Everything posted by nipper
noob question about boxer sound
This ca all easily be solved by turning up the radio and the 300 watt subwoofer nippper
Funny noise.....(Impreza)
nipper replied to SUBARU3's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou know we never did classify the funny noise as funny hehe or funny haha ..very important for diagnosing nipper
gl wagon cruise control?
i have used the split boot repair kit with no problems, but a year later i had to replace the axle due to contimantion. Its hard to clean the joint without pulling it apart. There are many good aftermarket cruise controls out there. I do recomned though that you get the either an optional vaccum pump or the fatory vacume pump, otherwise the cruise control will keep disconnecting going up hills. nipper
Where is a diesel powered subie available?
nipper replied to LostWater's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIts going turbo diesel in a peice iread from a new zealand paper nipper
clutch judder on '97 OBW
nipper replied to q240z's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like a clutch pure and simple. The next question is why, and what brand clutch parts they used to fix it last time. I did find this on the net, dont know how accurate it is http://www.pdm-csrk.com/ nipper
catalytic converter or O2 sensor
nipper replied to kimkathan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXReplace the O2 sensor first. The two O2 sensors once up to cnuff will tell you if the cat is working. Cat is not a cheap part to replace, so do the simple and cheap stuff first. nipper
<semi-newbie here> tranny grind/knock
nipper replied to johnnyennui's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe RWD part of the drivetrain always spins no matter weather the fuse is in the car or not. Is your starter fully disenagaing after you start the car. Does the car do it in neutral or park? Does it do it when you have the car in drive, fott on the brake, and give the car gas (dont do this for more then a few seconds). nipper
transmission problem
nipper replied to swilde20's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo a pcv valve, and sometimes its normal to have a cloud of smoke come out when you get on it. My 97OBW is doing it , and it seemed to satrt with the relaxing of gas standards. The only thing i can think of otherwise is an 02 sensor, but in all honesty, i would not gte too frantic about it. Try a tank of Ammoco premium and see what happens, or some other brand name good gasoline. nipper
nipper replied to johnnyennui's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAutomatic trannies dont grind when the go, or start going. Now that being said, at what RPM does this start. Is it RPM dependent or speed depenednt. If you pup the car in neutral at speed does it go away. If you downshift to drop the engine rpm under the threshold does it go away. I dont think its the transmission. You also have a carrier bearing and a couple of U joints under the floor ro the RWD. I would look there. nipper
nipper replied to LostWater's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi cant find anything on the net, just future engines.... whay not drop them an email and ask? nipper
nipper replied to kimkathan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRubber mallot test will just tell you if the cat is rusted out. How many miles are on the car ? A drop in gas milage can be bad o2 sensors. I think the two sensors check the cat performance, before and after. With the drop in gas milage, are you also feeling like the car has lost some performance. Depending upon the milage I would suspect the O2 sensor/s . nipper
Con-Rod bearing stiff?
There is a spec ofr side to side clearance in the journal of the connecting rod. Dissassemble everything and check all the specs too. It is possible that one crank journal is a different size then the others. nipper
Impreza steering rack question
nipper replied to SUBARU3's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can by a rebuilt rack. In warm weather a leaking rack is not an issue. In winter they can be real bear to drive until the rack warms up, if the internal seals are shot along with the outer ones. i dont know how long you can keep adding fluid to it. Depends at what point it starts leaking on the exhaust and smokes you out of the car. nipper
Where is fuel filter located?
nipper replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell if you dont know the last time you changed the filter, you just change it . The light under the PRND21 you have to partially disassemble the console, which is not all that hard to do. I think you start with the two screws under the center arm rest then it comes apart like a jigsaw puzzle.... im not sure been a while since ive seen one from 93. nipper
Subaru exhaust Northern NJ
nipper replied to 740gle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou know it could be as simple as bad flange gasket .... nipper
Strange coolant behavior?
nipper replied to sid_vicious's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like its weeping out the waterpump weep hole. Time for a waterpump, and as long as your there, belts too. nipper
94 Legacy Wagon - Water Pump & Oil Pump Seal
nipper replied to fredrosse's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'ld have them do everything while that are there. Replace the waterpump, I usually replace the oil pump after ten years. Have them inspect the cam seals and main seals, replace if they even look the lightest bit tired, replace the iming belt. If you do all this, may be pricey, but then your good for another 80K miles. nipper
nipper replied to SUBARU3's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLook around under the car at the heat sheilds, any plasti tidbits etc under ther. I bet you what your hearing is wind noise from something being loose or caught down there....nipper
New Outback owner served slice of humble pie...
nipper replied to bernie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXlook at all the switches, and wonder ...what the hell are they talking about... well that was the last volvo i had to rent. Now we and our brtohers from Saab embrace the oddness and quirkyness of our cars .... even if i keep washing my rear window by accident .. nipper
Brake Indicator Light-What does it mean?
nipper replied to 2-baru-family's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes oddly on a number of cars that I have, more so Japanese, the barke light would come on way before the battery light would come on with a failing altnator. When it got real bad all the idiot lights would come on... except the battery light. It may have to do with the type of failure it was inside the altenator. I think the battery light comes on if its a bad regulator, not a bad diode. nipper
What is one to do?
Why not try heli-coil thread inserts? nipper
nipper replied to bernie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou actually want to know how to turn the headlights? you RADICAL! isnt it amazing now how you need to have a lesson on how to drive in some cars. Drove me up the wall when I rented a car with automatic headlights and there was no real way to shut them off. nipper
nipper replied to swilde20's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhen was the last time it had a tuneup ...thats not a tranny issue. Also mine does it on occasion too, but im blaming it on the crappy gas going around. nipper
nipper replied to bernie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDont feel bad, i cant shut off my rear wiper without triggering the washer duh nipper
2001 Outback - Running lights will not go off
nipper replied to farva's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou are right, in other countries its law. nipper
