe's already there. nipper
Leaking brake lines
nipper replied to DaveSluder's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou only show how stupid you are by calling others ideas stupid. It is tried and true method as long as there has been tubing that had to be bent. You need to use clean dry sand to it, and sometimes a little heat helps. nipper
Worse / Best / Stupidest Wrench Turning Mistake!
yes but they are revolting...
technical difficulties - no improvement! help meee!
I know newer subarus have a Relay in the blower motor circuit. Even with a bad resistor pack you should have high. This may have a relay too. Door lock light I think is on the mechanisim. Gas gauge, the low fuel light is a thermistor. It sounds like there may not be enough power getting to the sending unit.
Leaking brake lines
nipper replied to DaveSluder's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes the line should require a tool to bend it. If the line is "soft" fill it with sand and cap the ends. It will keep the line from collapsing or kinking when bent by hand. I've always used a tool even on soft lines to make tight bends. nipper
No power no rpm
nipper replied to Tahoe Subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI dont have a 99 FSM but i have a 98 (9.5:1 CR and 137-176 PSI) and a 2000 ( 10:1 CR 156-185 psi MAX compression). Compression ratio in the FSM is 10:1, but that doesnt have any effect on compression depending upon when the valves start to open as the piston goes to TDC. COmpression ratio is a number purely derived from BDC to TDC. A good OBDII scanner you can read sensors output in realtime, so it can sometimes help you connect the dots.
No power no rpm
nipper replied to Tahoe Subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX200 psi is too high, factory spec is 185 max. Old idler and tensioner should be replaced. Something is out of wack. Do you have anything that can read the OBDII in real time. I want to see if this engine temp dependent (the dash gauge only tells you vague things). What happens when you put the car in neutral when it wont move? I dont think it is a fuel problem. I dont like the compression test, it tells me something is out of time. I know the knock sensor can hurt performance. I wonder if the timing being off, and the knock sensor trying to compensate, its killing performance. nipper
2004 Outback - Speedo Died
nipper replied to Seand's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXShould throw a CEL light or tranny light or both. If ti was an earlier subaru i would suspect them, but it should throw a light on a 2004.
2005 Baja - broken timing belt
nipper replied to Jaderider's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere arent any such thing really as bew engines (otherwise that clow boat from japan comes in) in this case. What he is getting is a fully warrented rebuilt in the usa (by some major US truck mfg i forget who it will come to me) for subaru to subaru standards. When you go to a subaru dealer and tell them you want a new subaru engine (as I did) that is what you get. It comes with a 3/36,000 mile warrenty. Of course they take them back (800.00 core charge otherwise). They take them back so they can rebuild them and they live another day.
Aerodynamics
The best method is to make up your own. You first need to take a baseline, a coast down test. YOu time how long it takes the car to coast from speed X to speed Y. It doesnt matter if the road has slope down hill, what matters is that you always use the same stretch of road, your tires are always inflated, the same wind conditions and you just change things one at a time. You time how long it takes the car to roll from 70 or 75 to 55. That will give you a very valid baseline. From there you can measure fairly accuratly what changes you make to the car and what effects it has. nipper
Leaking brake lines
nipper replied to DaveSluder's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIve always found it is easier to use some stiff larger gauge wire as a templet. Then you just bend the tube to match it. It usually gets you pretty darn close on the first try to what you want.
Bad gas mileage...
Usual suspects ... a tune-up first. then check for any dragging brakes. Check tire pressures. nipper
nipper replied to Jaderider's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell it goes back to the rebuilder as a core. nipper
nipper replied to Seand's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou may need a new spedo head. I am assuming you dont have any CEL lights on? nipper
Mysterious gas smell
nipper replied to pickn4him's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt is usually one of the short rubber hoses that go from the fuel rail to the fuel injectors. A shop can peg it down with an emissions sniffer, otherwise just replace all 4 of them.. nipper
