26
Everything posted by jonathan909
Much appreciated. The main (automotive specialty) aftermarket chain around here is Auto Value - they've got NSK on the shelf for $40 (CDN), which is comparable to the "GD-unapproved" parts Rock carries, once shipping cost is factored in. For a benchmark, one of the dealers just quoted me $120.
- 105 replies
I don't think you fully appreciate how difficult and/or expensive a lot of these vendors can be when selling to Canadians. Ebay normally quotes outrageous shipping charges for stuff moving over the border - if they'll ship here at all. If there's something I want/need badly enough I sometimes need to have it sent to a mail drop a friend uses just over the Montana border, then there's additional time/cost/hassle in getting it from there to here (less than a couple of hundred miles north of the border). I'll certainly check the vendors you suggest, but I don't expect any love. As far as either of the local dealers matching a US price - that's a non-starter. But back to my point: I won't automatically assume that Subaru OEM is the best available part - there may well be an aftermarket that's better. (Example: I've been spending some time with the ARP catalog, and those guys are hardcore. I can't imagine anyone suggesting OEM bolts are superior.) That's why I want to hear from the experts on this. At what price is a completely different question.
- 105 replies
I wouldn't necessarily make the same assumption. There may well be aftermarket idlers with bearings (e.g. SKF) that are as good as or better than OEM. That's why I asked.
- 105 replies
GD, can you give me the definitive guide to replacing this idler - whose parts to buy (or avoid)? I get most new parts from Rock these days - not just 'cause of cheepnis, but because they're a lot less hassle wrt shipping to Soviet Canuckistan. At the moment they list parts from Gates, ACDelco, and Flennor. Are any of these acceptable? How do Subaru OEM compare? If none of the above, whose do you prefer?
- 105 replies
Oh, okay. I'm guessing you'd preserve mass in both cases, but I can see how golf-ball-dent knurling makes sense and "regular crosshatch" knurling would create surface roughness that wouldn't hold the oil. Thanks.
- 105 replies
Pardon the intrusion here, but I just caught up with this thread and don't know anything about knurling. Is the idea just to expand the skirt by pushing the metal up, giving a tighter fit and reducing slap? How is it done? Chuck it into the lathe and go at it with a knurling tool? Honestly, I don't think I've ever had the sound of piston slap pointed out to me - I don't think I could recognize it.
- 105 replies
As you found, a bad fuel pump just means the motor slows or stops. A timing failure can result in a range of symptoms. If the belt skips a tooth (e.g. due to a failing tensioner) the timing's going to be out a little and degrade performance. Or you can experience what happened to me: The toothed idler seized, effectively stopping the belt. But the rest of the moving parts still had a lot of inertia, so the two passenger side timing (cam) sprockets shattered, smashing the timing cover on that side (that part was the giveaway when I raised the hood - lots of plastic bits), while internally three of the exhaust valves were bent by contact with the pistons. All that meant that there was a pretty abrupt THUNK as the motor stopped. I'm sure others here can relate the symptoms they experienced; perhaps together they represent a thumbnail guide to how the failures can present, though it may be less than definitive.
Can someone please enlighten me as to how and why KYB are the preferred brand? As a general rule I go econo and ignore the expensive upsell to "greater quality" with most replacement parts. That is, unless there are compelling quantitative and/or qualitative arguments for the extra cost presented by people who know - a ready example is the OEM thermostat. So when I replaced all four struts on my '02 Forester (since its crash, transplanted to the '01), I went with Gabriel Ultra and FCS (from Rock). How much difference will it make?
- 18 replies
- quick struts
- raising
(and 3 more)
Tagged with:
A few points: First, if you're trying to repair wiring faults, "twisting together" wires doesn't cut it. Either solder them or use a crimp connector (butt splice). Twisting will not give you the reliability you need. Second, Haynes manuals, while usually generally useful, do not contain model year specifics accurate enough for debugging electrical problems. They just don't, and you shouldn't try to do this based on their drawings, because you'll be wasting your time chasing ghosts. Somewhere, somehow, you need to find the exact drawings for your car. (This is a problem across the board, not just with Haynes' Subaru manuals.) Third, assuming your engine uses the same type of sensors as mine (which start at '95), they are passive devices that are unpowered - that's why they only have two wires. They're called "variable reluctance" sensors, and you can think of them as sort of like the volume control on an older stereo (which are variable resistors - potentiometers - that don't need to be "powered"). (A lot of newer audio equipment uses more complicated rotary controls like optical shaft encoders that are "active" devices and do need to be powered, but that's not what we're talking about here.) The upshot is that if you want to see whether the sensor is producing the pulses it's supposed to, you really have to put an oscilloscope on it.
As you've all illustrated, our work exists on a continuum from the "fun and games, keeping my own stuff running and staying stimulated by learning new things", through work for an employer and/or customer, to mission-critical/man-rated, where mistakes have the most serious consequences. As fate has had it, I've never been involved in the latter, and some of the very best programmers I've ever worked with have been categorical about not wanting that kind of responsibility. My career has been in the middle, and often as a contractor, where those mistakes sometimes came out of my own pocket. But back at the lighter end of the scale, here's another learning-on-the-fly boner move: For the longest time I had a persistent - and increasingly severe - drivetrain vibration in my old beater '91 Dakota 4x4. At one point I was so frustrated I was determined to just start disconnecting things until something changed. So off came the front driveshaft. No change. Then one front drive axle - I pulled it out and took it for a spin. No change. Then the other drive axle. I headed out our driveway and about a quarter mile down the access road to the secondary highway (we're out in the country). As I pulled out onto the highway, both front bearings (without the axles supporting the load) gave out, planting the front end on the pavement with the wheels splayed out like in a cartoon, or a newborn colt that can't quite stand up yet. I wish I'd had a camera - as I stood back and looked at it I just couldn't stop laughing. Then I trudged home, got the jacks and tools, and sorta wedged it all back together again well enough to limp back to the garage. To cap it, while I was fetching the tools, my girls' school bus driver passed by the poor thing, so the story got around. As my former business partner and I say: We know it's built right because we did it six times.
It's been quiet for a couple of days, so I thought I'd break the silence with a report of what kind of idiot I can be. Now that the holidays are over, everyone's back to work and school, and I can get some quiet time to crank up the stereo and get things done, I'm bolting up the heads on this EJ25D rebuild so maybe I can get the mill back in the car during the Chinook this week. Body count on this timing failure was three slightly bent exhaust valves, otherwise things look good. Having done the left head, I mounted up the right last night just before bed, and first thing this morning torqued it up. For anyone who hasn't done it, it's a procedure, and I still find some Zen focus in it, something I discovered a five or six years ago when I did my first head gasket job on this car, just after I bought it (my first Subaru). I'm normally very task-to-completion driven, but in the middle of torquing one of these heads for the first time, I found I wasn't thinking the way I usually do, rather, I was really enjoying the process. Quite a memorable moment for me. Anyway, in half an hour or so it was all torqued, so I went to the exhaust cam next, since I'm always nervous about falling lifters. But when I put it in place and reached for the cap... its markings were wrong - they were for the intake. So I looked at the cam - intake too. Confusing... I know where I put them just before bolting up the head... there are the exhaust parts.... oh... I'd put the head on upside-down. It's truly amazing, the big things you can miss when you're focusing on little details. We're all used to trying to be the smartest and most helpful we can, but I doubt I'm the only one who has these moments (and I have a few more, some pretty hilarious). Feel free to share.
Thanks - I'll see how it goes and may take you up on that. The problem was that with the engine in the (junkyard) car, there simply wasn't enough room to swing the flare nut wrench - or get a FH (B or otherwise) down there to help. I'm pretty sure the one I have was messed up when I first resorted to the Vise-Grips years ago. Nasty d@mn spot.
Sure - we all have our parameters when it comes to this stuff, and if you're using the tools to make your living it's easier to justify buying primo product. For example, when it comes to electronic pliers, I absolutely won't touch anything but Snap-On because nobody else is even close e.g. I've been using their 710 flush cutters exclusively for nearly 40 years. When there was a (really) good used tool shop in town I bought as many Snap-On, Mac, etc. "mechanic's" hand tools as I could, because they generally charged 1/2 the new price. But if I can't find those deals, I don't have a lot of trouble with solid consumer-grade stuff, esp. Craftsman or others offering free replacement. It's the normal cost vs. quality vs. time calculus, and it constantly varies with application and circumstance.
I can't be the only one here who finds that weird. Out here in Calgary we have three self-serve yards - Two Pick-n-Pull and one smaller regional independent. But a few years ago, out in Southern Ontario (where the vast majority of Canada's population is) I couldn't find one to save my life. I'm sure there's a pattern in this, but I sure haven't been able to suss it.
- 18 replies
- quick struts
- raising
(and 3 more)
Tagged with:
True confession: (Within reasonable financial boundaries,) I'm a total tool queen. I need very little provocation to buy a new tool so that next time that particular problem comes around, I'm strapped. These pass-through sockets (which are as you described) are a good example - I don't mind dropping $50 or so in order to not have to stop what I'm doing and start making tools next time. I'm not a big fan of these "universal" sockets, but given how often I'll use this kit, I think they'll be fine: https://www.channellock.com/product/39100/
I'm still trying to catch up with all y'all wrt what a "quick strut" is. Does that just mean "strut-with-spring assembly"?
- 18 replies
- quick struts
- raising
(and 3 more)
Tagged with:
Easy enough to confirm with a scope whether in fact the speedo circuit is just doing a simple waveshaping/level shifting without otherwise altering the signal. Unlikely, I think, that it's "random". Random is actually pretty hard to do, and I don't see how it would be useful in this case. More likely that it's variable or adjustable or something that's easy to implement with a 555 timer or similar. You wouldn't happen to have the schematic for it, would you? Might be helpful at some point. And yeah, I'm an electronics geek, mainly embedded systems (like this one). I'll be interested in hearing the outcome of the test with the VSS fed through the speedo.
I specified a self-serve yard because they're a completely different animal than a full-service yard. They're utterly indifferent to the removal of the valve body devaluing the remainder of the tranny. As far as they're concerned, any money they make on any portion of a car is gravy in advance of the rest going to the crusher for metal weight value. I didn't pull that $50 (CDN) figure out of my butt; that's what they actually charge around here: http://www.picknpull.com/part_pricing.aspx?LocationID=76&NavItem=12&SearchCriteria=&#partpricing I'm not going to argue the point further - it's your money, spend it as you wish. I just want you to understand that I'm not blowing smoke here. On the reprogramming part, I don't know, but my guess is that it wouldn't be necessary.
- 11 replies
- p0768
- valve body
(and 4 more)
Tagged with:
