Everything posted by nipper
lost coolant from motor
nipper replied to eastwestboy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCould be a few things. Since its a 2.2 we will rule out a HG for now. Sis you have the proper freezing protection in the coolant? There have been a few posts on the lists the last week or so with people who got caught off guard by the super bitter cold. When was the last time the water pump was replaced? Freeze out plug? Leaking hose. I would suspect a leaking waterpump. nipper
I finished my Twin Stick Mod!
Ok i thought i was the only one nipper
2006 Legacy Turbo Catastrophic Engine Failure
nipper replied to 2000outback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk that explains the high prices. nipper
Speedometer/transmisison
nipper replied to murphsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes. Get under the car and check the connections to make sure. nipper
Fan Clutch broke water pump?
This sounds alot like a typical over tightened belt. Belts fo wierd things in extreeme cold and may have made things worse. V belts are differnt from flat belts in thier requirements. nipper
So many fuel lines. Why?
i never heard ot the glass requirement before. I know in NYS its not anywhere in the inspection manual. If your carb came with it or had a glass filter from the factory it would be OK nipper
nipper replied to 2000outback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi was wondering that myself... nipper
And glass filters really arent needed anymore. Fuel is extreemly clean these days. Just replace a standard filter once a year. There are way too many filters in this car. Are you sure they are all filters? nipper
nipper replied to 2000outback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYup. nipper
nipper replied to 2000outback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi did a google on maynooth, and it comes up Ireland. SO the price is not out of line, especially when you conside he needed a turbo too. If he was using 4 liter of oil between changes, it sounds like it is an operator issue,as he should have taken the car into someplace to find the cause od the oil consumption. nipper
Delayed AWD Engagement
nipper replied to 2000outback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXis this an automatic ?
nipper replied to 2000outback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHe was just unlucky. This happens on bigrig diesel engines too on occasion. What happened is that the bearing failed, and wiped out the oil seal. The oil got sucked into the engine and byrned (and should have made a ton of smoke, doest he ever check his mirrors?). The car sucked all the engine oil and eventually the engine oil light should have come on, which i bet he didnt see. On a Big Rig, since they burn oil to run, they get a run away engine they cant shut off and have to wait for the engine to self detruct usually (run out of oil). Did he do regular oil changes? nipper
nipper replied to murphsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX99 doesnt have a cable (at least thats what my books tell me) Merry Christmas nipper
nipper replied to murphsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhow long you own the car? The dead spedo tells me that you have lost both VSS sesnors, which are in the transmission, That will make for no AWD and wierd shifting. nipper
nipper replied to murphsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhrmm any CEL or ABS lights on the dash. Any flashing lights on startup? Did you hit anything or run over anything?
nipper replied to murphsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhat year? nipper
4EAT Paddle shifters
i love grand experiments
techncially it may work. In the real world i dont know. Differnt torque curves, stall speeds, power curves. Will be interesting to find out. nipper
P0468 Purge Flow Sensor Circuit High Input
nipper replied to voodstoc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPS how many miles on the car?
nipper replied to voodstoc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPurge flow sensor has malfunctioned. Can you go to another autozone or someplace else that reads codes for free? nipper
cold weather brake issues
nipper replied to johnceggleston's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat they both said. nipper
Auto Trans. Diagnosis Help needed.
Sounds like you have a broken CV joint internally. Its a common thing to happen, you just need a new axle. nipper
chains
nipper replied to elizaspessard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHAHAHAHAHAHAHAHA nipper
Vibration when turning
nipper replied to etc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNO HINTS! thats cheating hehehehe
chains
nipper replied to elizaspessard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSUbaru says front wheels only. nipper
