25
Everything posted by nipper
Well it depends on how cheap the AWD system is. Ones without ciscous couplings or clutch packs can leave you with one wheel drive. With clutch packs and viscous couplings you get 2wd (one each axle). You get a poor mans limited slip by applying light brake pressure to the rear wheels (parking brake) or all 4 (brake pedal). This puts drag on the spinning wheel and transfers that torque to the non spinning wheel. Viscous LSD's are really poor replacements for good old fashioned mechanical LSD or Posi rears. nipper
i really need to let you guys do the shopping for me. Around here a tranny used with a warrenty starts at 400. nipper
From the automotive design point of view (My field) anytime we can replace a mechanical switch with a chip, its a cost savings. Not only in up front costs, but in warrenty costs. Switches are good in fixed positions, but when they get shocked from door slams, they usally get damaged over the life of the car. The test cycles are results of lab conditions. I used to test micro switches. Also making chips to whats required for the automobile really isnt that special anymore nor expensive anymore. nipper
Why remove emission controls if they are working? Its not like the old days where you just ripped the stuff off and gained instant horsepower. (unles you get an aftermarket carb ) For oil leaks, take the car to a do it yourself car wash and wash the engine using a degreaser. The usual suspects are main seal, valve cover gasket, cam seals (if it has a timing belt), oil pump, and water pump, depending upon the make-up of the muck. nipper
i want to go part shopping with you if you can get all that for less then 200.00. The tranny alone is more then that i would think. nipper
Really easy, 1st you sell the car, then you go and buy one with AWD. Anything else requires alot of $$ in parts. nipper
Nothing works on ice unless you have studded snow tires, then everything works. It really depends what you want to do with the vehical. Manual Dual range 4wd is cheaper and simpler to produce then an AWD system. Either system is good for snow. If you have snow mixed with non snow surfaces, (especially on curves) you want AWD. nipper
"Idle high (1600) and wont come down...all of a sudden she drops to 750 but is stumbling...3 seconds later back up to 1600 and smooth...5 seconds later to a stumbling 750...and she repeats that cycle over and over" Thats what vacume lines have to do with anything. Time to take out the compression gauge and see whats going on. ANy bubbles in the coolant? there should be lots of them if its a bad HG again Give us some history on this engine. Did it ever over heat, if so how hot and how often. nipper
heaps of oil in the air filter cover on 1400
nipper replied to kiwi subbie's topic in Historic Subaru Forum: 50's thru 70's
Your in upside down land You may have stuck rings from the car sitting. nipper -
Wooooooooooooooo i love how they leave out little details. Did they flush out the entire fuel system after replacing the fuel pump? You need to write subaru in detail, as that is whats required by the lemon law. The dealer doesnt want to fix the car. if it was my shop, I would give the car to a mecghanic to drive to and from work for a week with a scantool attached. nipper
anything is possible with time, a torch, and money. nipper
Pet peeve time.... its a holiday weekend here in the US. You may not get responses from people who know how to answer till monday. Responses tend to be a little slow on weekends as it is. i read USMB when not at home, but dont always respond till i get home. Now for me, i wouldnt pay anything for one, i would expect a free one to be in my driveway nipper
ah hes aussie. You might as well take a compression test and see how badly worn the eingine is. nipper -
Thanks, its been years since i touched one of these things. nipper -
http://www.misterfixit.com/blow-by.htm Follow one ot the larger diameter hoses back from the side of the air cleaner to the PCV valve. It is a small cylinder with a hex head. It unscrews. nipper -
Replace the PCV valve. If you have a lot of blow-by (from worn rings) not much you can do about it. nipper
