25
Everything posted by nipper
no. Newer TCU's communicate with the ECU to make for softer shifting (playing with the timing etc). The 92 doesnt do that, or at least not the same way. It may also talk to the ABS (not sure). if you look at a pre 95 diagram to a post 95 diagram, in the post the TCU talks to to the MPFI controller. It may not function properly. Also i dont even think you can get it to plug in. I dont think youll hurt anything besides the tcu by trying. Also your tranny may not be beefy enough for the extra torque load. nipper
Overheating '88 Justy help needed
nipper replied to painterdave's topic in Old Gen.: 80's GL/DL/XT/Loyales...
How about an aftermarket electric fan? nipper -
I usually wait for a reason. Wires made today can go 50 -100K miles without any problem. The first sign that its time is some ignition noise in the radio, or a slightly rough idle in the morning. If I'm replacing plugs, I replace wires. I dont go by soobies intervals for plugs as they seem to be too short. nipper
the mileage wouldnt be unusual for bushings to go bad. Get under the car and physically inspect the bushings. It will be fairly obvious (if you can see them) if they are dried out and cracked. a local shop is just as good as anyone for this. If its bushings, then you will be wise to get an alignment too. I would avoid midas (hate muffler shops) but have some respect for goodyear and firestone stores when it comes to suspension work. nipper
well look in and see if it has an interior If your going with the 2.2L the only thing to look out for is torque bind. Make sure all the tires match, and drive the car in a tight circle slowly. It should move smoothly and not jerk or grab. Check the color of the tranny fluid. Thats about it (and this goes for all subarus with AWD). nipper
Folks, remember gritle has very little knowledge about cars, so please explain what you are saying. Gritle at the milegae on your car, a worn clutch is not unreasonable. http://www.edmunds.com/ownership/techcenter/articles/43837/article.html will explain clutch free play. The cap should just unscrew. The car does not have to be warm. nipper
thats ok, the USMB site is being frustrating lately. If you dont get aproved quickly let me know ill post it, as i am on that board. nipper
