Everything posted by nipper
95 LSi sedan opinions?
nipper replied to MDW25gt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow does someone replace a waterpump and not a timing belt? At that low a mileage and year the car will need a timing belt (time can be just as bad as mileage). Also find out why the mileage is so low, and how often the oil was changed. If it was changed by mileage and not calender (especially with short trips) i would closely listen to the engine. It sounds high to me. Check on bluebook what the recomended value should be. nipper
Stoped in Drive Vibration
nipper replied to WoodsWagon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow many miles are on this car ?When was the last time the car had a tune up. Just for the hell of it check the crankase pully to make sure it isnt loose. Is there any time that its worse or better? nipper
87 4WD carb wagon cooling system issues
Can be a combination of problems. Check the condition of the radiator and the cooling fins. Is the puddle coming from the side or the middle of the engine (water pump leaking). A quick HG test is to start the car with the raditor cap off. If its a major issue the car will start vomiting coolant asap. If its little the car will burp when the thermostate open, then top off if needed, and see if there are bubbles in the coolant. Do you know how many miles are on this car? When was the last time it was serviced or had the timing belt/water pump changed? nipper
Wow.... Land Rovers are pretty hardcore
and even if a soobie could do that i wouldnt want too. After all we expecty our soobies to live another day nipper
AT filter on 96 OBW
nipper replied to lyonsnet's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXslap him for me too nipper
flood car H6 3l
nipper replied to WoodsWagon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it was just pareked it shold be ok. Usually there is an air pocket in the engine that will keep the water out, and the crankase is air tight for the most part. At worst one cylinder gets water in it. The first thing i would do is see if you can crank it by hand. If you want to take the engine just to fiddle with it, go ahead, its always fun to take things apart. nipper
Piston Slap - Should I replace pistons
nipper replied to adamthegreek's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThats the standard repair, and so far everyone seems happy with it. They only do two because i think (dont laugh at me) it has to do with the direction of the connection rod on the power stroke and gravity. Which side are they replacing. nipper
Somebody has done some SERIOUS driving!
nipper replied to Subarunation 713's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI know some people with 100 mile one way commutes. But man thats a lot of driving. nipper
Online subaru parts - Canuck friendly?
nipper replied to fishy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCall them ask for Jamie (she is on this board) and she should be able to help you out. nipper
how to replace 97 impreza OBS wiper blades?
nipper replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey are all like this. One was so bad I actually got somone to show me what i was doing wrong (i can rebuild a engine but cant replace a damn wiper blade). I got the new wiperblades, the ones that look like they are just one peice from bosch, and shose are so easy to install. For that fact alone i may stick with them. nipper
Starter cutout twice in 99OBW
nipper replied to Shep2112's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXflickering lights is a voltage issue. Also cables do get old and sometimes need replacing. One trick to see if its the cable is if it happens again, take one side of a jumper cable, and go from the starter terminal to the battery then start the car . If it starts replace that cable. nipper
nipper replied to Shep2112's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere is a chance the battery was defective. Have someone do a load test on the charging system, as well as check the voltage. You may have a marginal battery. When i get a no start the very first thing i do is check the battery termincal and make sure they are clean and tight. This is the simpliest cause for a no start. The next one to suspect is the NSS but since you said the start was getting slow, im betting on a marginal altenator or dirty battery cables. nipper
help, major catastrophy *updated with pics*
Break a valve spiring, loose a valve rtainer. Thise are a few of the ways one can drop a valve. nipper
Rear end noise, 1999 Subaru Impreza Outback
nipper replied to Husker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRear ends roar when they go bad, and the non SVX's rarely have a bad rear end. Inspect your rear tires, and look for broken belts. Rotate one at a time and see if it moves. nipper
99 Outback Starts then Dies!
nipper replied to Hydroman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMice can chew through all sorts of things. How many miles are on this car, and do you get a CEL. If no CEL and running like crap, i would inspect the harnesses nipper
Best Tires for Subaru Outback????
nipper replied to Suborsche's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo a search here for tires, its a popular post. nipper
Torque bind problem fixed
nipper replied to gyuunuuya's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think someplace in the mass of TB threads, somone did it themselves with new parts from the dealer, and the parts were in the 400-500 range i'll see if i can find my bill and see what the parts cost . nipper
Joining the Head Gasket Club
nipper replied to substeve's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRUN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Cant tell if the block are cyl walls are damaged, but a stall due to overheating usually means the engine got really really hot. Idiot lights will come on when the car stalls. My question is how long before they restarted it, a mintute, an hour , a day , a week ... nipper
HID lights on the GL wagon
so what there are like 4 city limits in the entire state nipper
FLASHER Problem - DRIVING ME CRAZY!!!
otherwise we teach him hand signals nipper
Fuel guage dropping off.
nipper replied to mulcheese's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnot really. It may be too harsh for the plastic at high concentrations. remember just because a little bleach whitens whites doesnt mean alot of bleach will get them really white. Another thing people try is to remove the sensors and clean them with a pencil eraser, but initially that made mine worse. The cleaner we use is specifically made to clean fuel senders. nipper
Need More Power!
nipper replied to d19yda's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbhp = brake horsepower. Brake horsepower is the Hp at the crankshaft without any accessories (alt water pump etc). nipper
Which would you get???
nipper replied to lhrocker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had a 1998 legacy L with the 2.2L. I would get the one with the lower mileage, timing belt is due just because its almost 10 years, and the seals will start leaking soon, but at that mileage, i would take it. Service the tranny too. nipper
nipper replied to mulcheese's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFull tank, since you want the fuel covering the sender. An odd plus for my car i have to do it once every 6 months, cleans up my gauge and gets rid of an odd stumble that shows up. nipper
97 Outback ABS 5.3i troubleshooting?
nipper replied to baboonia's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCool. Either way, it looks like his sensors got decapitated. (something else for me to make a mental note about) nipper
