brus brother
    44
Everything posted by brus brother
  1. On my 05, the green diagnostic connectors are on the passenger side tucked up under the dash. They should NOT be connected under normal operation. https://www.subaruoutback.org/threads/connectors-under-dash-unplugged.39287/ The seat belt chime is different than the open door chime. I smooshed my drivers side plunger switch for the open door chime by catching the seat belt buckle in the doorjamb while closing the door. PITA to replace. The seat belt chime will sound a number of times then pause then repeat. Is that your sound or does it just keep chiming without pause? There is a sequence to disable the seat belt chime
  2. defective alternator can give a light show. dinging airbag? you aren't referring to the open door or seatbelt chime? which can happen if the switch in the doorjamb is smooshed or defective switch in buckle. easy fix is to disable the chime. https://www.subaruoutback.org/threads/seatbelt-chime-error-chimes-all-the-time.183505/ what codes are you getting?
  3. run your finger along the seam where the valve cover mates up to the engine. If you find fresh oil, the VC gasket is a likely culprit. mine leaks so bad now that I get a good size puddle after letting the car sit after running as the oil remaining within the cover drains out.
  4. different color fluid but directly above the filter is the power steering pump which was leaking on my 05 OB You should see it collect in the recesses on top of engine. once that fluid is exposed to road dirt and such it can appear just as messy as in your picture. also look on top of the engine on passenger side in the recesses. I recently developed a HG leak on top towards the rear where an oil galley can leak through a failed HG but as Numbchux said, you would expect that oil to blow backwards.
  5. properly torqued plugs? without torque wrench tighten until you feel them bottom then 1/4 to 1/2 turn to crush washer.
  6. What Lucky said.. Is the valve cover leaking/spark plug seals hard and leaking? Might be coincidence that 3 and 4 are opposing cylinders. LINK here and posted by Bagshaster he describes similar opposing cylinder codes (1 and 2) and his turned out to be a bad tensioner!
  7. You need to bang around on the heat shields as they don't have to move much. The reason I am suspect is the sort of harmonic vibration that would happen under certain rpm/load. My 05 Outback exhaust is a bunch of stainless pool hose clamps holding it quiet.
  8. Auto or manual transmission? How many miles? Does the sound go away if you step on the brake? Does the sound occur if car is stationary? Is it by any chance a loose heat shield on the exhaust rattling? What are the transmission and/or catalytic codes/issues? Did you get the codes read? The catalytic converter code is usually P0420 and while you can throw your wallet at the car, results may vary.
  9. I like these micro torches for working in tight spaces, loosening fasteners ~$13 at Harbor Freight. Push button on and off.
  10. Just occurred to me... the other day I heard a ticking noise coming from the drivers side with the severe oil leak. I took out ye old stethoscope and isolated the tick to the driver side valve area. If all the oil had seeped out of the bottom of the vc while the car sat for a few days, would this account for the ticking on startup that went away after a few minutes? @sirtoke regarding bottom out removal for driver side, I took a quick look and first thing I would need to do would be to remove the oil soaked engine dust shield. I may end up doing just that to see if my fat arms can swing in from underneath to catch that rear bolt. Digging that far in, I would also have the potential to remove the wheel well shield and gain side access that way. Still trying to assemble the floor jack and appropriate sockets in the event that I need to raise the engine, if I had already detached the vc. I know I am probably overthinking this but there is an old military adage, the 6 Ps. Prior Preparation Prevents Piss Poor Performance.
  11. Check over at subaruoutback.org Cardoc has a posting (about 1981 posts, 100 pages worth) HERE He is very generous with his time and will help interpret your readings. I tried replacing passenger side Air Fuel and front O2 sensor and the cat converter without success. My car has 3 cats, 2 AF sensors, two front O2 sensors and one rear O2 sensor. At 200K miles, I am not going to throw my wallet at any more fixes. Good luck and let us know how it works out.
  12. I have had P0420 on my 05 OB for the last ~100k miles. I live in an emissions testing state. I have tried inserting the resistor trick on the O2 signal wire but while the P0420 went away, I started throwing P0298 immediately. Uninstalled the resistor and back to the P0420. While P0298 comes on almost immediately after clearing the codes, I can clear the P0420 and then have enough time to get all the systems "ready" to pass inspection. Procedure for readiness: I use an old Autel Maxiscan LINK listed from China for cheap if you can wait for delivery of there are similar US sellers for $18-20 It's cheap enough to keep in the car and plug into the OBD port without fiddling around with opening programs on your phone to mate with the other types. But, both types will do the same thing. Best done with 1/2 tank of gas 1. Clear codes 2. Start car without stepping on the gas (it will take a few cranks as the ECU is starting from scratch). 3. Let car idle for 15 minutes without touching the gas 4. Drive car about 10-15 minutes at highway speed (55 mph) trying to keep speed constant (no braking or hard acceleration) 5. Check for system readiness and if all set as ready, drive to inspection station. I check for inspection stations nearby and plan my route accordingly. Last time it took a few tries to hit the sweet spot but I am now good for another year and a hlaf. I have been doing this for the past 7 years through three inspection cycles.
  13. low fluid? long shot: any chance you disconnected battery while working? alternator output?
  14. Thanks Ido... I do have the FSM, but "rocker cover" gasket nomenclature wasn't what I expected. They don't mention any sealant but then again, they don't mention that you need to be a circus oddity to get your hands down into those spaces. Instructions: "remove" and "replace". Thanks Captain Fuji Obvious. I may end up tweaking the engine up a bit. I am in the rust belt but am blessed with an oil soaked undercarriage due to mild drivers side HG leak and passenger side top rear HG leak. Lucky me! I will borrow up a 6 point socket before customizing the engine mount nut with my 12 point junk. The left "rocker cover" gasket is a serious leaker now so stand by for a full report on the adventure. @Moosens, yes I retired! I am finding crossover usage of my old tools. If you stop by we can experiment with channel locks and oil filter wrenches for all your dental needs ;-)
  15. one video I watched suggested using gasket maker sealant when placing the gasket in the valve cover. is this factory spec or just belts and suspenders and to make sure the gasket doesn't get dislodged when reinserting the valve cover? I bought the FelPro gasket set.
  16. Friendly subie tech said loosen the passenger motor mount remove the driver motor mount and tilt the motor. My plan is to remove the oil soaked shield below the engine bay and see if I can access the rear lower vc bolt and wiggle the cover out without disassembling too much else. As a retired dentist, I am used to working in tight spaces and never considered the option to remove the ear to work on a back tooth. ;-)
  17. spoke too soon still leaking. gasket is probably smushed and no longer sealing. hold onto my ankles, I'm going in!
  18. 05 outback 200K miles puddling oil. Yes I have had external HG leaks for quite some time but all of a sudden, there was a lot of oil leaking. Watched a number of videos on replacing the valve cover gasket and plug seals. Today I investigated how tight the quarters are for my fat hands and to my amazement, the lower front bolt on the drivers side was so loose I could turn more than one full turn by hand! Checked other bolts and they seem OK (alright, I didn't get to the lower rear bolt). Will check that another day. Fingers crossed that fixes the leak... for now.
  19. teach an old dog new tricks! never thought of the PB Blaster trick. also, is it better to try removing plugs while engine is warm?
  20. Well for $5.33 for the part that you linked, it seems you should upgrade from the penny/gorilla tape as you might want a more permanent fix. Check with local Subie dealers in Tucson if any are close to you to avoid shipping charges? E BAY listing HERE with free shipping for $5.27 Otherwise for the link you posted, shipping may be more than the part cost! Looks like about $10 shipping!! Good work on noodling through the problem.
