Everything posted by nipper
Nipper HELLO can you help me?
nipper replied to pitstain's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey cured the design fault, that doesnt mean its doesnt break anymore. First thing, make sure all tires match and are properly inflated. Put the fwd fuse in the holder and see if it goes away. If it does it means electrically everything is working and the clutch pack isnt fused. Second flush the tranny (100 bucks is cheaper then 800-1000). That solves it 90% of the time. The legacy is simple car, so dont be intimidated. The awd is straight forward on the automtaics, on the manuals they are much more complicated mechanically. The clutch pack is always engaged and designed to handle some slippage (like curves). Constant slip kills it really fast (mismatched tires). The duty c solenoid controls the amount of AWD applied. Putting the fuse in powers the solenoid constantly so there is no awd at all. nipper ok im getting scared, this is the second post that asked for me by name
Please Help
nipper replied to giordi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsounds like it is the ignitor or an ignition problem. Next time it stalls check and see if you have spark. Can be a dying knock sensor, the backfire, floored throttle has me a bit perplexed. SOunds more and more like ignition. nipper
Nipper...Let me get you a coffee.
nipper replied to No Stuck's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi've gone upscale, i want a capacino. The OBW can pull its stuff, just drop the air pressure and have an on board air compressor (just like any beach comber). 5 speed is a 50/50 split. Automatic is a 10/90 varing to 50/50. i'm geting to be a bigger fan of automtics on beach vehicals. If you get stuck its hard to modulate the clutch/throttle when you dont have a grany gear. Also you can simulate lsd on front and rear by gently applying the brake pedal, you can get torque to all 4 wheels (basically waht the new computerized systems do). As far as the head gasket, in a 8 year old car or older thats always a chance on any car. But i have been seeing less and less HG issues as they are getting repaired. i like nutmeg and cinamon in that capaccino nipper
Anoyying raddles here and there under the dash board GRR
nipper replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIn no time all the loose parts will fall right off nipper
EJ18 overhaul?
nipper replied to Tbird Man's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmore expensive is NOT better (just means good marketing). Everyone here seems to agree to go with OE, as the more expensive plugs dont seem to work right some times. Search on spark plugs for lots of information. Some cars dont run on platnum plugs that well. Also there is a rebuild kit of the PS pump to stop the leaks. Dont skip the waterpump, you will regret it. nipper
Voltage Test
nipper replied to stephenbybee's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhrmm the haynes manual seems pretty clear, its says battery voltage. So whatever the battery is putting out with the key on is what is supposed to be there. It also says that if it is not there to check the puter with a scan tool. the wiring diagram has it powered by the ecu. nipper
EJ18 overhaul?
nipper replied to Tbird Man's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust go with whatever the factory put in, as the sooby seems to love them best. nipper
nipper replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi'm going to take a giant leap of faith here and assume you mean a rattle. It's an old car, old cars get rattles. A few dozen things back there that can cause a rattle, so happy hunting (use a freind to help if it a noise made when the car i smoving). nipper
Wagons only - post your pictures here!
nipper replied to kevinsUBARU's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIn a parking lot! now where is my cookie nipper
Catalytic Converter Replacement
nipper replied to wandersub's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXpromise me you wont laugh, but hit the cat with your hand or a rubber mallet. If you can hear it ratle inside it is shot. Also at that mileage it wouldnt be unheard of. a clogged cat would limit throttle response. nipper
transmission pan
nipper replied to pamike's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThen you have to inspect the pan carefully. You did use a gasket? is it leaking from the flange or a bolt hole. nipper
yellowing cloudy headlight lenses
nipper replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi miss the dual range, i dont miss the 2 bbl with its miles of vacume lines nipper
Slow & Wussy Power Windows... How to make them better?
nipper replied to Andyjo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi know that there is a bad joke here someplace but i just cant think of one That would account for the last inch of travel. rember these cars are frameless windows. You may have a point with the sunroof though nipper
Dealership can't even figure out engine? problem with my Legacy Wagon
nipper replied to thedena's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIts good it happened to him. Its bad that mortal sin that you commit The ecu will store codes. Most codes will trigger the ecu, a few dont. Also some codes dont stay in memory (since they are minor or do not happen long enough to be considered a hard fault). Also when you use a scanner, you can read the sensors in real time to see what they are doing, and it will also tell you (i think) wetaher certin valves are opned or closed. You may have a stuck purge valve. A stuck valve may not throw a code, but if the coil for the valve was dead that would throw a code. nipper
oily 2.2 98 legacy brighton underbelly
nipper replied to pitstain's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthats your problem, you have a brighton, so you need a generic blinker fluid, not name brand. Make sure you used the summer mix (btw i vote for oil pump o rings) nipper
Misfire after sharp cornering only
nipper replied to unobtainium's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXactually with ethanol dry gas is almost a moot point. You may have dirt in the tank. If you have used more then one tank of gas since storage then any water should be burned up. Another possability is that the jet pump is clogged (fancy term for in tank siphon) or clogged. Soobies have split gas tanks, and use a siphon to drain gas from the left side. You make a right turn, gas moves to the left, and for some reason isnt getting sucked up right away. i vote for dirt. nipper
nipper replied to unobtainium's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXexactly when does the car do this? is it hot or cold? first drive in the morning or after its been sitting a few hours? Is it predictable or intermitent? Subaru tachs dont work off the coils, the tach gets its signal from the ecu. When was the last time the car had a tune up, and yes dont rule out the ignitor. nipper
nipper replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgoogle yellowed headlights, there lots of information out there, as we are not alone. nipper
95 legacy upholstery repair/replacement?
nipper replied to dj3stripes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXlook in junkyards for replacements i would guess. You can try steam cleaning the seats nipper
Help! 1999 Outback Phase ll Block, DOHC Heads
nipper replied to steve2005's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdrive sensibly? what is this "drive sensibly" of which you speak? thats no fun. Seriously just watch the temp gauage everyso often and youll be fine, beating the crap out of it drive sensibly if its going to go, its going to go. Its not a performance issues, its an erosion issue of the HG and overestimating the sealing force required in a thin spot of the gasket. It's only about 15% of the engines and the longer time goes by, the less of these bad HG there are of none repaired HG's nipper
oil pump sealant
nipper replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPermatex is the way to go, just dont use a lot of it nipper
transmission pan
nipper replied to pamike's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEEEEKKK alas my warnings have gone unheaded Tranny pans have to be removed as methodically as a cylinder head to prevent leaks, and the same reinstalling it (oil pans too though they tend be stiffer). Its easy to bend the lip and cause a leak, or make an existing one worse. It may not be the gaskets fault. Get a steel rule or straight edge and make sure the pan flange is flat. Reinstall the pan using a star pattern and slowly tighten the bolts. All else fails there is always RTV. nipper
nipper replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere is also polish available at autoparts stores, the two part system works best. nipper
something is Slipping....!
nipper replied to AlpineRaven's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXer um, there are easier questions to answer. like is there a God. a good driver should get 80,000 miles at least. On subarus it seems like 130,000 or more is not out of the question, even more if you have a hill holder. If you have a clutch cable, replace that too (never know what other countries have). nipper
nipper replied to AlpineRaven's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour clutch is shot, the question is why. Your gooing to have to wait till its pulled apart to find out why. i have a feeling this may not be a new clutch. nipper
