Everything posted by nipper
Vibration in Gas/Brake Pedals
nipper replied to ltk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhrmm. Does the vibration change with vehical speed or engine RPM. Personally I would have looked at rotors, wheels (rotate them and see if it moves), CV joints, wheel bearing. Car seems awfully young for bad mounts. Have you taken the mnechanic for a ride to show him? nipper
Brake pads that don't fit into their holders
nipper replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBeen there done that myself, and not just on soobys. I also have had them fall out of the car, the other extreeme. nipper
94 Legacy turn signal issue
nipper replied to subieluvr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYup. The newer electronic flashers use the bulb resistance as part of the timing circuit. nipper
How long will a noisy wheel bearing last?
nipper replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTill it fails (which ttechnically it has already failed). Also you can be destroying the hub, as i have done that many times, and that quickly ups the repair bill. Just fix the thing before you need a bearing, hub, and a tow truck. nipper
nipper replied to subieluvr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou have a bulb that may be internally shorted. It looks fine but take a meter to it or inspect it and youll see a filamint is shorted. nipper
Two or Three Core Radiator?
nipper replied to MorganM's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou dont want to dump heat, you want consistant temps for best running. I would stay with the factory spec radiator, they do a really good job. nipper
Recharging A/C in '03 Legacy?
nipper replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXO rings leak, they aint exaclty the highest tolerance part there is in a car. Can happen to any car any age, and sometimes right in the lot before its sold. nipper
nipper replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt already is giving you a warning sign, its noisey. Its sort of like asking if your chest pains are a warining sign of a heart attack. By the time your asking it may be too late. replace it now before the driving season starts, otherwise Mr Murphy will tap on your shoulder, usually after you get the car packed for a trip, the wife/kids are driving, or you really need to go someplace in it. Its noisey, it has failed. nipper
Way too much cabin noise!
nipper replied to 1998subie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck your tire pressures. nipper
sluggish 97 legacy
nipper replied to trialsguy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBefore we start doing expensive things ....... go out and spend 20.00 on a vacume gauge and tell us what it reads and what it is doing. nipper
sluggish 97 legacy
nipper replied to trialsguy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell if you have emissions inspection you need to replace it. i would prefer that if it is clogged it gets replaced. nipper
Mystery Noise - Suggestions Appreciated
nipper replied to Carmel Corn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwheel bearing? nipper
sluggish 97 legacy
nipper replied to trialsguy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXreplace the wires with OE. You can have either a lazy knock O2 sensor (your way due for the front one so its not wasteful money to just get one from subaru). AN over hyper knock sensor, or a clogged cat. Hit the cat with your hand when it is cold, if it rattles its dead. And yes at 200,000 miles you should still run close to new. your also coming up for a timing belt change (every 106,000 miles). nipper
Not a happy camper...new motor blues
nipper replied to SubiPilot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBy 7000 miles the rings should be seated. Subarus use harder rings then most. It may come down to a compression test wet-dry to see what is going on. A bad PCV or misrouted hoses (not thata there are that many) or a clogged hose can cause oil burning. I would let the miles pile on some more and see what happens. the supplier knows of your issues, so you would be covered if you want to add more miles and take a wait and see attitude. And your using regular dino oil? nipper
gate lock on 2005 outback
nipper replied to gritle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell in most states it is illegal to have anyone ride back there, and untill dogs grow thumbs, there is no need for an inside latch release. nipper
nipper replied to SubiPilot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXrings smoke on acceleration. Valve guides/stem seals smoke on deceleration. nipper
Blinking check engine light
nipper replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo start with a tuneup. Plugs OE wires fuel filter PCV valve and air filter. Unless you want to throw money away on a coil when what it may be is a bad plug wire. Replace the O2 sensor too (OE front) as that would give us a good baseline nipper
Help with fuel delivery problem 01 Outback H6
nipper replied to subyfreak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEr um i think you may have just poked fun at 1/2 of the members on the older sooby board
Replacing HG/2.2 engine
nipper replied to john in KY's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes. nipper
nipper replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust check the codes first and post them here. And either way when was the last time it had a tuneup and a timing belt change? nipper
Forester Alarm just goes off
nipper replied to jimrichard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBad door pin. Low battery voltage. Dirty grounds. A hairy motion detector. nipper
Brakes lockup when braking hard in reverse
Lets define what hard breaking is. The self adjusters are basically a ratcheting mechanisim. There is a primaryt and secondary (leading or trailing ) shoe. BY backing up your causing the trailing shoe to become the leader, and due to the way the self adjuster cable is routed, this works the self adjuster. You dont have to break all that hard to get them to work. They will even adjust when driving normally. I suspect that your break hardware (springs) are tired and need replacing. Any issues with self adjusters can usually be traced to tired springs. nipper
Can't find the tapping noise!
nipper replied to MorganM's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRemove the accessory drive belts start the car and if the noise is still there Next remove the timing belt covers. Use the spray lubricant of your choice (or even water). The noise will change for a very short period of time and then you will know. nipper
nipper replied to MorganM's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo the wire trick is easier. Remove the drive belts asnd see if it is sitll there. 276,000 on a 2.2L shold be ok, but i thik this has a 60K timing belt interval . That would mean your coming up on its third timing belt, and i bet the tensioners and idlers have never been changed.
nipper replied to MorganM's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmileage? STart by removing the accessory drive belts. When was the last time the timing belt was changed and how many miles. Rod bearing, unplug plug wires one at a time, if its a rod it will change pitch. nipper
