nipper
Everything posted by nipper
  1. Oil Filter. I just bought a mobile 1 oil filter for Blu M1-108. It is so small i had to go back to the sotre and make sure i had the right one (bought it last week). Anyone ever have an issue runing one of these. i know its MObile 1 but i just dont like it when filters get tiny and reduce my oil capacity at the same time. i am used to trying to get a bigger oil filter to fit, not a smaller one. nipper
  2. If the engine is going to be pulled to do this, I would look into replacing the noisey pistons. Subaru has replacements that correct this. nipper
  3. replace the pistons ..there are two that get replaced. we are getting into rebuilt engine territory here. Look at CCR and start doing the math. nipper
  4. something tastefully late ? Though i am thinking of a run up to Mt Washington before the summer driving season hits and i cant afford gas anymore. nipper
  5. I think its just subaru hedging thier bets to meet emission code. Spark plugs are replacable and allowed to be replaced at what ever interval the mfg states. nipper
  6. No full size spare tire? nipper
  7. Thats assuming a costco membership.... nipper
  8. I wont trust an off brand unless i know who is actually making it, especially from a discount seller. i am just too fearful of to many chineese counterfits. They can put any thing they want to on the can or the label, but with no traceability, there is no way to prove what it actually is. Been burned too many times by chineese counterfits, or just plain junk, that was not what it was supposed to be. nipper
  9. Seriously giove think over about replacing the radiator. This is up to you. Radiators tend to clog when water hits the oil/antifreeze/water mix and make it glue. Sometimes they can be cleaned out, sometimes they cant. Also when the car gets home, clean out the overflow tank. No one ever does. nipper
  10. i tend to do a tuneup every 100,000 miles. i do replace the filters as needed and a pcv valve once a year. nipper
  11. Is that for a day or for invaiding poland? nipper
  12. On many boards its either triple treads, or for the best bang for the buck BFG's T/As. Thats what i run. nipper
  13. That is the MAP sensor. It affects everything from shift points, to compensating for alltitude. It samples both the Manifold vacume and the atmospheric pressure. It's slightly inportant. nipper
  14. As long as the engine wasnt cooked, it will be fine. Do change the oil when it gets repaired, aslo a new T stat and cap. nipper
  15. Relying on a cell phone is not the greates thing to do, you should have a CB in the car. I have been many places where the cell phone is useless. If your car is running whats the need for the generator, that just adds alot of wight. A first aid kit as well. I have a floding tree saw in the car, flares, a hand help crank up flashilight, battery flash light and a tow strap. I need a new first aid kit. I go wheeling with a paper map as well as the GPS on the lap top. nipper
  16. Better question, want to risk a 3000-5000 engine over 6 dollars? nipper
  17. ON non synthetics, studies have shown after a few thousand miles almost all oil ends up as 30 weight. If you mix 10w30 and 5w30 evenly you will get 7.5w30 (same for the other numbers). You arent going to hurt anything by mixing oil weights. i would however recomend staying within the same brand, or at leats type. Every oil compnay has its own special cocktail of additives. Again your not going to hurt anything, but why risk it. nipper PS check the oil pump to make sure its in spec, it may be on the high end of tolerances and need rebuilding.
  18. Now its time to look at the sealing surface. Take out a straight edge and make sure its flat. Next snug the bolts by hand, then using a star pattern, tighten them one turn at a time. Get out a torque wrench and tighten them to the proper torque, one at a time, one turn at a time. nipper
  19. Belden is a cheap brand, They would always fail lab tests at a very early point in time. nipper
  20. get a cheap meter at radio shack. Untill then we cant really help you. nipper
  21. is there voltage at the socket itself? You may have a bad ground, so check both the hot and the ground with a meter. I hate to ask the obvious, but how are the bulbs. nipper
  22. Or move to NJ where you have to make rights to go left :-p nipper
  23. http://www.aircondition.com/tech/questions/82/ thats how Also there are only one of two ways an AC system gets clogged. One is from a compressor that self destructs, the other is from desicant. The firts one is obvious to rule out.
  24. Sorry i get them confused in my head sometimes. With a leak the system reaches an equilibrium. Remeber 0 psig (gauge) is actually 29psia (absolute), thats what your barometer reads. So even though the system is at equilibrium with the atomosphere (Zero), there is still most likely some refrigerent trapped in the system (hopefully). Also when they pull down the system, they can tell if you will need a new drier. And they arent usually expensive, and easy enough to install. And please dont go to midas. They already are trying to take you by saying they are going to evacuate the system for you. I bet there is almost nothing left in the system to evacuate. nipper
  25. Sadly you dont know one till you find one At least this is a fairly easy thing to rectify. nipper
