Everything posted by nipper
crank pulley wobbling?!?! and some strange noise
nipper replied to greenleg88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes be worried. Try not to drive the car untill we figure this out. This is a 2.2L engine. When was the last time the timing belt was changed? You can have either a failing vibration damper (annoying) or a vibration damper that is working its way off (bad). The latter can damage the end of the crankshaft. how many miles? (always post that info). Is the noise a spinning noise or a rattle kind of noise. If it is a spinning noise, where theere isnt much there to make that noise. Putting water on the fan belt and pullies would tell you if the noise is coming from that end of the engine.
Oily spark plug sockets
nipper replied to ott_leg01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXssshhhh don't enourage him nipper
Blu ... driveshaft?
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWheels are fine. On Blu you replace the driveshaft. Luckily i know someone with 2o of them in his garage. It's just so odd that I can tell without dial indicators (its that small) but they were stolen along with some of my tools also.
tire blowout from pothole....
nipper replied to greenleg88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLimited slip diifs on any car have the same requirement (wheel to wheel on the same axle), and all AWD cars have the same need, and some of them are actually pickier. I am not sure how the 3rd generation of each system (or 6th in some cases) deal with a differnt size tire. Some may disable the AWD, some may just cook. read your owners manauls carefully. The checkbook you save will be your own. nipper
Blu ... driveshaft?
I am going to be away till tuesday, but i figured i would let this one sit and simmer for a while Blu 1997 OBW 245,000 miles, 45,000 on rebuilt engine. One frt driveshaft replaced aabout 40,000 miles ago one rebuilt 30,000 miles ago. Recent work, two new front ball joints (dealer installed) right fron inner tie rod (last week). Left front will be replaced because, well its old when i come back. Wheels are in balance and have been rotated. After the last wheeling trip Blu devloped this odd vibration. I though it was mud in the wheels. It never went away. We found a torn inner tie rod boot, and replaced the boot and the end 1 week ago. When the car was at the dealer 2 weeks ago, aside from bad ball joints they found nothing at all wrong in the front end. Since the car was goofy in a crosswind I had them replace the ball joints. I figured if there was money to be made the dealer would find it. He also said the front axles are fine. Vibration is still there: Vibration comes and goes. It feels like it is origniating in the front end of the car (mid point forward). At times you can go all the way to 80 and smooth as silk. Below 40 it doesnt exist. It builds like a sine wave, At the peak you can feel it in the brake pedal, steering wheel, and the car lightly shakes. I noticed something yesterday, the AHA moment. Going around a curve at 60 mph it started then held untill another curve, then built up. At another curve it dropped off. Have I ever told anyone I hate the way sooby front CV joints are mounted . Something was out of balance or out of synch. Only one thing can get out of synch really, wheels or the driveshaft. Since the tires were rotataed and the vibraiton never changed i ruled them out. It finally stopped raining today. I got the car up on ramps. As far as I can tell the rear universal joint is good (but there is too much slop in the rear diff, but I will live with that) Can someone with a high mileage sooby tell me how many degrees of freeplay they have, so I know whether to ignore it or not (most likely will ignore it). It is devloping that 70's mopar thunk . Carrier bearing and universal seems ok. Front Universal is hard to tell but there is some side to side in X but not Y. It is super super minor but it is enough for me to think thats the reason for the vibration. There is no comparable play anywhere else in the driveshaft. My guess is that when it gets into 3rd or 4th harmonics when the driveshaft roates at a different speed from the frt driveshaft. The car shakes untill it rotates at a different speed (a curve) and then gets back in synch. If I get a straight stretch after things vibrate, I have a tough drive untill it gets back to where it is happy. this is the only thing I can think of. The last time I had a bad uni was in a 87 GL, and that one almost fell out of the car it was so bad. This one is just very subtle on physical inspection. It almost seems like there is play in the tailshaft itself, thats how subtle it is. So Blu is going to sit out this road trip, well he is going to Hershey PA then from there we will take my partners CRV (ick) to chicago. I think I have it pinned down, but my self confidence is shot lately, as life has been getting really hard with really no real moral supports or confidants around. Everything just seems so bleak, but thats not something i want to burden anyone with. So is my logic valid? Thanks.
oil burn off after complete head replacement
nipper replied to jimrichard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMonitor it. It could be just dripped oil, and it may take time for it to burn off, especially if its on the heatshields and not the exhaust itself. Did you do this yourself? nipper
nipper replied to greenleg88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes raise a good point, is this AWD or FWD. nipper
1996 Legacy Outback-- AT jolts from 1st to 2nd
nipper replied to healyme's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen my 97 does it i know its time to do a fill and drain in the tranny . Soobys are known for hard 1-2 shifts, it can be startling at times. But a hard shift is always vetter then a long slipping shift. Change the fluid and you should be fine.
nipper replied to ott_leg01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf in the future you develop a miss or throw a misfire code, this will need to be addressed. You can let it go till then. The oil damages the insulation in the spark plug wires and may cause a miss on damp mornings. You would need to get the spark plug bucket gromits from Subaru, as aftermarket is not up to spec. BTW change your PCV valve, it may help reduce what little leakage there is. nipper
Not a happy camper...new motor blues
nipper replied to SubiPilot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA rebuilt engine is essentially a new engine. nipper
nipper replied to greenleg88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLook up "torque bind" that will explain why. Temp spare is just that, supposed to be only temp (very limited mileage). Once you get a real tire on there we can address any issues. Make sure the tire is 1/4 circumfrence of the other tires, or get it shaved down to match. nipper
Spark Plug Changing 101 Questions
nipper replied to axel's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI disagree. I have yet to see a cat go bad on waiting out sparkplugs. Now if you continue to drive on a missing plug, then you can have issues (and that can happen at any time to anyone). And thats not only my personal opinion but professional opinion. SUbaru for some reason likes short plug cycles, where shall we say, more inferior engines of other mfgs tend to push the 100K limit. nipper
nipper replied to axel's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere are cars out there that are even tougher to change plugs on. SUbarus are just "difficult" but not to bad with the right amount of swearing, and human sacrifice to the mechanical Gods. nipper
Hit a moose in the justy
Wellw e arent sure about the moose yet, i bet he hurt like hell the next day.
OMG you hit Moosens? No wonder he's not on line
nipper replied to axel's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would suggest untill you have a running issue or 100,000 miles whichever comes first (no cel no ping). Change the fuel filter, air filter and PCV valve regularly and you can get more then 30K out of the plugs. When you do change the plugs if you decide to go with the upper end, change the wires at the same time. nipper
Home Made Roof Rack
Ok ignore me. Why reinvent the wheel? What are you planning to carry on the roof. there is a limitation as to how much you can put on the roof, and where you need to put the supports. nipper
cylinder compression seems to measure low
nipper replied to 98sub2500leg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes handturning tells you nothing. nipper
Cruise control and rear defroster stopped working
nipper replied to Gene J's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre you sure the rear defrost is not getting power? Cruise check the break pedal and/or clutch switch. They are the most common reasons. nipper
Crank shaft pulley bolt won't come out
nipper replied to DavieGravy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave you started a big breaker bar and the starter? (just disable the ignition). nipper
2005 Outback 2.5i, heated seat not working
nipper replied to cheetah8799's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXplease share details.... nipper
Tstat gone wrong/loosing coolent
nipper replied to sleepylegacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave you replaced the Radiator cap? Did you fill the cooling system with the car running? Did you wait for the T-stat to open and add more fluid? nipper
A/C recharging question
nipper replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt does a third too. It will tell you if you have a leak, as it wont pull down a proper vacume. nipper
nipper replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnd safer. nipper
breaking in a new set of brake pads
nipper replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot with modern brake pads. Just go and drive, and realize the first few stops may be dicey till the pads seat themselves and the calipers adjust. Usually the first stop sets everything up. nipper
