LPGsuperchargedBrumby
Everything posted by LPGsuperchargedBrumby
  1. i am running a ej18 on LPG....but with a distributor & homemade gaseous carburetor.... if you where going to convert a FI motor you would need a set of emulators to shut off the fuel injectors while running on gas. i don't know too much about CNG except that its even higher octane than LPG so your timeing could be advanced even further.....i have my ej18 running 20deg BTDC. One thing about gas fuels that isn't mentioned on most pages that have info is the fact that the fueling needs to tuned backwards to what petrol is...I.E...if you motor is pinging/detonating/knocking you need to lean-out the mixture when running LPG/CNG
  2. does anyone know how much clearance there is between the valves an the pistons on a ej18?....the reason i'd like to know is so i'd be able to mill the maximum amount off...WITHOUT turning it into a contact motor. thanks
  3. no worrys.....pm me your email addy
  4. i found a couple but it won't let me upload them onto here
  5. http://www.ausubaru.com/forum/showthread.php?t=4837&highlight=eg33+brumby it used to have good pics....but they seem to have dissapeared
  6. there was a guy on ausubaru that put a EG33 in a brumby.....seem to remember that it went like a cut cat....but either sledged the front or thru the tail out on gravel due to the weight up front (don't remember which..)
  7. LMAO....i don't think theres much left in harley's that is actually manufactured in america anymore
  8. i have a LPG fueled carbureter and distributor ej18....
  9. how much power would it take to run an electrolizer that can produce 100 liters a minute?
  10. wastegate controls how much boost(i.e. 8psi ) you have.... a BOV or a BPV vents excess pressure when you close the throttle.....turbo doing 100,000rpm's....air its pumping got to go somewhere
  11. from what i've heard the EZ30 is about 1 inch longer than an ej.....and my belt covers are just touching the back of the the thin'st electric fan i could find. going by the "only 1 inch longer than an ej" it should fit in....however you might have to do some fun fitting to sort cooling it out
  12. an EA82T.....hope you like doing head gaskets dude
  13. with regard to the one piece driveshaft....it needs to be made longer to match up with the 5spd as the gear box is shorter than the 4spd box
  14. im the back of my brumby are a set of chains i got specificaly for driving in mud.....an to a lesser extent for snow an ice. the old style ladder steering chains with a couple of extra lengthway chains spaced evenly across the width of the ladder are the go for mud on a FWD or AWD......diamond chains are a dead loss for mud
  15. it has no power until you crank it and power then stays on until about 0.5 sec after you kill the ignition.
  16. just one question.....why would you want a RHD car in a LHD country?
  17. chuck in a spare coil an thats pretty much the whole ignition system spare
  18. im using a aftermarket thermofan controller wired into the temp sensor on the side of the radiator
  19. i'd try heating the turbine, it might expand a little bit and be easy'r to get off
  20. if you going to do an ej swap then do motor & box at the same time. i did it the other way....gearbox then motor... twice the down time....but its my daily driver so things got replaced as they died. oh yeah....an get with a one piece driveshaft made up if possible....so much easyer than mounting the carrier bearing
  21. i ran acetone in my brumby before i swapped to LPG an also ran it in my GF's mitzy mirage.....got a very noticeable increase in mpg....however when i worked out the cost difference between what we saved in petrol and what the acetone cost it wasn't worth the hassel.....so i swapped the ute to gas
  22. EJ18 runs an 89mm bore, not 92mmm.....
  23. Sorry....all banking in Kenya has halted due to the protests....try a Nigerian check...
  24. keep an eye on fleabay.....that the only place i've seen them
