Everything posted by LPGsuperchargedBrumby
Manual 4wd/dual tranny variations?!?
that sounds the same as what happened when i got a replacement 'box that had the 3.9 ratio in it when my rear diff was 3.7...i was told that the new box was 3.7 as well..gotta love(some) JY lunch eaters except i knew something was wrong within a couple of seconds of engaging 4wd ( far to much time driving crusty old Landrovers that torque bind to the max on sealed roads) same problems and 'thump' when coming out of 4wd
Explain to me this whole "wastegate system" on the EA82T
i'd be looking at the hose that go's from your turbine housing to the wastegate actuator its sounds like it was leaking when you were hitting the high boost #s but isn't leaking now for some reason either that or something was obstructing the movement of the diaframe or the rod that connects it to to the wastegate
6 cyl BRat
3 liters of subaru goodness = more power.......its already there
6 cyl BRat
umm all this talk of mega power is good but someone seems to have missed the fact that with mega power comes the need for mega brakes....like the guru said "its not spped that kills....its the sudden stop when it all go's messed up" putting a ez30r up the front would necessitate uprating the brakes (at least if i was building it it would anyway)
EJ18 to EJ22 Swap
correct me if im wrong but if a ej18 ECU will run a ej22 then a ej22 ECU should run a ej20 N/A i ask this because a friend of my'n has had the usual accesory pully problem with his ej22 , half the drive key is still stuck in the timing belt pully so he can't get that off and the bolt has broken off inside the crank and we can't even get a drill to go into it because i think its work hardend(drill was freshly sharpend and it wouldn't even look at cutting into the bolt) ej22's are very uncommon here so getting another one is out of the question however ej20n/a and ej25's are very common would the ej25 run on the ej22 harnes?
ea82 ea82t clutch differences
LPGsuperchargedBrumby replied to LPGsuperchargedBrumby's topic in Old Gen.: 80's GL/DL/XT/Loyales...thanks for the info, as it happens i've been too busy with work to much time into my motor swap and i haven't got the clutch parts i need yet(apart from the fly wheel) so some definitive part #'s is all good. ohh and i haven't bought any thing from the the partsbin or autozone coz the shipping to here would kill any price advantage.
two bent rims, what up with this?
in my 9 years of engineering i've seen chromeing and galvanising do some funny things to steel if your rims where designed to be painted not chromed then a different steel type may have been used to what would normaly be used for chrome wheels. galvanising steel seems to make it more brittlec chromeing seems to do what ever it wants harden or soften the base material unless its treated right
Diesel Powered Subi?
but think of the wheelspin on a set of stock 13" tyres...............
where do i get L series turbo motor and tranny?
you could always do what i did and look for a rusted out turbo L series then buy it for a song (or a couple of dozen...)
head torquing sequence
21 ft-lb 43.5 ft-lb 47 ft-lb
general questions....
i don't think we got the "spider" intake here, i think that its something like the ea82t manifold with 4 inlet runners i.e, one to each cylinder
***Subaru Diesel??!
just reading through this thread give me the feeling that some ppl are a bit set against diesels due to bad experiances with the older US domestic diesels. im in New Zealand where about 40% of light vehicals are diesel and it always surprises me to hear (from america mainly) the same old complaints about noise low rpm redline and lack of power compared to a petrol engine. nissan produced a motor called the LD28 a 2800cc 6 cyl that redlines at 5000rpm for the early'r versions and 5500rpm for the later ones produces 100hp NA (turbo version made alot more) and does't sound bad ,actualy sounds sounds real smooth and throaty if the right exhaust on it. and it gets 35mpg in something with the aerodymamics of a brick how do i know? i got one in my work truck and wouldn't swap it for anything( exept maybe a dodge viper motor )
The noise is getting worse, could it be Wheel Bearings
check you front torsion bar bolts where it bolts onto the swing arm my'n rattled and clattered like your describeing getting worse all the time till i found what the problem was, they weren't very loose i only got about half a turn out of them before they were locked up again (then i undid them and loktighted them) i thought it was CV's or maybe the swingarm bush
Supercharger
if my rusty memory serves me right i seem to remember working out that with a matched engine and blower (as in 2 liter engine & a 2 liter per revolution SC) every time you increase the blower speed by a full ratio ( i.e 1:1 to 2:1) you should gain 14.7 psi of boost ( i know, i know, blowers arn't 100% efficiant....so you won't get that in the real world ) in theory. reddevil, what the hell kind of intercooler did you have, thats the worst pressure drop iv'e ever heard of, a couple of psi is normal but a 50% loss????
ea82T performence mods?
well i've put carb pistons in a turbo now i gotta see how it go's
Supercharger
me too...out of sight is out of the cops ticket book
mid rear?????
just one question...........why?
Supercharger
i did super' a ea81, then i got greedy with the wanting more boost and it grenaded shortly after.....however it was on carb pistons and im pretty sure it went lean possibly due to it outstriping the amount of fuel my lpg regulator could supply. also got told in no uncertain terms by a 'orifice' of the law that i wasn't allowed it unless it was a certified mod' , that cost $300 that i didn't have at the time. that said,it went like a rocket untill i wanted "more" . one thing to think about if your racing is weight, a Rootes type blower is about 3-4 times as heavy as a turbo of the same realistic capability i had an SC12 off a 4agze......be warned if you are going to try a toyota blower that you can't run petrol through them as it toasts the seals in real short order
leone to brumby/brat instument panel swap?
LPGsuperchargedBrumby replied to LPGsuperchargedBrumby's topic in Old Gen.: 80's GL/DL/XT/Loyales...i'll try to go with what i've got first.....but if that dosen't work then i might have to take you up on that
LPGsuperchargedBrumby replied to LPGsuperchargedBrumby's topic in Old Gen.: 80's GL/DL/XT/Loyales...will do
Finally some nice weather! Coupe Bonding time!
tyre shine?? TIRE SHINE????!!!!!!! phillistine............
Super Deluxe Subaru Sherpa
that looks like the cavemans Justy......and someone apperently stole a cylinder off him as well
LPGsuperchargedBrumby replied to LPGsuperchargedBrumby's topic in Old Gen.: 80's GL/DL/XT/Loyales...yeah it is an ea82 panel it looks the same physicaly and the speedo drive in the back looks the same so im hopeing it fits, otherwise im going to have to find another ea81 instrument panel or speedo unit
LPGsuperchargedBrumby replied to LPGsuperchargedBrumby's topic in Old Gen.: 80's GL/DL/XT/Loyales...well i hope it fits and all works like its meant to i'm hopeing the subaru lego ability stretchs to the instruments
my speedo is working casually...as in it reads when it feels like it but my odometer is working fine so i know that the cable is ok. what i want to know is will a instrument panel out of a '85 leone fit and will it all hookup? it also has a tach which i don't have, even though my ute is a GL . do all brumby/brats have everything needed to drive the tach?
