Everything posted by nipper
Torque Bind, Repair Options, VC Failure Mode
nipper replied to wagnerku's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXVC shows up on turns for the most part, or a thud in the drive line (but not a rythemic thud). Without the binding on the turns showing up, your VC is fine. nipper
rough idle after 2.5 sohc timing belt broke and replaced
nipper replied to jimrichard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYup. Most the time a compression test will show really wierd numbers if the teeth are off. Either you will have very high numbers, very low numbers or one head high one low. It really is a good way to tell if the belt is off, as usually the two banks dont match if they are. nipper
more axle problems
nipper replied to hebrewhammer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXim going wwith a wheel bearing. wheel bearings will do that untill they get really bad and the only thing holding the wheel hub on is the axle nut. AHA! Have you got a stethascope around or a wooden dowel. use that to listen to the bearing via the knuckle. nipper
more axle problems
nipper replied to hebrewhammer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit may make it in reverse but your not going fast enough to hear it. nipper
more axle problems
nipper replied to hebrewhammer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIm wondering if you have the beginings of wheel bearing failure. You really cant eye up driveline alingment well, you need to use a ruler of some kind and fixed points, like the drive belts vs the front bulkhead/radiator. Have you removed the rotors to check them front and back. Have you checked the brake pads and backing plates?? nipper
nipper replied to wagnerku's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSometimes it pays to go to the dealer. Let them look at it since this is an unusually early failure. Maybe subaru will work with you, or it may be something else. It's hard to diagnose sometimes over the net. Have the front end looked over, ball joints etc. Check the carrier bearing. Are you getting binding on tight uturns? nipper
No Start, Couple of Sensor Questions
nipper replied to lostinthe202's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnd thats why Blu got a rebuilt engine at 191,000 miles
nipper replied to lostinthe202's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou wont get a code because the car never started. If you can get codes on cranking you will get a code for almost every sensor there is. Blu does this, and he does it only in the winter when the temp is between 35-45 degrees. he does not do it often. I beleive its a crank sensor, but he never does it so I can trace it. I will most likely replace the crank sensor just because it has 245,000 miles on it. He will not do it at any other time during the year. nipper
hydraulic clutch vs. non
nipper replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHyd clutches have been around as long as hydrualic brakes. They are much simpler to design and install then cables. Mechanical clutches rely on leverage and moment arms to get the forces managable. Hyd clutches do it fairly easily by just varying piston size. They both last about the same time without needing service, though I would recomend a new cable on any car with over 100K on a clutch, since its not a great expense. nipper
HELP! Brat wont come out of 4WD.
If its bind usually just jacking up one wheel will release the bind and allow you to shift. If thats not it its a linkage issue. nipper
more axle problems
nipper replied to hebrewhammer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere are reasons cars are in junkyards, and we all know the tales of bad aftermarket axles. Sometimes it pays just to buy the new part and be done with it. As long as you dont have any frame rust and the wheel bearing is good there is no reason for the car to cause the axle failures. nipper
2009 impreza outback sport low tire pressure
nipper replied to Rice Burner's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere is a major recall (no particular mfg) on tire valve stems not holding air. Granted your car is a bit old for the recall, but I never know how far in advance some suppliers buy thing. Spray each tire stem (with the covers off) with windex and see if they are leaking. There will be bubbles. Otherwise its just one of those teething pains with a new widget. nipper
bleeding abs systems
nipper replied to mountaingoatgruff's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo it sounds like this in a way?
Help with fuel delivery problem 01 Outback H6
nipper replied to subyfreak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe worst thing a 4 cyl pump is going to do is give you a full throttle issue. It should be able to deal with high speed cruise issues. and get you home. nipper
broke timing belt on 99 Forester HELP !!
nipper replied to jimrichard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDepends upon how much damage was done, and how much the pistons were compromised. A dented piston surface can cause a hotspot that will cause ping and possibly future HG issues. It all depends upon the damage, nipper
nipper replied to subyfreak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyay you cant run it like that, but it would tell us if the press reg was good or not. nipper
east coast meets?
mmmmmmmmmmmmm meat mmmmmmmmmmmmm
nipper replied to subyfreak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLook for a universal pump, it may be cheaper and they all flow about the same. Here is another idea. Find your fuel pressure regulator. It will have a vac line on one side a fuel line on the other, with a return to the tank. Choke off the return to the tank with a pair of sie grips and see if the car starts. nipper
nipper replied to subyfreak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNothing is going to fall in the tank, or fall off, just DONT LOOSE THE TINY FASTENERS. They are really tiny. I doubt its a voltage issue, but one side would be hot, one would be ground. You can check which one is which when you open up the covers (I dont know off hand). Is your fuel pump noisey?
nipper replied to subyfreak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYoull need pliers. Everything comes out together. The fuel pump is on the apssenger side of the car. Remove the access plate (dont loose the fasteners). Below that is the fuel pump/sending unit plate. Again dont loose the fasteners. It takes a little gentle feness to wiggle it out of the tank. Would be helpful if you could get a fuel pump pressure gauge on this first. Have you tried removing the gas cap and starting the car? nipper
nipper replied to subyfreak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere isnt really all that much to the fuel delivery system. It can be your fuel pressure regulator is toats, or the fuel pump impeller is shot. nipper
97 gt speedo - believe it or not!!!
nipper replied to johnceggleston's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you keep your transmission yes.
Rear seal leak???
nipper replied to Tiny Clark's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo NOT touch the rear seal, they rarely leak, and are a a PITA to get to sit right if you replace it. It is your seperator plate that is leaking. Also change your PCV valve, that may help slow down the leak. nipper
nipper replied to wagnerku's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe axle issue isnt really a problem with balance. Its a matter of the tolerance being too tight and transmitting engine shake at idle while in drive. It isnt a issue i recall with manuals. There is nothing wrong at all with too much detail, its all data.
Repalce or Repair 2.5l Outback Engine
nipper replied to abeauch's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe very first thing to do is a compression test. We need to see the condition of the rings on the engine. Even with a bad HG we will get good numbers from the other side of the engine. Personally my cutoff for a sooby engine HG is 160,000 miles, i'll go higher if it is the original owner and well maintaned. The fear is blow by. You have rings that have a lot of miles on them. Doing a valve job and even the minor milling for the heads will restore compression to factory specs. The rings may not be able to seal well against this and you may get some oil burning. So the first thing is to see what the compression test numbers would be. nipper
