Everything posted by nipper
overdrive lock up
nipper replied to supergn6's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXits winter, everyones gas milage takes a big dip. Between the longer warm up period and the winter blends of gas, you have to ride it out. Even without winter blends and the tranny delayed shift, ever since man has made internal combustionengines, cold engines use more fuel till they warm up. Fuel injection has helped, but its still just one of those facts of life, like death taxes and rust. nipper
Door Seal Questions...
nipper replied to 1995SubaruImpreza's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMake sure the HVAC drain is clear. Also check all the body drains and make sure they are clear. nipper
nipper replied to 1995SubaruImpreza's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you have a sunroof? nipper
Isopropyl Dry Gas AND Gas With Ethonal?
nipper replied to SubeeTed's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcorrect. nipper
Replace or Repair?
nipper replied to WoodsWagon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you have any idea why you have burnt valves? nipper
overdrive lock up
nipper replied to supergn6's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXits a thermisotr in the tranny so that wont work. Also it aids in the engine warming up faster for emissions. All cars do it so just something to adapt to. nipper
Impreza Legacy AC operation in cold weather??? Pressures?
nipper replied to SUBARU3's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt was probably too cold for the AC to come on. nipper
Burning smell but only when reversing...
nipper replied to dotname's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck for oil leaks and greas on the exhaust system. When you back up you drive over your own blue cloud. nipper
nipper replied to SUBARU3's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat was the temperiture outside. Usually (some are higher some are lower) below 35 they dont run, as the air is do dry that there is no humidity to remove. nipper
Cold weather brake problems
nipper replied to OswaldtheBold's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThats what im having. SO question is, what do we do about it ? nipper
Ok, try not to Cringe.....
nipper replied to NuclearBacon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell just make sure you use the proper loctite. get the wrong color and it will never come off. nipper
Feels like I'm in a boat
nipper replied to DiscoStu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXrepeat after me .. KISS K(eep) I(t) S(imple) S(tupid) its a good thing to learn (didnt mean to call you stupid but thats how the acronym works) nipper
SVX Don't Stop
nipper replied to ecky's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA bad Booster will make the pedal incredibbly hard and increase braking force, and stopping distance. You have to rule out the booster before you blame the master cylinder. From having both go bad, ild rather have the booster fail then the MC. The MC can be goofy, from intermittent no pedal, to a normal pedal and nothing happens, to pedal to the floor. a Booster will be fairly consistant. nipper
2.5L DOHC Head Gasket Failure *PICS*
nipper replied to WAWalker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe aluminum in the block is weaker then the bolts, so you have to work awfully hard to stretch them, so you dont need to replace them. If you want to, DO NOT buy bolts off ebay. There is a lot of counterfit bolts out there that don't meet specs (thank you china). Also you have to remeber that there is a weird torquing pattern for the heads from subaru. If thats not followed that will give problems. nipper
benefits of manual transmission?
nipper replied to p3pppx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXless people want to borrow your car nipper
2002 Outback Brakes - not working when cold
nipper replied to srs_49's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXim wondering if there is some condensation freezing in the booster due to a bad check valve. at 202,000 miles i wouldnt begrudge my car a check valve failure. nipper
nipper replied to srs_49's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhen in doubt, start cheap. Go for the valve first. nipper
Speedometer Calibration
nipper replied to Slegacy96's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe wire that comes out the back of the gauge cluster. Any wire with a connector on it is a pigtail. nipper
found performance control modules for 90 legacy
nipper replied to A DOG's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's a higher tech sham then whats on ebay. though i am surprised the Summit is carrying it. nipper
Inline Subaru 4 valve DOHC head
"This one-of-a-kind Model A uses a pair of Subaru 4-valve twin cam heads welded together. The engine makes almost 300 hp and is in Doug Eyres’ 831 roadster." Granted it doesnt say wrx. nipper
nipper replied to Slegacy96's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOh ok so your doing exactly what i attmepted to do. Let me know how it works with the pigtail. Otherwise the gauges just plug right in. nipper
nipper replied to srs_49's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt must be contagous. Usually i use the remote starter to warm the car then take off. Today i was too far from the car to do that at my freinds house. It was 22 outside. I went to make a 3 pt turn, and Blu's (97 obw 202K)brake pedal was hard as a rock and took two (human) feet to stop. AFter i backed up, it was fine. I'll have to see if it does it again nipper
help. PHANTOM LEAK
nipper replied to blatant's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXReplace the cap with OE and watch things. nipper
nipper replied to Slegacy96's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcare to share a pic of his gauges? I am curious nipper
What Is Happening?
nipper replied to BIGBLUE1212's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf its cracked it has to be replaced. Being cracked will affect its function, not enough to throw a code, but enough to affect performance. nipper
