25
Everything posted by nipper
The ignition lock or the switch assembly? The assembly is held in by bolts that have break away heads. You just drill out what is lift of those bolts (guess the size of the bolt shaft, dont go by the "head size" and then it will copme right out. Say is this car being scraped? Does it have the cross bars on the luggage rack/ Just askin
The problem with usuing junkyard parts. Ask yourslef why the car was there to begin with. Like lets say, they couldnt get the car started and it was to old to bother repairing... IE no spark. Check the power going to the coil as the engine cranks with an ANALOG meter. Also replace the condenser if it has one. nipper
I liked the vision of 300 acres of plastic forks. nipper
A CB helps but isnt needed nipper
These are not scary issues, and in fact may all be independt of each other. The light issue, check your tail light bulbs and brake bulbs. This is a common problem when the brake filamint in the bulb shorts out against the parking light filament. Replace the bulb that is bad. CEL- Get the codes read. ABS light - Get the codes read (this is NOT done with an OBD reader, there are procedures somewhere on the site on how to do it). Typically it is a broken tone ring or a dying wheel speed sensor. Cruise not working - Code 703 Bad Brake light switch (replace it). Has this car ever been in a flood? Also check your alt output at 1800RPM with everything on. nipper
There is a locking pin in the lock mechanisim that locks the steering wheel. This pin is gauling, and will only get worse with time. Have it fixed since as the weather gets colder, it will just get worse. This is a mechanical issue with the lock cylinder, and the dealer was just being honest with you. You got two prices because it could also possibly have to do with the circuit that connects the shifter interlocks with the ignition switch. This also may not be a straight "just replace the cylinder" thing as they may have to replace the fitting that the pin goes into too. nipper
Did i just hear a gauntlet being thrown?
Front Rotors are MSRP 94.95 1st subaru price 68.36 Rear Rotors are 94.95 68.86 Front pads are 94,95 63.36 Rear Pads are 94.95 63.86 So thats 70X4=280.00 Rotors 64x2= 128.00 Pads Normal labor is 1 hour per axle i think, maybe 1.5 hours. Any time a car goes on a lift usually it is a 1 hr charge. minimum Expensive brake work is avoidable if you dont let the pads get that low as to grind. The car did not have to go to the dealer for this service, so maybe you could have saved 100 bucks. nipper
Welcome
SVX Research
nipper replied to 9098's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Because it was a luxury grand touring car, and in the early 90's those kind of cars did not come with a manual shift. Windshields cost an arm and a leg and something else you are fond of. Be leery of any SVX with its original transmission. Any odd shifting it will need a tranny (best fix is swapping in a legacy tranny and rear diff). Expensive fix is having the original tranny rebuilt to correct the issue at a proper rebuilder. Rear wheel bearings nipper -
I know these tracks are commercially available. I will not buy them i will not buy them i will lust after them
I love bars leak. I dont love two of any stop leak/conditioner in a cooling system. And i dont beleive this is the cause of the problem either, as it would cause redced heating of the air all across the board. The OP said he was getting no air flow out the right side, which is not something that bars can cause. nipper
