25
Everything posted by nipper
it may look like it shares a block, but to be a diesel there is so much beefing up that is needed it needs its own sepcific block nipper
1 - The subaru is biased to the front of the car. The rear wheel drive on the manual comes in when there is a differnce between the front and rear axle speed. The fact that the rear wheel was spinning indicates it was working, and that you were good and stuck (see previous comment on open diffs). In the manual unless you brake something the failure mode is the the AWD system fuses (automatic is a differnt story). 2 - Double check the code. Like said before front o2 sensor usually fixes the problem and should be OE. 3 - Its possible you broke a sway bar, blew a strut, or the busings quit. Also check to make sure that the rack is tight. nipper
I'm not sure what you are saying. Is your no start condition meaning you have no crank? If the car is not fully in park the engine will not crank, try neutral instead? 505 is the idle air motor. a bad or non responsive IAC should not keep the car from starting. I'm not sure what you are calling the accumilator. Usually an older cars shifter is easier due to slop in the cable linkage. I bet your cable is bad. And i dont quite understand the last line, do you mean the gear shift release button? nipper
i got 4200 for my 98 legacy L. Recooperation is still going on. My hips are staying in place (enough so that the chiro only sees me once or twice a week) finally thats a HUGE thing. Still in pain, have sadly perm injuries. I am pigheaded so i will do my best to adjust to them and learn to live with them. Sadly I have applied for SSI disabilty (lawyer says he thinks i got it), and my car insurance company is jerking me around by not sending loss of income checks. The personal injury lawsuit is starting to windup, but sadly not alot of money there to be had. nipper
spare key
nipper replied to legacyak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Go to the dealer with your title and reggi, and they will make you TWO keys. nipper -
Tachometer sticking when cold
nipper replied to mikeshoup's topic in Old Gen.: 80's GL/DL/XT/Loyales...
in all honesty i don't remember, its been a while ....... anyone? -
See if you can get one from a junkyard, it doesnt have to work. Take it apart and see how it works, then decide if you can tackle the problem. And i agree about the tpae on the CEL, it can do more harm then good. nipper -
SVX Lovers
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Click on the link, its all descirbed in there, the design and inception of the car. nipper -
SVX Lovers
HETHAN!!!! BE BANNED TO THE PLYMOUTH LIST! (hehehehehe) nipper -
i looked through 20 pages of posts anf found only three people with the switch. Two of witch. had failed awd systems (ill look more as i get bored). i find it interesting only three people have the switch on the list (i searched under "switch") Andyjo was one, but couldnt tell which came first the chicken or the egg. I'm at the point where i dont care anymore. I just want people to know that if they screw up its a 1000.00 repair. I may put this on my "topics i dont respond to list" along with "synthetic oil" as they seem to get hostile after a while. nipper
