Everything posted by nipper
Rear engine adaption of Sooby driveline
http://www.subarugears.com/index.htm Reverse ground ring gear for a sooby differnential. I found this interesting.
Lifting a 2000 Legacy sedan
http://www.offroadsubarus.com/ http://www.subaruoutback.org/forums/showthread.php?s=&threadid=14738&highlight=lift+kit The offroad board has a lot of aussies on it, but i remeber there being a USA kit for lifting that generation Sooby on there. nipper
98 Legacy - rough acceleration, smooth idle
nipper replied to subx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX"new" or "I got them from subaru yesterday" new. Unless they are the later I wouldnt say it hasnt been diagnosed. Also you need to do a real tuneup, plugs, wires, filters, CV valve. This being a 1998, it may be overdue for a timing belt. On a 2.2 it is every 60,000 miles (1 month = 1000 miles) With it being such low miles the 2nd timing belt may past it's life, assuming that the first one was ever replaced. Check the timing belt. nipper
Clutch smell when AWD is engaged?
nipper replied to capewaveride's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX"When driving my 2010 Impreza Premium (manual transmission) in situations where the AWD is engaged (getting unstuck, doing donuts, uphill on slick surfaces, any tire slippage while trying to move forward) I get a strong clutch burning smell" I'm seeing driver abuse here. Yes you will smell clutch when you beat the snot of the car. nipper
1996 Outback issues
nipper replied to JeffStu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMaybe he had two subarus with bad timing belts?
1996 Outback issues
nipper replied to JeffStu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUpstream O2 sensor should be replaced with OE, they are not cleanable since the oxydizer tends to ear off with time. It is a wear part. The brake calipers. Are you sure the calipers are truly (cant save them no matter what) seized, or is it just a matter of taking them apart and cleaning the slider pins. nipper
Gas Light
nipper replied to subaruzane's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGD slightly off topic, as i havent had a rusted/bad tank since high school. How much does it cost to clean out a tank these days and do radiator shops still do this? I know with plastic fuel tanks this is a dying service for passenger cars. nipper
Gas Light
nipper replied to subaruzane's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThats because it is a thermistor. As long as it is cold (as in gasoline covering it) the light wont come on. When the thermistor is exposed to air, it heats up and the light comes on. thats why the light isnt a on/off thing. It slowly glows. I dont know what the calibration is for it, but i can see where in winter, if it is cold snough, the thermistor can be fooled that the tank is fuller then it really is. There is about 2 gallons of gas left when the light comes on. nipper
Outback steering rack or inner tie rods?
nipper replied to P K's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLate 90's are getting in the 10-14 year old range, so I wouldnt be too alarmed. I have only seen a few 2000's issues. Also keep in mind the cars are getting heavier, so that will have an effect on the rack. nipper
Snowpocalypse meet, Pine Barrens, Sunday 2/14/2010
I'm slipping into a big black hole mentally so I dont know if i can come. I do have a new camera mount I would like to play with. We'll see tomorrow. How well do you know the route? nipper
Winters here - Time to pull the ABS fuse
nipper replied to JohnKos's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had the chance to do some rough tests in a parking lot with the last blizzard. (I found if you pop the car in neutral whne the ABS kicks in (I am assuming safe distance and of course no one is overdirivng for the weather conditions) the ABS works much better. The ABS could have used another sensor or two or a software tweak. The ABS and AWD in automatics fight each other, along with the mass of the car at lower speeds. I now have much better confidence in the ABS.
96 Legacy stalled, restarted, gave P0335, what to do/check?
nipper replied to porcupine73's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnd it was Blu , but it was also at 230,000 miles. They do last a long time back there. I had to replace it again at 236000 miles when i smashed it wheelin. But like Gross said, the cheapest generic rear sensor works.
nipper replied to porcupine73's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust replace it. Blu does this once in a while after a start and it drives me nuts since I can't test it when it fails (once out 300 starts in winter). It's one of those codes that you can trust 99% of the time. nipper
CVT AT in the new Outback? Is it sluggish?
nipper replied to 740gle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGo over to the outback board. http://www.subaruoutback.org/forums/ There they tend to like thier cars new, here we like to wait for them to mature . I drove one I thought it was quicker off the line then my 97 was, and it feels quicker because there are no gearshifts to reference.
Master Cylinder leak question
This is the one part I would demand to customers to be new. It is just too important to take a chance on a poor rebuild. Just replace it. nipper
Dog Tested
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBut they aint driving though they do sound like the driveup speaker.
Electrical Problems
nipper replied to sean56a's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFirst thing first. Chek all your grounds and connections, but I dont think that is it. You are missing the ever popular Brake light and ABS light. Check your Alr output at 1800 RPM with everything on. How old is your bettery?
Dog Tested
http://www.youtube.com/watch?v=D_fKxVBMR60&feature=player_embedded
Strange Handling when snowy
nipper replied to DaveSluder's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnd it was asked what kind of tires.
Weird clutch issues (slipping)
nipper replied to mr.radon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck to make sure the return spring is on the pedal. Next I would question the Master Cylinder. I think the problems are related. nipper
nipper replied to mr.radon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYear and mileage? Is it the orignal master cylinder and slave cylinder? What brand clutch? Did you replace the Release Bearing clips? Is the pedal actually hanging up or does it feel like the clutch?
Steering Vibration
nipper replied to DaveSluder's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWheel balance. Ball joint. Wheel Bearing. Tie Rod End. Inner Tie Rod End. Snow buildup on a wheel. Warped Rotor. Long shots Drive shaft issues. Is it always over 40 mph? Do you feel it in the brake pedal? Is it worse with breaking? Can you feel it in the drivers seat?
If loving this is wrong
I dont want to be right
02' Legacy GT wagon- cold morning rough idle, misfire
nipper replied to 740gle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCylinder s 1-2 and 3-4 fire together. Do a test. Swap the wires around. If the problem moves from 1-2 to 3-4 I would suspect wires. If it doesnt move we can inspect the coils and the CTS. nipper
nipper replied to DaveSluder's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo this is just plain old vehical dynamics, called oversteer. You have oversteer (rear swings out) understeer (turn the front sheels the car resist direction change) and balanced. The OP may just want to peek under his car and make sure the sway bar links arent broken. Oversterr and understeer are sometimes natures way of telling you to get better tires or to slow down. Ghost walking, if it truly does exist (there is another post on this so dont jump on it here) is something else.
