Everything posted by nipper
Center Diff Lock Q
nipper replied to Jibs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFrom the SAE automotive handbook 4th edition pg 384: "The purpose of the piston, connecting rod, and crankshaft assembly in the reciprocating-piston engine is to trnasform the gas forces generated during combustion within the working cylinder into a piston stroke, which the crankshaft then converts into useful torque at the power-output end of the engine." And for the more geeky "The gas force (Fg) which acts on the piston can be subdivided into the side forces (Fn)applied by the piston to the cylinder wall and supported by it, and the connecting rod force (Fs). The connecting rod force, in turn, causes the tangential forces (Ft) to be applied at the crankshaft journal. This force together with the crank radius generates the shaft torque and the radius force (Fr)." Then it goes into a formula which i have no idea on how to reproduce on a keyboard, but it results in vibration calculations. and wikipedia is cheatting, and not allways correct. nipper
Center Diff Lock Q
nipper replied to Jibs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI noticed it out in the woods, so did njdrsubaru... whatever, argue with subaru. nipper
drivetrain and U-joint question
nipper replied to babyfacefitz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs simple as a driveshft looks, its really hads a few critcal tolerances. The alingment and the balance of the universal joints and the shaft are critical. That 35.00 is the part, but the installation should be done by a dirveshaft shop, so add a few bucks for that. Once again, its not the part itself that is expensive, it's the labor. And the skill set. nipper
Big time hesitation in Outback
nipper replied to Rusty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAny strange noises from the front of the engine, like a bad timing belt tensioner? nipper
2003 Forester A/C evaporator removal
nipper replied to kamrows's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs long as the system has not been opened to the air for any length of time, you dont need a reciever/drier. The desicant tends to discentegrate after its been exposed to refrigerant, then air. If it loks like this may take you two days, cover the ends of the ac lines with baggies then zip tie them sealed. Its not a big deal if you need one. Go with a used condenser. Its rare for them to leak. nipper
Center Diff Lock Q
nipper replied to Jibs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXever fix the tranny (or is that one of the goodies)? So shes just a planter in the driveway then, or still on all four tires. One of the few cars i have never seen on cinderblocks, a subaru. nipper
Center Diff Lock Q
nipper replied to Jibs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSAE calls it torque, all the automovie engineering design texts (at college level) call it a torque split. So i call it torque nipper
Center Diff Lock Q
- Baja Dirt Bike Rack
nipper replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXone word... trailer. nipper- NE Pine Barrens NJ Meet *** SAT April 12th ***
Thats where we all were nipper- Second opinion: "new rack not centered"
nipper replied to dhewitt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsooooooooooooo is the cruise control switch on top of the steering wheel now? nipper- Second opinion: "new rack not centered"
nipper replied to dhewitt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRemember how i said nothing is impossible as long as you have thumbs? I just went through the FSM, and i cant picture a way that he can do this. Maybe i'm not stupid enough, but the only way for him to really screw this up is to have one tie rod turned all the way out, and the other all the way in. Maybe he tried to do this without removing and centering the steering wheel. It is allowable to remove the wheel and center it, sometimes it needs to be done. Thats why they are attached with a nut. nipper- Second opinion: "new rack not centered"
nipper replied to dhewitt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThats impossible the way rack and pinion steering, or any steering works. http://auto.howstuffworks.com/steering2.htm nipper- Center Diff Lock Q
nipper replied to Jibs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXits a 50/50 torque split between the front and rear wheels. http://www.howstuffworks.com/four-wheel-drive.htm nipper- drivetrain and U-joint question
nipper replied to babyfacefitz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAssuimg your never going to get the AWD clutchpack fixed, by a honda. Seriously, youll get better gas mileage. Why have an AWD car if your not going to fix the AWD. That said if your not going to get the AWD fixed, just remove the second half of the drive shaft and be done with it. If you are going to get it fixed, get a used sriveshaft from a junkward. Get the carrier bearing and all if it comes that way. It will just bolt in, very straight forward. nipper- Catalytic Help!
nipper replied to Audiophobe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXer um, no. The #2 wil last much much longer then the front ones since it sees much cleaner exhaust. But on the plus side the down stream #2 can be generic. Just dont buy the cheapest one, as you get what you pay for. nipper- Catalytic Help!
nipper replied to Audiophobe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYOu dont need a cat. YOu need are front O2 sensors. Cats rarely go bad on these cars. Also there is no risk in replacing the semsors, since they should be replaced with a cat anyway. If you do a search here, youll find maybe 2-3% of bad cats actually are the cat, while 98% are the sensors. You have sensors up and down stream from the cats. The one behind it is fine, so its the front, i dont remeber if you have 1 or 2 on a 6. They should be OE. nipper- stereo upgrade - recommendations?
nipper replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi have a pioneer unit. It directly controls the ipod, and has the option of sat radio, and does have an add on blutooth module for my cellular phone. it has little buttons for pre sets, which i really like. i hate hunting for them. i also added a power amp, pioneer of course. nipper- An Eletrical Challenge. going crazy
its been ages since i looked at one of these, but isnt there like a illumination amplifier or some such thing that works the lights? nipper- NE Pine Barrens NJ Meet *** SAT April 12th ***
Tom you have a PM- Mr Subarus next 6 cylinder
nipper replied to boxerhummfetish's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXpiston engines with common cylinders have been around for a while in various applications. Though i sitll like the traingle one, just think, symetrical all wheel drive with a delta force engine nipper- stereo upgrade - recommendations?
nipper replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWow, its safer to talk motor oil, politics or tires . Go to an electronics store and start there. Look feel touch play with the units to see what you like. then make a list and ask us again for the record, i like pioneer and sony, and hate one knob does everything units. nipper- Big time hesitation in Outback
nipper replied to Rusty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXpossible Knock sensor. Get the codes read from autozine or someone, and lets see what comes up. nipper- Better gas mileage?
nipper replied to jerryjetman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFuel injection has made up for a mulititude of sins. nipper- "exploding" moonroof-03 LL Bean
nipper replied to michaelbteam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThats what i was wondering. Of course its possible that the sun roof is not considered a saftey glass item, and wouldnt be covered. nipper - Baja Dirt Bike Rack
