Everything posted by nipper
disassembling 97 legacy and have questions
nipper replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo you never had a stripped bolt that you had to use a drift or a chisle to remove it? You just hit it like an impact gun. hitting it to it turns in the direction you wish for it to loosen. nipper
nipper replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDang i just wanted the cross bar screws. FSM says to use a drift and a hammer "hit the torn bolt head to loosen and remove the ignition switch" Ah we love brute force. nipper
Random overheating
nipper replied to thirdgenfirescu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre you using an OE thermostat? Have you replaced the cap (at this age you should). Did you fill the cooling system SLOWLY with the car running? nipper
location of fuel filter
nipper replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey are supposed to last the life of the car. With the ultra clean fuel we have now I would tend to believe them, but maybe replace it every 100K. Its realtivly easy to get to for being in the tank and the part doesnt cost alot. nipper
nipper replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe ignition lock or the switch assembly? The assembly is held in by bolts that have break away heads. You just drill out what is lift of those bolts (guess the size of the bolt shaft, dont go by the "head size" and then it will copme right out. Say is this car being scraped? Does it have the cross bars on the luggage rack/ Just askin
98 Legacy Outback -- Need compatibility details
Go over this car with a fine tooth comb. Removing the rear diff for torque bind id like cutting off a leg to cure a hangnail. The FWD fuse has no effect on the way the car operates when the RWD is removed. Only God knows what else is wrong with this car. nipper
Rear defroster sucks
nipper replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat I do (if this is a wagon) is use the rear washer. It really helps. nipper
who's good with electrical?I don't want to go to a stealership!!!
nipper replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe problem with usuing junkyard parts. Ask yourslef why the car was there to begin with. Like lets say, they couldnt get the car started and it was to old to bother repairing... IE no spark. Check the power going to the coil as the engine cranks with an ANALOG meter. Also replace the condenser if it has one. nipper
300 acres in forks, wa, got any ideas how to use it?
I liked the vision of 300 acres of plastic forks. nipper
Nov 14th - Sat Pine Barrens, NJ
A CB helps but isnt needed nipper
Replaced Coolant Temp sensor, no change!
nipper replied to jbmorse's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSay, has anyone plugged in the green diagnostic connectors to each other under the dash? That can make the fans run on.
ABS and Check Engine Light
nipper replied to cw360's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHappens all the time. You apply the brakes, the power backfeeds through the parking light filament and makes the dash lights glow. nipper
nipper replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXStart with square one. How is the alt output? nipper
nipper replied to cw360's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThese are not scary issues, and in fact may all be independt of each other. The light issue, check your tail light bulbs and brake bulbs. This is a common problem when the brake filamint in the bulb shorts out against the parking light filament. Replace the bulb that is bad. CEL- Get the codes read. ABS light - Get the codes read (this is NOT done with an OBD reader, there are procedures somewhere on the site on how to do it). Typically it is a broken tone ring or a dying wheel speed sensor. Cruise not working - Code 703 Bad Brake light switch (replace it). Has this car ever been in a flood? Also check your alt output at 1800RPM with everything on. nipper
Ignition key won't turn (99 Subaru Legacy)
nipper replied to fritztc1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere is a locking pin in the lock mechanisim that locks the steering wheel. This pin is gauling, and will only get worse with time. Have it fixed since as the weather gets colder, it will just get worse. This is a mechanical issue with the lock cylinder, and the dealer was just being honest with you. You got two prices because it could also possibly have to do with the circuit that connects the shifter interlocks with the ignition switch. This also may not be a straight "just replace the cylinder" thing as they may have to replace the fitting that the pin goes into too. nipper
nipper replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX+1 And as i said before, ignitors/ignition amplifiers/mystery box will drive you nuts on these cars trying to diagnose it. Thats why you rule everything else out first, OR just toss in a complete working one from another car. nipper
Advice on purchasing code reader
nipper replied to dcbpe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCanBus. It means that is it multiplexed. It will read new cars and old cars with OBDII. Can is the new OBD communication system. Any reader you get should be CAN-OBDII ready. nipper
Ken Block - trax
Did i just hear a gauntlet being thrown?
Stealerships replacing heat sheilds??
nipper replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the sliders were not dissassembled and lubricated when the brakes were last done i can see them wiping out. Next time ask for the old parts back. nipper
nipper replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPS the V belt (yes they call it that as I just ordered some for Blu) is high. I would question them on that one, or they shifted some of the labor charges around, which is not uncommon. nipper
nipper replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFront Rotors are MSRP 94.95 1st subaru price 68.36 Rear Rotors are 94.95 68.86 Front pads are 94,95 63.36 Rear Pads are 94.95 63.86 So thats 70X4=280.00 Rotors 64x2= 128.00 Pads Normal labor is 1 hour per axle i think, maybe 1.5 hours. Any time a car goes on a lift usually it is a 1 hr charge. minimum Expensive brake work is avoidable if you dont let the pads get that low as to grind. The car did not have to go to the dealer for this service, so maybe you could have saved 100 bucks. nipper
New to USMB
Welcome
SVX Research
nipper replied to 9098's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBecause it was a luxury grand touring car, and in the early 90's those kind of cars did not come with a manual shift. Windshields cost an arm and a leg and something else you are fond of. Be leery of any SVX with its original transmission. Any odd shifting it will need a tranny (best fix is swapping in a legacy tranny and rear diff). Expensive fix is having the original tranny rebuilt to correct the issue at a proper rebuilder. Rear wheel bearings nipper
nipper replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat is not a bad price at all. I have seen shops quote alot more then that, a hell of a lot more for heat shields. Considering most dealerships get over 100.00 an hour for labor she got a really good price. nipper
Ken Block - trax
I know these tracks are commercially available. I will not buy them i will not buy them i will lust after them
