Everything posted by nipper
Low Battery, engine dies?
nipper replied to Megell's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi use www.1stsubaru.com alot. there is also https://www.subarugenuineparts.com
clunking noise in rear diff 99OBW
nipper replied to lizardbrain's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHaving the driveline up in the air is going to confuse you to hear the noise. For instance (im going to do simple numbers here). It takes three turns of the driveshaft to make the ring gear turn once. The power from the ring gear goes into a mechanical splitter, that avgs the driveshaft rotation between the speed of the left wheel and the right wheel (this is how you can make turns). If one wheel is turning 0 times and the outer is turning six times, the avg is three (hence the driveshaft speed). Thats why i was asking for the pattern of the noise. This is assuming is is a hollow sounding knock of some kind. If it is a scrape kind of noise it may be something in the brakes. Inspect the rear CV's too (though they tend to last forever). You may also wish to drian the rear diff fluid and have it drain through a cheese cloth to see what comes out of it. Chrysler rear diffs used to thunk as they got older, when you went from forward to reverse. This was just play developing in the diff, and the cars went thier entire lives like this.
Early 90's small Pickups; Who made good ones and who made junk
That has been GM's model for quite some time. The bean counters starve the cars, then by the time the model is mature enough for them to sneak everything the beans counters took out back in, they have to stop the model. nipper
AWD to Front 2WD
To do this you have to open up the transmission. It would just be easier to get a used transmission. nipper
nipper replied to lizardbrain's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXClunking is either a bad bushing or a bad Universal joint. If its a clunking joint you will notice it rather quickly by turning the shaft by hand. Now if the clunk matches road speed (not there when you change directions) its possible you may have a broken tooth in the diff. Does the noise match tire speed, or does it seem to be three tires turn to one clunk? nipper
nipper replied to Megell's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe battery is used for starting, and the Alt is used to run the car. The Battery is used to suppliment the power if the Alt is not capable of meeting demand. IE a dead alt. Check the on line dealers for a Alt. You can get a much better value then what most chain autopart stores try to pass off as a rebuild. They also can be very reasonable. nipper
08 Legacy Resonator and other question...
nipper replied to Guinness133's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAh ok hes talking the snorkus end.
nipper replied to Guinness133's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThats part of the snorkus. There are odd cavities like that to tune the sound of the engine to meet federal noise standards. Thinks of it as a sinus cavity.
nipper replied to Guinness133's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAn exhaust tin can wont do it, and anyone who guarentees you a 20 HP gain out of a box is taking your money. Modern cars are fairly peaked out. They breath effeciently, they last many rouble free miles, and get the best mpg they can for all around performance. There are things you can do for a quicker throttle response (which is NOT a HP gain like most sites say). One is lightened pullies. A high flow cat doesnt work unless you are doing cams etc to take advantage of it. You already have a cold air intake (as do almost any modern car). You can clean it up, and if you never intend to take your car into water of any great depth (most engine damage from sucking in water comes from puddles on paved roads) you can get rid of the snorkus and get a free-er breathing system, The intake air filter sits in the right front fender rather low. The subaru sinus is designed to keep the engine from digesting water. not much more beyond that for a normally asperated subaru. nipper
nipper replied to Guinness133's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDepending upon where you live, modifying the exhaust system is against the law. Some places dont care, others use an inspection mirror to check the exhaust system Generally ricers do this to thier hondas. nipper
nipper replied to Guinness133's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot crazy about your warrenty or passing inspection? Resonators are long gone, you are talking about replacing the muffler. nipper
Anyone seen a rear hatch not open?
nipper replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt also only costs about 25.00 to replace all the handle parts. It's a common issue. If the handle doesnt properly reset it wont open again. nipper
P0304: Issue solved!
nipper replied to 211's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFor now i am going to go with engine being healthy, and hold off on the valve timing. That would have shown up in the vac gauge. Vac gauges are an underrated and oft overlooked tool, but they can tell you a lot of things. On the crankshaft there is a special tooth geared. This is used for the crank sensor, which in turn sends a signal to the ECU to fire the plugs. If that is dmaged, which can happen, it will make for a weak spark. It may be possible that we are assuming the bright spark is correct, and the weak one is the issue. This is a waste spark system, meaning the plugs are fired in pairs. Electricity likes the path of least resistnce, so the weak spark may not be the suspect side. There may be a shoort on the strong spark side (not allowing for the good side to get full voltage). Like i said there is only so much that can be done over the net, and sometimes the need for an on-hands professional is required. nipper
nipper replied to 211's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe ONLY vac gauge readings that matter are the ones at idle for the most part. A video is not needed, just tell me what it is doing Yes you are stubborn. i dont always trust the coil tests as they are not always correct. Have you taken a meter to your plug wires yet? and not ALL shops are crooks and thieves. That really irritates me when someone makes a blanket staement like that. i will hold my tonhue from really sayng what i feel, but so far.... never mind i will just piss people off. If you dont like your shop find another one. Right now your not doing any better for what may be a simple issue that you at your expierience level can not comprehend. nipper
nipper replied to 211's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhrmmmm Did you do a wet and dry compression test. Drys is just what it says. Wet means you squirt some oil in the cylinder and repeat the test and see if the numbers go up. If they do you have bad rings, if they dont (assuming the numbers are low) its valves. The fact that the compresion got extreemly high (too high) means either you did something odd, or there is an timing issue. Subarus NEVER get that high a compression reading, as max is 180-185 for a healthy engine. The good news out of those numbers is that your head gaskets are good. The numbers themselves are even so the compression is balanced. Also there is no shame in throwing in the towel and letting a shop look at it. I am still going with your engine timing being off. Go to www.endwrench.com and look in the archives under engine. Read the section on timing belts. I need to know EXACTLY what the vac gauge is doing and what numbers it is "flucuating" on a healthe engine the needle is fairly smooth, so smooth in fact it is steady. I think the key to this issue is you telling me exactly what that gauge is reading. You said you swapped out coil packs at one point? nipper
4EAT Replacement?, Trans. Alternatives?
A magic elixer vs a replacement tranny, go for the elixer first. It can't make things worse. There is actually a bad internal seal that can be replaced, but you need a really really SMART shop to know what the problem is to do it. good luck. nipper
nipper replied to 211's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIts not the "ignitor" if it was it would be random cylinders. Soobys fire 1-2 and 3-4 together. If it was a bad coil you would have a 1-2 or a 3-4 misfire, not a 1,3 misfire. a 1,3 issue is usually a timing belt issueor a cam issue. nipper
nipper replied to 211's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat are you calling crankshaft bolts and how are you getting to them? Counting teeth means as much as a 3.00 bill in a candy store. You have to check the alignment marks on the cams and crank. Untill you stop freaking out and start properly diagnosing your not going to get any answers. I dont trust any parts but subaru when it comes to the timing belt but thats just me. And change only one thing at a time when trying to diagnose something, otherwise you are digging a deep hole we cant help you out of. Lets do a poor mans compression test. Pull plug wires one at a time, is there any change in the way the engine runs? nipper
Subaru Legacy 2010
nipper replied to bigu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
- P0304: Issue solved!
nipper replied to 211's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think it ihas ju,ped a tooth or two. A compression test or a vac gauge can tell that (the compression test moreso). Then they next question would be why did it jump a tooth? Were all the idlers and tensioner replaced? Is there a bad sprocket? nipper- Subaru Legacy 2010
nipper replied to bigu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi think they are just using the tool and dies from the tribeca to get thier moneys worth out of it. Hopefully the next go round they will start getting back to wagons, or even what they are getting in Oz, which is smaller version of the 2010. nipper- P0304: Issue solved!
nipper replied to 211's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.classictruckshop.com/clubs/earlyburbs/projects/vac/uum.htm- P0304: Issue solved!
nipper replied to 211's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUnburnt gas on two cylinders on the same bank. I would start with a compression check and or a vaume gauge. With it being on cylinders 1 and 3 you can rule out the coil, and its just a longshot to have two bad fuel injectors. Maybe a vac leak on the intake manifold on that side of the engine? When you use a vac gauige, tell us exactly what the needle is reading. Did you use OE parts?- P0304: Issue solved!
nipper replied to 211's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs there a new timing belt tensioner in the car? nipper- Pulling Codes ?
nipper replied to billrigsby's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOBD2 was 1995 and newer. - P0304: Issue solved!
