25
Everything posted by nipper
air conditioner
nipper replied to 97OBW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
i have 182,000 and it will still freeze you out of the car. nipper -
when was the last time this thing had a tune up. i bet from the low mileage the plugs are fouled. if this is all local driving go to a slighty hotter spark plug. Give the car a full tuneup, plugs wires and filters. If your doing maint by the mileage and not by the calender, switch to the calender. This thing is way over due for a tuneup if it hasnt had one and a tranny oil change. nipper
its a HG. Has all the classic signs. Get the exhaust test for the radiator. Also look for bubbles in the coolant. Radiators dont seem to clog up untill higher mileage, and usually only when the AC is on. You can get a raditaor for about 100 i think from raditaor.com. ALso change your oil when you have the HG fixed. Oil isnt keen on being over heated either. nipper
i agree. For 3500 you could have got a rebuilt engine installed with a 3 year warrenty. That dealer not only ripped you off, but royally screwed something up. i'm not seeing how the block can be warped but that point is moot. It sounds like they somehow blocked the oil Jounal or debree got in the journal to the camshaft. Usual failure mode after a HG from an engine being baked is a spun connnecting rod bearing. Also i question why you got a valve job, as soobys tend to rarely need one. Something stinks here. Document everything. Take notes, even on phone calls. Get everything in writing. MAYBE you will luck out by dealer #2, but i can tell you myself its hard to diagnose a failure when someone else has taken the failed item apart. Send an oil sample to a company that analyzes oil. They can help rule out causes. Explain to them what happened. Be prepared for a fight. Stand your ground, prepare for a fight. This is defanitly a failure due to oil starvation. An empty crankase makes for a very noisey engine, and wiped out bearings and possibly connecting rods. nipper
This is one of the things that can cause sway.worn bushings can cause suspension parts to move more then designed. Then add in to the mix alot of cars (including subaru i do beleive) has some sort of passive steeing in the back of the car though wheel movement.add all this together you can get sway. Since everything else checks out, i would inspect ALL bushings front and rear. Bushings are cheap enough to get a pair and replace any in question. Sometimes you cant get a true feeling for them untill you remove them. Some bushings have a steel sleeve inside them and can be a challange to get off. nipper
Here we go... There is an illumination control module that is the amplifier i was talking about. I would test the stalk by removing the trim on the steering column, dsiconnecting the harness that leads to it (do NOT touch anything if in doubt..as the air bag wiring is stuffed in there too). Airbag wiring is wrapped in colored tape so leave that alone. You have blue/red blk/red brwn/red coming from that rehostate. Using an analog meter, there shold be no opens and values should change as the dimmer is rotated. If that all works out its the illumination control module. nipper
No need for locktite if it is properly torqued. Thats the reason for the torque spec. If its a manual thats one way to do it, have somone stand on the brakes with the car in 5th gear to get rid of the mchanical advantage. There is a access hole in the bell housing for the ignition timing marks. You can lock up the engine there with a heavy screw driver or some other method. SOmone should chime in. nipper
tire comparison
nipper replied to rizzo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
From personal exp i agree 100% except for the french part. nipper
