Everything posted by nipper
99 legacy (H4 2.2L) cranking but not starting
nipper replied to dlove's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat qualifies as goofy nipper
2009 Forester Hill Holder
nipper replied to Fritz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo now its done electronically. It operates differntly then the traditional hill holder. nipper
Great Subaru 360 video!
And i didnt really see a brake inspection.
96 Leg OB overfilled transmission damaged?
nipper replied to paulivan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi was trying to be nice, but OK i will second that nipper
Horn isn't working and the headlight day runners...
nipper replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHOrn is probably as simple as a dead horn. The car is old enough. Daytime runing lights can be the jhand brake switch. nipper
nipper replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXso we are going to have the guess the year of this car? hrmmmmmmmmm
nipper replied to paulivan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX1 GALLON! I think you may get the award for most overfilled. NOrmally i would say no, but i've never seen one so over filled and be driveable. Usually it screws up the shifting. I think you would be ok, as Auto Trannies die slow deaths and will give you warnings. If your not slipping when the car shifts your fine. nipper
Timing belt replacement cost
nipper replied to Pgh_Scoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBlue was 650 last time i think, but that included everything. nipper
'97 Impreza runs rough, sputters out
nipper replied to Bmm001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI guess i got my answer. Yes. They arent made to last forever, even subaru recomends replacing them after 105,000 miles on the 2.5, and i recomend it every other timing belt change on the 60,000 mile interval. They usually fail relativly quickly after a t-belt change, as they dont like being disturbed as they get older (who does). Miss rough stalling after running perfectly fine is typical timing belt junp sympton. Especially after being shut off and running fine. nipper
nipper replied to Bmm001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdoes that etc part include the tensioner and idler? nipper
Interesting .. subaru 360 going through a Japanese insepction.
painting block
Except for the most part where they fly tend to be a lot colder then surface temps. I've seen painted corvair blocks, vegas, and VW blocks. Engines used to be apinted to protect them from rust. Its not really needed on aluminum engines. nipper
voltage regulator
nipper replied to murphsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes.
Looking for a CTS and CPS test procedure
nipper replied to wavekayaker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell its not that hard. For the CPS you need an analog volt meter. As the engine cranks, the needle will pulse. It wil make an AC signal. Check your cam position sensor too. The CTS is a thermistor. The colder it is the higher the resistance. Also check the reference voltage at the harness, it should be 5 volrs with the key on. nipper
CEL - advanced class
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi still may put it on the to do list. even with 23.00 a fill up thats 14 mpog was getting painful.
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell my gas mileage is back up, yay, and everything is fine. i will keep an eye on it. I cross my fingers because i cant afford a cat (though i actually like working on modern exhaust systems). nipper
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFINALLY After a month i ran the scan gauge for the heck of it, saw the car was staying in closed loop much longer, scanned the codes, and finally got a reset. Now for some odd reason, when i take my foot off the gas pedal, for a second or so the car will go open loop then back to closed loop, so i may still have an issue. It's not flipping back and forth constintly like it was. I will warch to see what my next tank of gas does to see if my mileage came up or not. nipper
2006 Legacy Turbo Catastrophic Engine Failure
nipper replied to 2000outback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThats quite possible. nipper
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXengine coolant temp is fine. Engine timing is fine 2 and 4 are the only ones left really, and i dont think its 4, but its supposed to hit 60 here tomorrow so i may get a chance to look under the car and find out. nipper
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy cat doesnt rattle. In all my years ive never seen a O2 sensor respond INSTANTLY to throttle by going closed/open loop, hence the damage theory. Also it got tripped over bad road which leads me to belive its a physical fault, not to mention it refuses to reset. Also the 30% drop in gas mileage. nipper
P0468 Purge Flow Sensor Circuit High Input
nipper replied to voodstoc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell we do have all the codes nipper
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi was thinking about this, as the weather hasnt allowed me to get under the car. i am thinking its just what you said, the heater is damaged. Thats the only thing i can think of with instant open/closed loop response. My gas mileag is crap, so thats telling me its not the cat. Also if it was a cat i wouldnt get instant closed/open loop response whaen teh car is cold at 15 degrees. I see that OE o2 sensor for blu is on sale at less then 100 bucks. i think i am going to order it on blind faith and my best guesstimate. nipper
nipper replied to dlove's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTypical of a goofy electronic issue. nipper
nipper replied to dlove's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEngine Temp Sensor or crank position sensor. It wont show up on a scan as the scan only shows errors on a started engine, not won that wont start. Thats where i would look first. Do you have spark? nipper
I finished my Twin Stick Mod!
Oh OK When i had my 87 i used to use 4wd low in stop and go traffic all the time (really saved my clucth leg as the car would crawl). Wish i had thought about the 2wd low then. nipper
