25
Everything posted by nipper
have you tried to pull any codes? you can also go to a junkyard and pull a coil pack and an ignitor. You can also have somone crank the engine while a analog meter is hooked up to the crank sensor,. SInce you have spark out of the first pack and not the second, maybe it is a coil pack. The ignitor i think would be intermittent or dead. If you can do the crank angle and cam anglke check and get a heart beat, i would look at the coil and the ignitor. Pick them both up at the junkyard (or a couple of each). nipper
well you have a few possabilites. The tensioner went bad and the timing belt came off or jumped, or the cam angle/crank angle sensor is bad. The dealer gave you bad information. Of course they are going to say that becuase if it goes bad a week later, they get to charge you the labor all over again to get to the part. Why did you use a dealer and not a local garage? nipper
ok then we can pretty much write off the milega on the car as being accurate. i dont expect a waterpump to go bad till over 100,000 miles. Then you have a bad waterpump, and if the car had some major work done, then i would suspect a cloged radiator too. If somone here has a carfax account it would be interesting to run the vin # and see what history comes up. i bet it wont be pretty. nipper
is the car still under warrenty? Has the car had any major work done to it? The symptons dont make sense to me, but im leaning more and more to a clogged raditor. Thw difference in the hose temp tells me there is no flow. ON the other hand the forced running of the cooling fans cools the car down. The more i think about it the more i think your radiator is cologed, but the questions is why? Do you have a stick? What does the coolant look like? What color is your engine oil? nipper
what year and whats the mileage on the car. i know you daid 45k but cant tell if that is how long you have owned it or thats total mileage on the car. If its 45K total on the car its WAY too early for either problem. If the waterpump drive belt was loose the timing belt would junp. Timing belt drives the water pumo. What eyar make engine tranny and mileage is on the car please
Look at This!
nipper replied to jsaudy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
well 30 g for fully loaded legacy, then 10 g for the conversion, 40 is about right. nipper -
Valve job is no that hard, but the ppoint of the valve job is refinishing the seats. Valve grinding compound is not what that is used for. It is actually for lapping the valves, This is done with a suction cup tool to ensure a perfect metal to metal seal, its the final step, not the first step. Taking the head apart is simple. But if your not going to bother with a true valve job (and three angle isnt that hard to do with the right tools) then you may be doing alot of work for nothing. nipper
abs light
nipper replied to pamike's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
in all honesty i dont know. https://www.subarugenuineparts.com/oe_parts_cat.html look there and see what part number comes up. nipper -
Look at This!
GIMMIE! nipper -
Remove one spark plug wire at a time and see if the noise changes pitch. Is it from the front center or rear of the engine. Does it do it when the engine is cold? nipper PS i love svx, looking for one for myself. There is an svx board, but they are sort of useless as far as anything thats not the tranny or the differentials.
abs light
most popular reason is a dirty or malfunctioning wheel speed sensor nipper
