25
Everything posted by nipper
First we are going to assume all the motor mounts are in good shape. While the car is in drive, parking brake on, someone in the car with thier foot on the brake. Shutting down one cylinder at a time to see if there is any change in the idle condition of the engine. If you hit a cylinder that does not change the rounghness to a great degree, it may be an ignition/fuel issue on the one cylinder (plug or dirty injector). The one that has an issue will change the least. nipper
From my 97 OBW manual (just an fyi) MT model towing without brakes - 1000# with trailer brakes 2000# AT model Towing without brakes - 1000# with trailer brakes 2000# Towing continously up a hill of 5 miles with an outsdie temp of 104F 1000# (odd how they came up with that one) Now that is trailer plus load, not just trailer. The key thing here is trailer brakes and tongue weight of the trailer. nipper
Cam timing has alot to do with exhaust note. Designers cant really fiddle with when TDC is, as it is always in the same spot. The can fiddle with calve lift, tming, duartion, and overlap/. As far as engine internals on ANY boxer engine, since cboxers arte flat equal and opposit forces cancel each other out so there is usually almost no mwear on the pistons, connecting rids, and crank. Boxer engines tend to breath pretty well due to design. The intake runners are of equal length. SUbaru exhauts systems are already fairly well free flowing (hence the lack of alot of headers on the market). THis goes for almost any boxer except VW as they used the exhaust for a source of passenger heat. nipper
This cant be right either. ONE INCH too short is dramatic in a car where sometning 5mm too short will self destruct. Yes i can understand the factory shafts being better (i have often said buy subaru shafts, anything else would be taking a chabce) but ONE INCH comeone is on drugs. I can think that the shafts being too short, theyre would be no freeplay in them. No freeplay means that every little vibration from the engine is being transmitted to the chassis like having solid mototmounts. Now that being said, i woud go to NAPA and DEMAND that that is put in writing, because that lack of slack could possibly damaged the transaxle or wheelbearings. I would be pissed ..... nipper
its more then weight, its a higher center of gravity. nipper
Oil Pressure at 75 PSI!!! AHH!
nipper replied to gwsbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
get yourself a really cheap mechanical gauge. It can be the sender, it can be stuck check valve. Somone here probably knows the resistance values. nipper -
Switching a digital speedometer
nipper replied to river2surf's topic in Old Gen.: 80's GL/DL/XT/Loyales...
hrmm its not the computer i thought it was... Oh well, just learn that 66mph = 100kph nipper -
Electrical issue - cannot turn over
nipper replied to Ever Victorious's topic in Old Gen.: 80's GL/DL/XT/Loyales...
remove all the cables clean and reinstall. Hot wire to the starter using a jumper cable and makesure the starter is good nippper -
Knock knock :-(
nipper replied to don80's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
This does not sound good. It almost sounds like a rod knock. Has the car ever been overheated? You can try this. when the car is warm and running, dissconnect one spark plug wire at a time. If the sound changes pitch, you found its location. If it doesnt go away we can rule out rod knock. nipper -
i would fix the clutch. You knwo the car. The work you have done in the past will just have to be done to another subaru. i would suggest doing a compression test on the engine. If the numbers are good, go for it. If you like the car, go for it. The money you are putting into the car are just normal wear items. i dont see anything unreasonable. nipper
You know there are times that you should let things go and stop over analyzing. http://auto.howstuffworks.com/differential.htm The failure mode for a LSD is that the tires will squeel around turns. If you dont have this issue, and if both wheels turn in the same direction when the car is off the ground its working fine. If it reallly bothers you i would gladly loan you my open differntial and take a long time to investigate your differential in great detail , it may take a few years to do it. Now does the lightbulb really go off when you clsoe the fridge door? nipper
There are kits to mount the sooby engine on a VW tranaxle... the vanagon people do it all the time. nipper
yes i agree...... nipper
HELP!! Oil Sandwich Adapter!!!
nipper replied to Gravityman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
oooooo if the make one for the 2.5 i want one. Was trying to figure out how to add more oil capacity to my OBW. nipper
