25
Everything posted by nipper
If the system is in one peice, odds are it has a leak and needs refridgerant. Some things are best left to the pros (pay once do it once). There are other things it can be, but subaru AC systems are fairly resiliant. Loss of coolant is usually the cause for them not runing. Any idea how long its been not working? nipper
Differntials either whine (gets louder as you go faster) or thunk when changing direction. (from drive to reverse). You need to check the lube level in the siff. You also need to check the universals in the driveshaft, and the carrier bearing. Do you feel any vibrations that come and go at highway speed? A bad strut is also a possbaility. INspect all the rubber bushings also. How are the exhuats hangers? BTW noises are hard to diagnose over the net, so best we can do is guide you nipper
Hypermiling
nipper replied to FSRBIKER's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Actually neutral does better on paper, but its such a small amount, you would probably wear out the shifter cable before you saw any real gain. nipper -
Scan Gauge II
nipper replied to rlsimpso's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Not easily. OBDI was no standardized, so a mfg would have to make one for each and every car model. You may be able to find an older trip computer that will work with obdI on ebay. An easy way to do it would be to add a vacume gauge to the car. That was the old fasioned way of doing it with cars. The higher the needle, the better the gas mileage. nipper -
My latest car 1973 GSR
nipper replied to kiwi subbie's topic in Historic Subaru Forum: 50's thru 70's
sweeet i would keep it yellow. -
4eat question
nipper replied to pamike's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
There is an interlock that keeps the car from engaging park over a specific speed. Its made for "incindents" and Accidental" park engagement. i'm sure there wil be other ways the car wont survive the relationship. nipper -
But its dirty ....
There is an easy solution. Stick a note on the spare tire in sealed plastic bag facing up that says in big letters "put this fuse in the FWD holder under the hood" and have a spare fuse in it. If she can change a flat, she will undestand that. I am impressed that she can. And if someone else does, they will se the note. nipper
Dash light out
nipper replied to starsea's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
They are old. If it was a short they would all be out and you would smell the magic smoke. The dash comes out easily, you'll find maybe more then one bulb out. The PRND321 bulb is easy to see, but a bit of a bear to get out. nipper -
Subaru and Nissan's share quite a few parts. The fact that nissan got the contract to rebuild subaru trannies doesnt mean anything. My engine bought from subaru was rebuilt by a (forget the name) over the road HD diesel truck mfg, yet i dont claim it to be a semi nipper
