Everything posted by nipper
A/C Problem
nipper replied to fixitguy50's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like the AC compressor is failing. What was the warrenty on this item? Subaru AC compressors dont go bad usually, so I would recomend a used one. ALso you may need a new reciever drier. These have a filter in them that catch all the tiny parts if the compressor ever implodes. I personally would not take a chance on using the same one on a 3rd compressor. nipper
pic of corroded head gasket...
nipper replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat is why the rear seperator plate works. Its the Subaru Auto Anti-rust system. nipper
A/C Problem
nipper replied to fixitguy50's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI forgot about the overcharge scenario, as its been a long time since I have seen someone do that. nipper
CV joint bad after changing struts
nipper replied to wtdash's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSometimes this happens. It's not often but it does. As long as you are there inspect the wheel bearing too. nipper
2005 Outback 2.5i, heated seat not working
nipper replied to cheetah8799's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXStart with the easiest thing first. Use a meter and make sure you have continuity in the heater coils. If you dont, then we are done here. Odds are thats the problem, the easiest to diagnose and hardest to fix. nipper
Can you drink in the back of a brat?
Some states just require that all passengers wear seatbelts. The jump seats have seat belts. nipper
Oil Pan Drain Plug Washer
nipper replied to axel's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThats where i got mine from
A/C Problem
nipper replied to fixitguy50's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like the AC compressor is siezed or in the process of seizing up. What happens when you remove the AC belt and drive the car with the AC on. nipper
A/C Problem
nipper replied to fixitguy50's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you mean the car wont accelerate or the engine RPM wont go increase? nipper
Tstat gone wrong/loosing coolent
nipper replied to sleepylegacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm not following either, but at that mileage it could be the T-stat, cap and or radiator. More details please. nipper
nipper replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLeave well enough alone. If it is working fine, why look for trouble. nipper
nipper replied to axel's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNope, not untill i got a great deal on a ton of them from here. nipper
what could it be? vibrations at ~60mph
nipper replied to greenleg88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThats a little early for inner tie rods, but check ball joints, inner and outer tie rods, as well as the universal joints in the driveshaft. If it makes you feel better Blu has the same thing right now. Some roads make it worse then others, and sometimes its not there at all, so i am going to replace the tie rod ends and go from there. He got new balljoints 2 weeks ago. He needed them. nipper
Brake pedal sinks down too low....
nipper replied to mwatt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi had a frozen rear claiper giving a wierd pedal, thats why i was asking when was the last time he had the brakes done.
nipper replied to greenleg88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOP needs to post how many miles are on this car. Inspect your inner tie rod ends, outer tie rod ends. nipper
nipper replied to mwatt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWlecome. How many miles? When was the last time the breaks were done? When was the last time the brake fluid was changed? nipper
99 outback engine question
nipper replied to mdjdc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXand the price of a two rebuilt cylinder heads? penny wise and dollar foolish. nipper
nipper replied to mdjdc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour going to have to check things, especially the tensioner. Replace the belt as it may have gotten damaged, but belts just dont jump for no reason. Something isnt right. Also inspect the sprockets for any wear. If there were any non-subaru parts, get OE parts. nipper
nipper replied to mdjdc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEr um , you know i hate to tell ya this They dont do that unless the timing belt is stretched or the tension and idlers are tired or bad. If you have over 106,000 miles or 106 months on this car you need a timing belt. Heck it jumped, you need a timing belt.
1994 automatic legacy wagon dies randomly
nipper replied to seth3030's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes this have a ignition module by the firewall (i think it does)? the next time it dies check for spark. If you have no spark it can be that module. Things like the crank sensor can be tested with a analog multimeter while the engine turns. Ignition module/amplifier can drive you nuts trying to diagnose it. If you can get a used one throw it in and see what happens. nipper
alternator help
nipper replied to erik litchy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhave you priced a new regulator or diode trio vs the cost of a rebuilt alt? There is a saying penny wise and dollar foolish. Sometimes the replacement part (just 1) is many times more then the cost of a replacement alt. nipper
nipper replied to mdjdc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRunning like crap after shutting the car off is 99% of the time a timing belt/chain jump. The sudden unloading of the belt causes the jump. How many miles are on this car. Its not a coil pack, as it would be 1/2 or 3/4 and it wouldnt be suddenly. nipper
2000 OB turn signal lever problem
nipper replied to Fabric8r's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
- 2000 OB turn signal lever problem
nipper replied to Fabric8r's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDOnt just look at the bulkbs. Take them out and inspect them. i bet you have a bulb shorted out. nipper- Affirmative Posts where are they?
nipper replied to subaruplatt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDONT DO IT! Most country air comes from higher altitude. It is there fore thinner and you need twice as much as sea level air. Also city air is fortified with minerals and vitamins thats are essential for the lubrictain of the valve stem. nipper - 2000 OB turn signal lever problem
