Everything posted by LPGsuperchargedBrumby
i want i want i want!!!!!
LPGsuperchargedBrumby replied to LPGsuperchargedBrumby's topic in Old Gen.: 80's GL/DL/XT/Loyales...first time i've seen it i don't think it would be that heavy.....fiberglass bodywork would help
i really wish i had the money to buy this....but i spent it all on a 18 ton truck to build into a housetruck:rolleyes: http://www.trademe.co.nz/Trade-Me-Motors/Cars/Subaru/Tull/auction-273197348.htm
EA/EJ Adapter plate, with dowels, without dowels
i put the dowel hole in mine....i figger if they weren't needed subaru wouldn't have put them there in the first place
5 lug swap complete...notes etc
it was contacting when the suspension was at simultaneously at full suspension drop and at full lock...I.E up on a jackstands with the wheel cranked round to full lock. it didn't contact with the suspension at normal height...i.e wheels on ground and at full lock i have XT6 rod ends on it the get "certed" to be road-legal here it can't touch at any point....and steering gear touching things tends to be a bad idea at the best of times
if your using ea81 rod ends make sure you use 16 inch rims or bigger...the 15 inch factory alloys i'm running needed a 5mm spacer plate to prevent the rod ends hitting the rim at full suspension drop
don't know about swapping XT6 rod ends on to a power steering rack, they should thread on...but best way to find out would be to measure the length of a power steer rack and compare it to the length of a non power steering rack
carb to turbo conversion?
it fits....its tight but there is one in my ute so they fit
driving awd brat with no power steering??
i run 195/50r15 on legacy rims under my brumby (EJ22 FT4wd DR) on XT6 hubs...i find its lighter to steer than when i was running the stock wheels an 175/70R13's....guy that did my wheel alignment said it was because my wheel track center was about 20mm wider than with the stock rims an hubs while the steering is still pivoting at the same point as it used to
found what the is causing the noise i'm hearing when i hit bumps....the spring in the impreza strut is offset...the one on the old brumby strut is centered on the shock the offset on the imp spring is causeing it to hit the bottom edge of the strut tower i have a set of TEIN adjusty's that have a smaller spring diameter that should fix that problem
Propane Brat Conversion
Lol thats alot neater than my underbonnet conversion....wish i could have got a proper LPG carb when i was doing my conversion...it is alot better looking than my homemade carb. nice job on the conversion....just out of curiosity what ignition timing are you running?...when i had my ea81 on LPG i was running so far advanced that i was off the timing marks on the flywheel
Oh noes, runaway car!
my brumby did that to me once....just before i first converted it to LPG....carb primary butterfly shaft was worn i found out once i pulled the carb off and could see it properly....full throttle in the middle of town isn't a whole heap of fun
Gauge placement
i have a fuel air ratio gauge and a vacuum gauge mounted on the dash on each side of the raised bit that the instrument cluster sits in...lmao with the wires from the gauges running along the dash and out round the bottom of the windscreen pillar....WestCoast Kiwi style....rough as guts an twice as good...
EA + EJ Adapter Plate Overlapping bolt holes
i drilled an tapped the holes (10mm if i remember)...they were close but do-able i also drilled out the alignment pin holes so i would know at least i had the plate mounted right on the gearbox
It finally goes
my one running around town uses about 13 to 15 liters of LPG per 100k...depending on how i drive. and thats with the RX 'box with its tall gears so you might get a bit better economy with the Legacy box if it has better ratios in 1st-2nd-3rd plus you should use less than i do due me being on LPG an you on petrol
EJ22 to Gen II Brat
no you don't need a motor out of a manual car...the one i have in my Brumby/Brat is out of an auto. once you take the flexplate or clutch off there isn't difference as far as i know as for the ECU differences i would think an auto one could be made to work by making the ECU think its in neutral or park however i wouldn't know...i have a factory dizzy an LPG carb on my one
It finally goes
nice to see you have it going now....interesting idea for the gearbox crossmember....i might have to pinch that idea and do it for my one. hahaha you do realise that you have just made dunedin the EJ22 converted brumby capital of New Zealand well done man
yeah i'm thinking it must be the top of the strut....altho i'm not sure how it can make the noises i'm hearing but i'm basically out of other options of what it could be. and yeah i'm thinking the the steering geometry must be different on the EA81's...most people that have made comment on the tie rods hitting the rims seem to have been running EA82 platforms... maybe the EA82 being that little bit wider in the wheel track allows things to clear
brumby to legacy/impreza master cylinder swap?
new ones needed
well my wheels rubbed with the 15" factory Outback Wagon rims that i have on...and i have the tie rod ends on the right side...pretty hard to screw up considering they have LH & RH cast onto the top of them. one thing i have an ongoing issue with is a clunk in my front suspension somewhere...it only happens when i hit a "sharp bump"....like a small pothole....but it doesn't do it when i hit a "smoother bump"...like a pothole that has been patched but sagged/settled a bit. all bolts are tight so i don't understand whats making the noise...whatever is doing it doesn't affect steering or braking...although being on the brakes means you don't need as big a bump to get it to make the clunk the noise sounds like its coming from just in front of and just above my feet when i'm driving
the rear bleeder on the MC or the one of the ones on the rear end calipers? make sure the tube you are using to bleed it with is a tight fit over the nipple.... i thought i was getting alot of air out of a my system when i did the 4 stud rear disk swap....turned out i was getting air into the tube around the nipple end....combination of a oldish bleeding tube and a small nick in the nipple end caused me no end of trouble
i'm getting more pics of what i have done tomorrow morning when i go hunting for the noise in the RH suspension i didn't use the EA81 rod ends because they hit the rims even worse than the XT6 ones....and yep i have the rod ends on the correct sides
well my 5 lug swap onto my brumby is finally done....after alot of issues....basically anything on the front end that could give me attitude...did. Parts List XT6 rear backing plates hubs and calipers XT6 front hubs complete with brakes & rod ends etc EA81 control rods reamed out to take legacy balljoints brake lines off XT6 plus assorted spare clips an stuff that came with the brake lines axles i cut and shortened the rear end was pretty straight foward apart from having to shim both caliper carriers outboard by 4.5mm so that the carrier was centered on the disc. the front end gave me a few more problems. first off if your doing a swap on an EA81....USE 16 INCH RIMS OR BIGGER....i used 15 inch rims and had to machine up 5mm hub spacer plates for the front so that the XT6 steering rod ends miss the inner corner of the 15" rims on full lock. axles i made from legacy ones that i cut 85mm out of the middle of and sleeved and welder back together( had to cut the axles with a cutoff wheel on a grinder...the ceramic tip on my partoff tool for the lathe wouldn't even touch them...they are VERY VERY hard) i had to machine the steering rods to allow me to put another 30mm of thread length on the rod(14x1.5mm thread pitch)....which allowed me to cut 15mm off the end of the rod...the XT6 steering rod ends had bottomed out on the thread about 6mm short of enough toe in and didn't allow enough thread to put the locknut on the rod. i got the top hats off a pair of EA81 struts and swapped them onto a set of 2WD impreza struts...just had to file the flat spot in the hole in EA81 round...and fitted them to the XT6 hubs...with a 6lb club hammer and a 1" dia punch:grin:...they are a bit of a tight fit. i also had to push the strut tower with a hydraulic jack and pushing form to expand it on the outboard side to allow the strut top to come out as the suspension comes up also had major issues bleeding the brakes...but i think this was my fault for not following the proper sequence i.e. corner to diagonal corner i also had to get longer brake lines made because the XT6 ones i had were too short to allow full steering lock at maximum suspension travel. got a steering alinement done yesterday...( my 8x2 plank and ruler 'get me to the tyre shop' alinement was only a 2.1mm out on the left side and 3.4mm out on the right side:lol: after a couple of very frustrating and busy weeks i'm finally on the road...and it drive's really nicely... there's a couple of things i still have sort out...i have a 'clonking' noise in the right front side somewhere when i hit largish bumps...having a look for what that is tomorrow...and i don't like the feel of the brake peddle...it stops 'ok' and will lock up the fronts...it takes alot of pressure on the peddle and and the peddle feels....odd...can't really explane it more than that next move i think is to fit a larger master cylinder to see if that sorts out the brake issue....then its time to dust off my supercharger...and become nameworthy again:banana: and i lost a couple of days in the middle because my GF ended up in hospital with gall stones...one very unhappy lass at the time...but all better now i have pics of the axles i modded but can't upload them cos they are too big...so heres a link http://s458.photobucket.com/albums/qq310/LPGsuperchargedBrumby/5%20stud%20swap%20stuff/
got it sorted....air in front brake lines
i've been doing the 5 lug swap on my brumby using xt6 bits and imp struts....an having alot of issues with things not quite fitting:mad:
ahhh ok....my peddle felt spongy..... so it must be air in it
