nipper
Everything posted by nipper
  1. Do a search on climate control, you will find it. nipper
  2. There are a few options https://www.subarugenuineparts.com/oe_parts_cat.html they have great prices. Another is go to a mom and pop auto parts store (there is a reason repairshops dont use autozone for parts) and get a rebuilt there. nipper
  3. On the plus side OE is not that bad cost wise, considering how long they last. nipper
  4. grrrr Year enigine size type of tranny and mileage. How long have you owned the car. We cant help at all without this information. AC clutch can be replaced without toying with the compressor itself. The other noise assuming this is an automatice, i can only guess at. Yes do a tranny flush. If you pwoerbrake the car does the noise change in pitch. Is the noise there in all gears (listen hard for it). Cant say more till you tell us more about the car. nipper
  5. Did you use sooby bulbs or the radio shack bulbs that are recomended. Also you dont say how old your car is, but lightbulbs burn out with age, it happens, and in the newer DIN steros, they cant be replaced (and aftermarket is the same way) One thing to check is to see the voltage at the bulb socket. nipper
  6. Depends who is doing it and why. You can replace the boot, but it is just as much labor to replace the boot as it is to replace the axle (if not more). You can get a split boot, but they tend to leak on outer boots, but seem ok for inner boots. nipper
  7. Ditto. There is a right way and a wrong way to store an engine, and if not done properly can screw it up. Did it have plugs in it when you got it? Was the intake and exhaust sealed? nipper
  8. i like semi-syn in the tranny I dont know the threshold of the ATF light, and one really wants to avoid a light coming on as opposed to waiting for the light to come on. A tranny temp gauge would be a good investment too. nipper
  9. HAHAHA you funny, radio shack actually selling something useful beside light bulbs. i buy my widgets from http://www.alliedelec.com/ allied electronics. If they dont have it no one makes it. nipper
  10. you can get a timer relay that would dtake care of that nipper
  11. Next time it happens downshift and see if it still does it. What speed and engine rpm does it. when was the last time this thing had a tune up, fuel filter plugs wires etc, it could be a coil issiue, coiuld be fuel delivery. Also have the codes pulled off the car and see what it is saying. nipper
  12. Do a search ehre and see what comes up. There is no such thing as too much cooling of the tranny unless you live where it gets 20 below. Its real easy to do http://www.flex-a-lite.com/auto/html/translife-coolers.html http://www.bmracing.com/index.php?id=products&sid=4&cat=20&subcat=28&pid=73 to start nipper
  13. Do a search ehre and see what comes up. There is no such thing as too much cooling of the tranny unless you live where it gets 20 below. Its real easy to do http://www.flex-a-lite.com/auto/html/translife-coolers.html http://www.bmracing.com/index.php?id=products&sid=4&cat=20&subcat=28&pid=73 to start nipper
  14. Yes it can be done in the car. If you take it out, you unbolt the ac compressor and put it to the side. No hoses have to be opened. nipper
  15. Thise are just variable resistors pput in line with specifice sensors, can be the o2 sensor, and be the TPS, and be almost anywhere and lie to the ecu. YEs you can get more power, but it wil cost you two cat converters. The only ones worth any money are the chips that go in the ECU, and they aint cheap. Dont by the electric turbo either. nipper
  16. ah non unibodies are easy. They will still flex but not as badly
  17. Subarus tend to be picky about plugs and wires, and like OE the best. Considering how often they gaet changed (maybe three times in the life of the car) it pays to go with OE. The K and N air filter has higher flow, but allows more dirt in (this has been discussed many times here, and there is a link someplace to the lab report stating as much). The dirt can damage sensative electronics downstream from the air filter (especially if the filter is oiled). It takes at least 3 tanks of gas from the same station to determine if you get better mileage. In my 97 OBW auto i can get from 17-23 around town just purely with my right foot. i could probabaly use a new set of wires at 185K (car coughs once in a while in gear stoped). Things that can influence mpg. tire air pressure, air filter, junk in the trunk and your right foot. Always good to hear somone has squeezed a few more miles out of a tank of dead dinos.
  18. Well you can do it to any car, just dont expect to get a lot of life out of it. :-\ nipper
  19. i remeber when it used to be magic wands, now its little black boxes nipper
  20. i keep forgetting you have a 1.8L, sure be difficult. If you can find pictures of them within the same Generation, the sensors should look all alike across the engine range. i dont have any 1.8L info for that year nipper
  21. and a lot of body reinforcement if you dont want the windsheild to pop out or the car to fold in half...... kinda of embarising when that happens. nipper
  22. In my local paper, Newsday, they have a peice on cheap fixes aka Fuel additives (which the scarfed from the LA Times). http://www.latimes.com/classified/automotive/highway1/yourwheels/la-hy-wheels3may03,0,6121637.story?coll=la-class-highway1-yourwheels Basically in the last few years a number of gas stations and refiners have been sued for pumping high sulfur gas. The high sulfur gas contaminates the silver ro silver paladium strip in the fuel sensors (in the tank) and cause "erratic" (read broken" fuel readings at the gauge. The peice goes on to say tens of thousands of cars have been damaged by this. Hrmmmmm They als state that Chevron has a additive sold in sotres called "techron Concentrate Plus" which is designed to clean the sensors and save "consumers potentially 500-1000$ in repairs". i will try this the next time i fill up, cant hurt, aside from the 10.00 they say it goes for. Just wanted to pass on the info. nipper
  23. Brandon, Go get yourself a haynes manual. Since this may require more troubleshooting then we have done so far it will make it easier for us all nipper
