Everything posted by nipper
Coming to Austrailia
Dont forget your gravity boots, we dont want you falling off the planet nipper
Overheating with A/C on
Physically inspect the radiator, and check the electrical charging system. The Radiator is probably clogged, or decrepid. If you look between the ac evaparotor and the radiator, the cooling fins may be all gone. You are due for a radiator. nipper
Blown Head Gasket or just nothing to worry about?
nipper replied to rverdoold's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRun out of fluid, over heat the oil, warp the cylinder heads, blow the radiator, bake the engine and ruin the block. Nothing too bad
Brat back together!! - It's REALLY REALLY alive!!!!!! - No, I MEAN it this time :)
And the automatic climate control, which works well till it breaks, then it doesnt work at all. nipper
Help on Power Window Problem 01 Legacy
nipper replied to RedRum's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe switch is easily disassembled and cleaned. JUst be care fule and watch for little parts. nipper
p0446
nipper replied to charm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell that would be the evap system. The evap control valve is malfunctioining. nipper
Water Pump Advice wanted...
nipper replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXChange the water pump with the timing belt at 105K. Your pump has a lot of life left in it. For a 60K interval, thats every other timing belt you replace the pump. The pump may be done at 105K, but it wont make it to 210K (yes someone out there alwyas has one with a gazillion miles on it). Even subaru suggests it. nipper
breke problem, 97 legacy!!!
nipper replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOK lets back up. What you need to do is look at the wheel you have not touched. Make sure everything looks the same. Have you gotten yourself a haynes manual yet? nipper
2002 WRX Knocking Sound?
nipper replied to carfreak85's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcan you reproduce the knock at will? Is it a deep hollow knock, or a tinny kind of knock? USe a screw driver or wooden dowel as a stethoscope to try to trace the knock sound. nipper
Its always possible to have the disty off by a tooth. nipper
A Noise on warm up and accel
nipper replied to Yellow_Car's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes its still a heat shield. Check them with the car stone cold. nipper
nipper replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXParking brake shoes. nipper
Camper/Trailer
nipper replied to Subaru_Aloo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDateline wyoming..... i wish i took a pic, but i did not have a fisheye lense. A dualie Pickup with a fifth wheel, pulling a full size fifth wheel camper/trailer, and that was pulling a large enough boat that the boat trailer had dual axles. nipper
Window wont go up, uh oh!
nipper replied to Dickensheets's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlways start off with the simple possabilities first. nipper
Wheel Shimmy
nipper replied to Audiophobe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes they can, but rule out the simple stuff first, like a warped rotor, or high/hard spots. nipper
Books about the 4eat????
nipper replied to xt61991's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGive me the year and send me a blank dvd (-) and i can send you factory manuals nipper
Big time hesitation in Outback
nipper replied to Rusty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWe are beyond codes here, its time for tried and true 1930's technlogy. Put a fuel pressure gauge on the car and lets rule that out. Get a vacum gauge and tell us what it is reading. My feeling is that the ignition is breaking up at high load. The ignition system is under a higher load in 5th gear, then in fourth, even though the engine rpm may be the same. I cant scroll back as i'm typing, but lets make sure some things are ruled out that can affect igintion. Knock sensor (though that will affect performance not make a miss) OE ignition wires OE recomended spark plugs. I am getting the feeling it may be the coil pack, but i can't tell without an oscilliscope. It sounds like a classic coil failure to me. It can drive you batty. nipper
nipper replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat can be a seized caliper, the caliper shold easily slide on the pins when the pads are out. nipper
05' Impreza knocking & humming issues - help?
nipper replied to Scuba Scotty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf your CV boots arent torn, then at this mileage, the CV joints are fine. nipper
nipper replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot to the point of smoking. nipper
Wheel Shimmy
nipper replied to Audiophobe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would say rotors. Don't buy cheap chineese rotors. They also are made of questionable materials. Also at that high mileage, your wheel bearings are probably reacing the end of thier service life. nipper
nipper replied to Scuba Scotty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow are the cv joints. Are there any dimples in the tires. If you rotate the tires on the left side of the car does the sound move? WHat happens when you push down hard on the bumper? nipper
nipper replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt is time to go to the store and get the haynes manual. there arent many things that can go wrong on a brake job to have problems. nipper
nipper replied to xt61991's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgoogle "endwrench transmission" sometimes the direct link on endwrench doesnt work. There will be lots of information there. nipper
nipper replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe calpiers may be frozen. Did you lubricate the sliders? nipper
