Everything posted by nipper
Hill-Holder Flatland Lockups
nipper replied to quazi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX29 days of rain out the last 30, i dont have anything else to do hehehehe
nipper replied to quazi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOn www.endwrench.com in the archives in brakes section it describes the hill holder. It just sounds like it is out of adjustment. nipper
2000 Forester - Backfire Problem
nipper replied to howards11's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhenever this happens, you have to start with a tuneup. This rules out plugs and wires and clogged filters. Backfire could be a vac leak, a extra lean condition, leaking valve, leaking injector. nipper
Transmission squeal/squeak 1999 Legacy Wagon 2.2 ATX
nipper replied to yesyeah's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is an auto? Does it do it with the AC on or off or both? nipper
Misfiring need help
nipper replied to DavieGravy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsoory my mind goes between legacys and loyalesmodels in those years. Still there should be no spark leakage at the coil towers even with the wires removed, cap or no cap., especially on a waste spark system, since two plugs fire together. The voltage will find the path of least resistance, and if it is finfing the coil tower the easiest path, that indicates a hairline crack. Put the wires on with the car running and wet the coils and wires. There should be no sparking. best done in the early evening. nipper
Misfiring need help
nipper replied to DavieGravy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXActually there should be no arcing at the cap if the wires are fully away from the cap. You need a new cap and rotor, you cant tell just by looking at them sometimes that they are good. If you dont replace it and still have issues, its, well, your doing 1/2 a tuneup. Youll just be chasing your tail. nipper
2003 LL bean wagon- need groundhog repellent
nipper replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLooks like an english groundhog. nipper
Weird Shake and Noise
nipper replied to axgutt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSteeringwheel thing? nipper
Misfiring need help
nipper replied to DavieGravy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave you replaced the cap and rotor? nipper
the ring with timing marks fell off!!!!!
Which ring ? and dont say the one with the timing marks Where is it on the engine? The only things i can think of, well, that has to be one hell of a dent in the front end. nipper
Won't Start
nipper replied to LegacyWagon92's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX120 PSI is low. You need to do a wet and dry compression test. The numbers being even at least makes me think the timing is OK. You wont really have any CEL codes unless the engine runs. CHeck the engine temp sensor Check the Crank Position Sensor Check the Cam Position Sensor nipper
Help-Bouncing Speedometer???
nipper replied to JimmyJam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthats a hard one, as you can either have a cable or en electronic spedo. 1995 is when they switched. Look under the hood, at the firewall around the master cylinder. You will see one cable, for the gas pedal. Do you see a second cable that loops down to the transmission? Do you have any CEL lights? nipper
Are the valves bent?
nipper replied to billrigsby's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it wont hold water, the velve stem or valve face is bent, most likely the stem. Either way you need to replace the valve. Damage can be from nothing to looking like a bent mushroom. nipper
nipper replied to JimmyJam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwelcome. we cant tell you a thing without knowing year, model, mileage transmiision and if it is 2wd or 4wd. nipper
Transmission seized, how to move?
nipper replied to kami333's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs it possible that it is in two gears at the same time? It does happen rarely on soobies, but it happens. nipper
99' Legacy Water Leaking from Roof handle Passenger side
nipper replied to cfendrick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGot o self service car wash and do the same thing. Also check to makeure the drain hoses are not loose on the sunroof drains.
CT Cookout July 25th.A West Coaster will be here.
Right now its a maybe for me, i will know as we get closer. nipper
timing belt components - cheap kit or OEM?
nipper replied to cjd160's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEven if it is your time, your time is still valuble, so get OE parts and do it once, right, the first time. It still amazes me how people want to cheap out (I can understand if they have no choice) when the OE parts were trouble free for 106,000 miles. Those parts work hard, and are key to the engines survival. its possibel that 80.00 in savings can sot you a replacement engine. Just go OE and have peace of mind (and dont forget to do the cam seals, main seal, waterpump and re-seal the oil pump). nipper
Replacing Struts.....have questions
nipper replied to elmwood22's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNever replace just one strut, at the very least you do them in pairs. Replacing just one can make for very bizzare handling (that goes for any car). You car is old enough that you will need four of them. You can usually get a great price on KYB GR-2 struts if you search the net. nipper
Sedan AC compressor
nipper replied to Knichol's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou mean the compressor clutch? Yes. nipper
annoying floor mat....
nipper replied to AEIOU's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWasnt this a recall? nipper
nipper replied to cjd160's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnd there are people who barely made it past 106,000 miles before they bent valves. Its not worth the hassel to risk the expense (and as far as i am concerned stupidity to let it go). Considering OE parts last 106,000 miles trouble free, i always go with OE. Bearings themselves all come from the same source, as they really are not worht the effort to counterfit or make poorly (even for China). However for the belt, that should really be from OE or a known supllier. That belt just works too hard to be anything less. nipper
Oil pump test, oil flow test, new HG reuse
nipper replied to 98sub2500leg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWasnt there also something about using too much sealant someplace causing a cam bearing to become oil starved?
car runs cold all the time
Just go buy a new thermostat. replace the radiator cap and make sure the cooling fans arent on all the time. Check your ignition timing and the EGR valve operation, otherwise it is what it is. If you want you can buy a cheap gauge and wire it in just to test the cooling system. You can also stick a meat thermometer in the rad filler neck and wait for the thermostat to open up and read the temp. Check your altenator output too. If it is putting out too much voltage it can make the gauge read off. nipper
97 Legacy Outback air bag, cabin air filter
nipper replied to spud's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey are finding 20 plus yearold air bags still work, so dont worry about it. nipper
