nipper
Everything posted by nipper
  1. after a flush (NEVER use a chemical flush ion the transmission ever) it takjes a little while for TB to go away, if you dont cut u turns right after the flush. YOu did the usual fix, if it is gone thats a good thing. nipper
  2. put the old sensor back in. Your car is old enough to have a corroded or clogged radiator. is it worse with the AC on. Since the heat brings down the temp you can rule out a blown HG. Check for air in the cooling system. nipper
  3. er um .... new gen subarus already have a cold air intake, thats why it takes air in from the right fender well. Cars have been doing this to some degree since obdII started. You have a link for this airfilter, would like to take a look at it. as far as the begining of the thread, if you have a fender air intake, you already have a cold air system. nipper
  4. skip the spark plugs, as subaru has a rediculously low mileage for this. If the car is running fine let them go. i would also skip the brake fluid untill you need a brake job, as that is another low number everything else you do yourself. DO rotate the tires. no oil change? You may want to add the pcv valve to that list. nipper
  5. thw clutch pack should be 800-900 in a dealership. You resort to this only if the flush doesnt fix it. Jiffy lube depends on the independent shop. The on by ,e is fine as long as they dont touch the tire pressures. nipper
  6. how many miles? 250 is low. Can be a tired o2 sensor, can be a tuneup. Check your tires too. Ac you need to have gauges thrown on it, as it may be as simple as low gas in the system and a leaky o ring. last one is a cv joint, an outer in the front. look and see what condition your cv boots are in. nipper
  7. also the sound deadening thingies (sorry its late and im tired). The metal plates that go behind the brake pads may not have been installed. This will cause the same thing. If a shop did it take it back and let them look at it nipper
  8. use your scanner in real time. Freeze the window when the car stalls then go read the data. See if there are nay out of spec or non existant readings. nipper
  9. define noise? Have you tried a new fan belt first? nipper
  10. ok here is something. Can you get to a junkyard and get a coil or two. it can be a weak coil, but i dont want anyone going out buying new ones untill its been checked out incase im wrong. nipper PS keep in mind the puter isnt my forte
  11. you may have to rent a code reader. Run the reader in real time mode and when the car starts acting up freeze the window and read the data. You can either decipher it yourself or share it here with us. How is your o2 sensor? nipper
  12. i never heard of this, but also in the days before AC was common, radiators would on occasion fell pray to the same thing. With the front profile of cars now, its usually the windsheild that takes the hit. With a larger front grill this can happen. Its one of the perils of driving. There is a way to prevent this, but it requires you keeping an eye on things. First possability is to loof for a bra that covers the nose with a mesh. Second possability is to put chicken wire behind the grill. This second one works well BUT you need to check it for leaves and such in the fall. Another way is to not tailgate and follow the 2 second rule. That helps avoid road debree from hitting your car.. nipper nipper
  13. you need a real set of gauges on the system. There is so much you can tell with the gauges. Your going to have to take it to somone and let them look at it. nipper
  14. actually the braking thing takes practice. and if you get yourseld in soft enough sand, even the best 4wd can dig in. The LSD doesnt work that way. It will rotate real easily without a load on it. you need a load on one tire and the other tire not slipping to get a good number. The viscous coupling LSD is not like the old cone clutch posi rears. nipper nipper
  15. never turn subaru rotors, they dont like it. Yes there are people here that will say they have had them turned and never had a problem. Not every turning removes the same amount of material. Some remove very little, some remove quite a lot of material. Its just better to replac e them then to do the job twice because they warped from having too much material removed. nipper
  16. never turn subaru rotors, they dont like it. Yes there are people here that will say they have had them turned and never had a problem. Not every turning removes the same amount of material. Some remove very little, some remove quite a lot of material. Its just better to replac e them then to do the job twice because they warped from having too much material removed. nipper
  17. the light goes on and off as the fuel moves. Fuel is a liquid and will shift with car direction, but will always initially come on at the same level in the tank, gee i dont see why you have such trouble with that. The gauges have an elcetronic damoer so they dont react as quickly. Tis effect is obvious when you fill the car up, and it takes a few minutes for the gauge to read full. The light means, GET GAS IN 30 miles or sooner. That way you know when to fill up so you can figure out the gas mileage. sheesh nipper
  18. almost. i dont know if the subwoofer was available for those years, just an idea, but it does go under the seat. nipper
  19. anyone check the pressure? AC system is probably going to take an hour maybe 2 to diagnose, but really its prbbly something siimple. Not much there to go wrong. nipper
  20. so would you be upset if i said 120.00 for a new one? http://www.radiator.com/price.php?make=64&model=513&year=1993&engine=1.8L%2C+110ci%2C+L-4&transmission=Automatic&carmake=64&carmodel=&vid=2270928 nipper
  21. You may want another opinion, as that is the first ive heard of this nipper
