nipper
Everything posted by nipper
  1. and far less conservative. But ive been pushing this point for 2 years now, and sometimes, well, ya got to do what ya got do. Hopefully there will be a bar nearby after "brunch"
  2. Of all the places I would rather not be ... Seems like my partner wants me to meet the inlaws (this goes under becareful what you wish for...), so I dont think I can go to CT and VA at the same time. nipper
  3. Ford 500 AWD Mercury Montego AWD Saturn View AWD Toyota HIghlander Ford Escape Hybrid Audi A6 Audi A4 Many AWD and many much heavier then the sooby. Though the one on thier I would least trust would be the saturn. My only question is can it hold up to 300,000 miles of driving. 100,000 is acceptable for the avg car (though 160 is expected). But for a sooby it has to be 300,000 miles. nipper
  4. Justy CVT was a completly different animal. Usually the issue was the brushes failing on the wierd powdered metal clutch they used, the trannys themselves would keep working. The CVTs in the Prius are reaching 100K in the US. http://wikicars.org/en/CVT There are quite a few out there, though i will say subarus being the first to use a chain will be interesting to watch. nipper
  5. I am withholding my judgement, but they seem to have gotten the bugs out of them.
  6. You may be one of the rare ones that have a bad thermistor (level light sensor) This is easy to dig into. Another possability is a bent fuel sender assembly. All this good stuff is easily accessed by the passenger side cover behind the rear seat in the floor. There is another sender on the drivers side, but it doesnt have a light. nipper
  7. damndamndamn i can't drive a stick anymore (yet) due to the car accident. Otherwise this would be such a tempting thing to look deeper into. nipper
  8. I've been watching this thread, and the site isnt that helpful, or i am not seeing what i want to see. So excuse the dumb questions (yes i do make them on occasion) What can this box be used on (transmissions years etc). This box basically is a far more agressive, controlable, and basically a plug in device? nipper
  9. Exc pet for when you loose a belt, the water pump starts leaking, your low on coolant, the thermostat gets stuck open or closed. That reasoning doesnt fly. It is totally necessary as catching a 100.00 failure can save you from a 7000.00 engine replacement. It is just foolish to think nothing ever breaks, thats how you get into far more danger then taking measures to monitor conditions and stop them before they happen. nipper
  10. If I had to be a 2010, I would have to give the Imp a close look, but I think I would leave the subaru fold. Luckily there is all those up to 2009 to look at. nipper
  11. 2000 is a phase II. At that high a mileage, I would go for a (much) lower mileage engine. The engine may have good compression, but ... When you do the HG, you will be resurfacing the heads. this may increase compression, and add stress to the old rings. Its like giving a 90yo man a 22yo nympho girlfreind. He may enjoy it, but you just know something is going to have give. Usually what happens is the rings have a problem dealing with the new tighter heads, and you will develop blowby. BTW your compression is about 15-20psi too high, which is a bad thing. On a new engine I would expect 180-190 MAX. You have something else going on too. nipper
  12. Lazy O2 snesors wont always throw codes, they are working just slow to respond. Loose plugs, you are so lucky they were caught. usually a loose plug sint found untill a loud PING followed by a loss of power is discovered. The plugs come flying out and take the threads with them. It is rare but it happens from time to time. nipper
  13. Autos dont really need a low range, that is what the torque converter is for (though its nice to have). nipper
  14. Some dealers have them just to show them off before they go on sale. Call your local dealer. I may go and see how much they want for a 2009 nipper
  15. I would hope for a hybrid dash. Digital dashes are a PITA, thats why so few cars use them.
  16. Temp gauge is gone. There is valuble realestate on that dash, and by federal mandate it seems there is nhow a MPG gauge on the dash. you want a temp gauge write subaru and tell them that. There is still a chance there is an engine temp readout on the senter information panel, I am not sure. nipper
  17. Many many many car mfgs from all over are doing the same thing. nipper
  18. A 1998 anything has a increased chance of having a bad HG. Interestingly it is also more likely to have a replaced HG then any other 98 on the road. Pay close attention to the color of the coolant in the overflow tank, looking for debree or oil residue. TB really is just mileage (over 200,000 things dont last for ever) or unknowledgable owners. Look for mismtached tires, burnt tranny fluid (on autos). Take it for a test drive, drive in tight circles. The car should be able to make the circle with little or no gas. If it has TB it will be very obvious. A slight lurch initially when makeing the tight turn is normal (as the computer sorts everything out). This is common for most real AWD vehicals. nipper
  19. http://www.autoblog.com/2009/06/29/first-drive-2010-subaru-legacy-improves-commercial-appeal-reta/
  20. Im going with either a loose belt of a heat shield. You can adjust the belts to see if it changes. nipper
  21. 7 inches in a month where we normally get 2 inches, and the month aint over yet. you should see my poor peppers. Glad it worked.
