LPGsuperchargedBrumby
Everything posted by LPGsuperchargedBrumby
  1. hmmmm....sounds promising if i do find i need a bigger MC
  2. sweet....i must still just have air in the lines....dad said that it felt like air in the lines....but was the same as me and didn't know if a undersized master cylinder also felt like it did i'll bleed them again...for the don't know how manyth time lol
  3. i'm doing a a XT6 5 lug swap on my brumby and it would appear that the master cylinder on the brumby is too small for the XT6 brakes (bratsrus1 metioned i might have this problem)... having one last go at bleeding brakes tomorrow as it feels like there is air in the system...but i don't know if thats what a too small master cylinder feels like as well so what i want to know is if a non ABS legacy or impreza master cylinder will fit the brumby/brat booster and hook up to the brake lines... i kinda need to know ASAP oh an a full write up of the swap will be happening (complete with pics of front axles altered to fit) once i have it back on the road Cheers for any advice
  4. at the subaru wreckers in dunedin....the one they sold was sort of a an 'off white'....not snow white anyway....was in pretty good nick if i remember right....the motor had the TOD from 'Nam. i wanted to buy it but didn't have anywhere to keep it at the time
  5. wasn't a white one was it?.....there was a white sold by the subaru wreckers here a year or so back to a guy who was building it into a rally car
  6. i imported the XT6 hubs in from the 'states....and yes the postage was a killer....but still cheaper than getting a crossbreed kit to put Leggy hubs on:grin:
  7. that is what i'm going do in the morning....i've got the axles cut (had to cut them with a cut-off wheel on the grinder, the part-off tool in the lathe wouldn't cut them...lol it just polished the surface of the shaft...they are really really hard) and i spun sleeves up out of 4140 to be a 0.3mm crush fit. looks like cutting about 85mm out of a legacy axle gets you to the correct length for a brumby/brat.... i'll know exactly tomorrow
  8. this has been done before...pretty much all the major aircraft engine manufacturers on both sides tried it in varies forms one thing that has been done recently is to use a turbocharger type turbine to drive a alternantor via a reduction drive.... altho i don't know how well it would work on anything that uses a throttle that restricts the air flowing thru the engine....the ones i read about where being tested on a nissan diesel truck
  9. cherry bomb....sounds nice on a subaru....thats what i've got on my Brumby/Brat
  10. will factory legacy wheels fit a brumby/brat that has a XT6 5 lug conversion done on it....will the back spacing be ok? the legacy rims i have are alot wider than the stock brumby rims (rims are off a second gen legacy wagon...don't know what year) and it looks like they have alot more distance between the surface that pulls up against the hub and the back edge of the rim. i'm hopefully going to get the 5 lug swap underway next week...lol i think i have all the bits i need....certainly got all the major bits anyway has anyone else done a 5 lug swap on a brat?...i've searched but didn't come up with anything Cheers Callum
  11. just the carbs an manifold as far as i know
  12. both....get the twin carb manifold an carbs....and start looking for a late motor
  13. if your looking for spare blocks an stuff give Otago Wreckers in Dunedin a ring....they are a subaru only wrecker....and have a currently at least 4 ea71 engines....including a twin carb motor thats still sitting in a rusted out hatch. if your looking for the newest ea71 engine you can get keep an eye out for a a EA82 shape "1600 FWD Leone".... they have the last version of the EA71 motor...hydraulic lifters electronic dizzy an all the good bits
  14. Hows the front camber with the XT6 hubs?....is it still \...../ ? or does the slotted mounting holes in the Imp struts allow you straighten them up?
  15. does anyone know the length of front axles off a BRAT/Brumby?....i'm doing a 5 lug swap using XT6 bits....i'm using Legacy axles that i will have to shorten to the right length....an it would help if i could find out what length i need to make them up to before i start that swap so what i need is the face to face length (DOJ compressed) of a BRAT/Brumby front axle....as in the length from the flat face of the CV that goes against the wheel-bearing to the end of the DOJ closest to the gearbox. or if there is a website with this info on it that i haven't found yet.....lol Cheers for any help
  16. i have a brumby ute with an EJ22 an no power steering.....i find the steering is fine....the only time i wish i had power steering is when turning the wheel while the vehicle isn't moving
  17. cut the front axles off at the hubs with a 5" grinder with a cutoff wheel:banana: an pulled the axles....it was a bit brutal but i needed to be moving again as soon as possible
  18. have had an issue with the LHS DOJ on my Brumby (EJ22 &RX FT 4WD 5Sp)...it poped the circlip of the end of the shaft....which let the ball cage slip off the end of the shaft (stripping the spline for good measure)...this all happened while fully loaded with most of my worldly possesions and towing a trailer with two motorbikes on it 600 kilometers(about450 miles) from home....while coming down a mountain pass under engine braking in 2nd, and slowing down for a 35km/h corner. i thought the clutch had let go suddenly...but the grumble from up the front and total lack of drive had me looking under the bonnet as soon as i could pull over..... left hand doj had a torn boot an the axle just looked like it was sitting in the wrong place....put it in gear with the handbrake on an the cup turned.... but the shaft stayed stationary:mad: then i remembered i had a center difflock:headbang:.....flipped the switch an made it home....then had to cut the front axles off at the hubs and remove them so i could go back and pickup the rest of my stuff...lol in RWD:burnout: anyone else had a DOJ grenade like this?
  19. i ran into the same issue when i swapped the RX box into my brumby.... i heated it an bent the loop down flat then i took it to the spring makers up opposite where the motorcycle wreckers used to be to get retempered. cheers Callum
  20. i'm running a carb'd ej....my ignition wiring is the same as used on my original ea81...right down to the length of the wires from the coil to the dizzy
  21. my one is white with a canopy an alloy bullbars...if you want when i'm down in a week or so you can have a look at it... lol altho be warned its no show car dunno about finding a power steering rack to fit a brumby....maybe you could get Otago Metals subaru wreckers to keep an eye out for one? how are you setting up the gearbox mounts?....i'm using the original 4spd mounts....i wouldn't do it that way again because the FT4WD 5spd is a bit heavy for them...when i get some time i'm going to make another crossmember to take the bigger mounts off a EA82 or a Legacy
  22. i replaced my midpipe resonator last week.....i put a straight thru cherrybomb (known here as a hotdog) muffler on it....its noticeably quiter than with the resonator on one thing i found interesting was that the pipe downstream of the resonator was twin walled....one pipe inside the other
  23. looking good i've got the same engine an trans setup in my brumby that your putting in yours lol except that i'm running on LPG....two EJ22 brumbys in dunedin....lol legendary!!!!
  24. hmmm TPS RPM an Speedo....famous last words maybe....but that don't sound too complicated to get to work
