25
Everything posted by nipper
On The AA lift, i had to use camber bolts on all 4 wheels, it solved the alignment issue. nipper
The clunky shifting is old fluid. The TB you are exhibiting is most likely from a failed Duty C solenoid, which has to be fixed (and change the fluid at the same time). I am guessing at that since the age of the car seems right for it. The 16 flashes mean the last time the car was used, there was an electrical fault in the transmission. Its to get your attention. How does it feel when you back out of a parking space or making a tight turn? nipper
Question?
nipper replied to elmwood22's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I wouldnt. Too many incidents of drive line vibration from cheap drive axles. nipper -
Question?
If your strapped for cash and doing it yourself, replace the boot. Take the cv joint apart, clean it, and use a sooby boot (they are thicker then aftermarket). If you can afford it, get an MWE axle. The first option is only going to cost you time and the boot. The true factor is how long do you think the boot was like that? nipper -
I got my AA kit late, but it was very beefy. The customer support is baically calling the person who made the kit. They thought i had a manual, so they didnt send two braces. When i called them, they instantly sent me the extra braces. The kid who makes the kits is really cool to talk to , as he has a lifted sooby himself. i think you all are beating up on AA unfairly. We are talking about something where less then 10 kits are made a year, because less then ten people ask for them. If you think you can run a business on 10 orders a year go right ahead. They do have a primary business that pays the bills and saleries. i will get off my m-16 tripod now. nipper
I just did a 3x drain and fill in the auto tranny. I only bought 11 qts. So i imagine i am still qt shy. Yes i could use the dipstick to measure it, but its busticated. My method of refilling the empty qt containers lets just say was less then perfect. may the person who designed that dipstick be forced to work on designing the next chevy vega for eternity. nipper
What is the "right amount" Also what is the ambiant air temperiture? Always give us the exact data points when we are trying to help diagnose an issue. What you may think is the "right amount" may be an important clue to the problem. Also did you read the pressures after 10 minutes of the AC running for it to normalize? We need both the high pressure and low pressure numbers. nipper
Low pressure can cause a short engagement. No pressure can cause no engagement. Overly high pressure can cause no engagement. The days of AC being simple are long gone. You can pull your hair out for a few days and maybe never get it right, or just have a shop do it and be done with it. If there is no pressure, the clutch will not engage. Also AC can seriously hurt you and the enviorment if you dont know what your doing. What your looking for is akin to your car not starting because its out of gas, so therefor you must need a new engine. Either way 1st step on any ac issue is to check the pressures. Its rare for there to be an electrical issue on the AC systems of these cars. KISS Keep it simple nipper
On my 1987 i had the driveshaft rebuilt. They Used U joints from a ford ranger that were servicable and could be lubricated. Dont go with a one peice driveshaft. You could possibly shake the car apart. nipper
i posted lots of information on this kit (all good). http://www.ultimatesubaru.org/forum/showthread.php?t=79293&highlight=Allied+nipper nipper
If you are still loosing it after checking the above, its possible you are burning it. Your Master Cylinder is old enou to be leaking. You have a giant vacume canister on one side of the master cylinder connected to the engine. If its leaking, the brake fluid can get sucked into the engine. Check the inside of the booster hose, does it smell like brake fluid? nipper
