25
Everything posted by nipper
OK when the fuse is in you are telling the TCU to hold the Duty C open. This leads to a burned out solenoid followed by a 1000.00 repair. So any increase in mpg is lost by that repair bill. You can not compare what VW does or Mercedes or honda with Subaru, They all use differnt systems. i find these posts tiring, do a search its been covered many many many many many times. nipper
Have you checked to see if the bulb is working. The bulb circuit is from the ABS controller. Have they checked to make sure its getting power. It can be as simple as one of the power relays are burned out. email me before 9am tomorrow at nipper.dawg@gmail .com and ill mail you a witrining diagram for a subaru that will give you an idea how its set up. nipper
You can also install an auto tranny from another FWD subaru. Seems all the issues are with the AWD SVX. The trannies last about 80K in a clip stock, so if its gone to 133K its had tranny work done. Tranny issues are almost guarenteed in an AWD SVX, the FWD should be ok. I havent heard the rotor issue but the issues are a 1200 dollar or more windsheild. The tranny issue is resolved by a cooler AND a filter. The trannies fail because the lockup TC sheds material and clogs up the cooler. The rear wheel bearing issue is done by using legacy wheel bearings (I think thats the fix). The engine aside from having two more cylinders is straight forward subaru. Cars seem to hold up well, thoug realize electrically they are more complicated then a legacy so make sure everything works. There is an SVX board to check out. DO a google search. nipper nipper
everything back then was a death trap. Look at Nash, VW, Mini, and nameless other small cars from that era. But they were cute deathtraps. nipper
Do a hard reset of the ecu. Leave the ecu or battery unplugged for an hour. Next do a clutch test. Try to start the car off from 3rd or 4th gear the car should stall. If it stalls then the clutch is fine. being one of the search nazis , i wouldnt tell you to do a search on it as this is a different question then what we have had in the past. nipper
In all honesty, i dont know. I have yet to replace one personally. I know when I had the middle uni replaced on my car the front half of the driveshaft came out with no problem. The drive shaft shop replaced the universal. From having it posted here in the past, I have heard it can go either way. Right now I have internet issues so I can't give you a firm answer. Call Jamie and ask. nipper
you are over analyzing, now put the tools down and get a beer. If there is a short in the starter solenoid i dont care how you hook it up you will have the same issue. The starter circuit is simple. If your jumping from battery to starter and still having a problem, that cuts out everything and points to the starter. Personally i just replace the entire thing. nipper
