Everything posted by nipper
justys
Yup, there are a few here too
justys
Nonononono the 3 cyl is a nice oddball powerful engine, and the cvt when dirven properly is really amazing.
justys
i do, i own one. SHould be on the road by april.
Engine Missing
nipper replied to The Dude's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPlug wires mya look ok (and these may befine). What happens is they have less silicon or inferior silicon to what Subaru specifies from it's suppliers and they break down quicker.
"creaky" 97 GT Auto 2.2 Wagon
nipper replied to gregB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWel the next thing to do is pull the radio and drive the car, look for noises behind the radio.
need help, no brake pressure after rotor change
nipper replied to danbennett2u's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSometimes if it is an old Master cylinder a brake job can damage the internals if bled by foot (really old). What happens is that the cups are pushed past their usual travel, the same travel that they have been doing for millions of strokes. A ridge and gunk can build up and damage the cups. ( I said sometimes )
What's so bad about a hitachi carb?
I was wondering about a throttle body (cheap FI) as opposed to a full fuel injection conversion for the Justy
'95 Manual doesn't shift right.
nipper replied to starfox5194's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTsktsktsk no one wants to keep things simple? YOur bushings are shot, nothing wrong with the linkage itself. Just replace the bushings in the shift linkage and your done. I think the performance places have performance bushings for the shifters.
On the 89 Justy it has like 8 internal parts. I sort of like the electronic ones less hoses less parts. I was looking at converting the justy to a webber but i need a shaft through the bodyand the weber from what I can tell does not have that. It is just like any carb decision, smaller less power better MPG vs larger better performance less MPG.
Acts like slipping clutch, but not so sure...
nipper replied to detwiler007's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour at high enough mileage that your universal joints in your driveshaft may be shot. do not drive this untill you rule out the driveshaft, as it can make life incredibbly interesting for 5 seconds.
Rounded Axle nut removal
We don't all have welders. Sometimes brite animal force or delicate dremel tool surgery, then splitting the nut has to be done by us peasants
nipper replied to danbennett2u's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou need that rubber seal. It serves two purposes (and on seom cars three). It keeps the fluid from jostling around and getting airated. It keeps the fluid from coming back quickly into the resivoir and areating (like a fountain). It takes up volume to keep air out.
nipper replied to gregB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXrear mount is EASY. Basically it is an unbolt and replace. You may have to jack the tranny a little bit to get it in there.
Mystery stalling when braking ??
nipper replied to SubeeTed's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA/F = air/fuel mix = Oxygen sensor
nipper replied to SubeeTed's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUsing 20 year old technology as a measuring stick is like saying all four cylinders cna only make 80Hp. So so wrong. When lockups first came out GM lockups were new and had issues. It is never heard of these days (someone will say Mememe but ya know, there is always one). It is not the torque converter. It is a A/F issue or vacume leak. Possibly a dying O2 sensor.
nipper replied to SubeeTed's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXReplace the PCV valve. Cleaning the IAC doesnt always work. Did you put in wires, what kind.
nipper replied to SubeeTed's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo no no no maybe yes and no. Delay engagment is a bad seal inside the transmission common to 01's. TransX is the usuall fix. Have you replaced the PCV valve? When was the last tuneup?
nipper replied to gregB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHeck it can even be a suspenion part
nipper replied to gregB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe transmission mount doesnt age well, I would look there. Noises travle so that may be why you think it is the dogbone.
Where to buy Porcelain White color code 241 spray paint??
+++++1 on these guys. I have used them for Blu and the Justy. Also great communications.
Engine Missing
nipper replied to The Dude's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhehehe thats the first thing I thought too
At what speed do you cruise with your legacy ??
nipper replied to renillo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGenerally all engine are very happy at a fixed rpm in thier torque band. It is all the stopping and starting they arent thrilled by
Engine Missing
nipper replied to The Dude's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCars havent really changed since they dropped coal dust ignition. They still need tuneups to run properly. You need to start with a tune up including the PCV valve. Use the basic plugs sooby recomends and OE wires, anything else can be anything.
Terrible gas mileage 91 Legacy
nipper replied to Markus56's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell it isnt that simple. It isnt so much the tire size, but there is a automotive factor called "drive wheel thrust" (basically more auto engineering term that us engineers use). With the larger tires you have effectivly changed the gear ratio of the diffs. This requires more effort to get the car moving and keep it moving. as the terrane and wind changes. At highway it should be a net gain as thats why they used to call taller gears "highway gears"
nipper replied to Markus56's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEven a geo metro probably wouldnt warm up enough for the best gas mileage. Trus me i have a Justy i know. Best thing for short drives is a car with fuel injection. Dang I would have kept the metro as a investment. Everytime gas goes up I get offered stupid silly money for the Justy.
