25
Everything posted by nipper
engine dying like clockwork
nipper replied to justaquestion's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Points, wow, i remeber those! How old is the condenser? Do you have a good strong spark? Is the carb dirty? nipper -
Since when is running out of gas on a date a bad thing? How can you not have the trip meter hooked up? It works with the spedo, and the spedo is electronic. Also the spedo not working is probably why the cruise doesnt work. The fuel sender can be fixed by removing it and cleaning it with a hard pencil eraser. Also a tank or two of techron Gas additive will help. Subarus are notorius for innacurate gauges, but why not just fill up when you get to E. You do have a low gas light which should come on when there is about 2 gallons of gas left in the tank. nipper
Huh? Subarus since 1996 have had 105,000 mile intervals on the timing belt. This belt should not have snapped just for the sake of snapping. Maybe a failed cam bearing. http://endwrench.com/images/pdfs/TBeltEWWin05.pdf http://www.cars101.com/subaru/subaru_maintenance1.html I would strongly suggest not to do a thing yet. I would contact subaru and firmly complain about the failed timing belt. I am suspect on the need for an engine. You may have a bent valve or two. Talk to subaru, and more specifically the local area rep. Good luck. nipper
http://www.autoblog.com/2010/02/03/rally-america-sno-drift-2010-the-aftermath/#continued nipper
I am about to make a big order for Justy Parts (look its a sale! but im not sharing till i order mine ) Are there any parts in the 1989 Justy that are picky about who makes them? Particularly the O2 sensor. nipper
Wheel sensors are easy. Just physically inspect them. They need to look cylindrical with a nise 90 degree edge to them. Usually they get eroded and rounded. When this happens they dont pick up a proper signal. This is the way they usually fail, without failing. I'll see what i can find out about the other thing. nipper
Timing belts live a very protected life. They are quite sheltered and can hold thier markings so they look like new. When in doubt replace things. How does the seals look, I know you cant really see them, but any sighn of oil leaks? Also the cars history may come up on https://www.subaru.com/my-subaru/index.html nipper
