2
Everything posted by Phizinza
Saab wheels and sube == saabube?
Phizinza replied to bgd73's topic in Old Gen.: 80's GL/DL/XT/Loyales...
So have you messured the stud pattern? What year Saab's are we looking at? -
So the thread striped, not the splines? When I done mine I expected the splines to strip before the thread. I used old studs from another hub, did you use new ones? Maybe they aren't the proper high tensile?
I just done this... It was easy, needs a bit more welding at the moment though... I know there is someone here in Aus that makes the adapters, but he charges like $500+... Personally I was thinking about doing a hub+brake swap with a newer subie, but then I wouldn't be able to use my 6 stud mag's! :-\ Sorry, I don't have any links for you
Stock rims have about 58mm offset I am pretty sure... I recommend getting some rims with an offset that just doesn't stick out the fender, that seems to be pretty good at not rubbing. I'll have to messure my mag's and offroading wheels offset to tell you what that is.
Here in South Australia it is pretty hard to get anything over 2" legal (and if you had more it would look kinda obvious) So we have 2" lift on both. The Brat has Kumho Venture 27" M/T's with about one third wear. And the wagon had new 26" re-treads in a "winter tread" pattern. They seemed pretty good, but nothing like the kumhos. Also, both have open diffs alround
4 to 5 hole adapters for what?
...! What? Hideous?? It just looks like it is ready to offroad! All you need is a tube bumper, a lift, some bigger tires, and some spotties! It would look awesome then. hehe... On the subject of sand.. take it down the beach on a day you have plenty of time on... Then get it bogged. Easiest way to find out how much is too much.
I would love a set of these rocker covers, but they cost like $200 a set or something http://www.sub4.co.nz/rocker.htm Some of those EA81 heads they make would be nice too!
Isn't that what the O2 sensor and AFM do? When theres more air, it puts more fuel to go with it? That's how the Mazda 626's do it... Otherwise having fuel injection would be about as pointless as using tire blackener... Or blinker fluid for that matter..
'experience'?... I'd say this was quite an experience(watch the first 30 seconds or so.) That was my first time on the beach. I hadn't even let the tires down. Pretty much all I can add to what has been said is, say goodbye to all that pretty metal that holds your roo together :-\
If there was a sticky about this all it could really say is 'for stock, if you don't want to cut/beat 25.5". If you don't mind cutting or beating, upto 29"...' Then again, we could just answer all these questions with that reply... Although, if we had a sticky like the EA81 in Old Gen, maybe we could get something that is pretty accurate?
No problem mate.
My subaru Ticks with the ignition "ON"
Phizinza replied to Prospeeder's topic in Old Gen.: 80's GL/DL/XT/Loyales...
... what year? It probably is just the fuel pump under the hood working.. Its a electrostatic(?) fuel pump so it can/does tick over really slow. does it tick faster when you have just turned the key for the first time in the morning? -
IF your not afraid of hitting that fender wall (bit between wheel and your feet) back 2 to 3 inchs then you would get 27" on there pretty easy I would think.
Those wheels look phat man (lol, I used the word 'phat') I am planning a little for my EA81, might be similar setup as yours Lol, I got my ute with a dash like that in it. The guy who put it in said it was a pain in the .... and he would never think about doing it again. But I like having a tach, and for some reason my speedo reads almost correct with the 215/60R15's on it... ? Lol, you even kept the jack under the hood, how Subaru I guess you have the AWD low range box? Use the low much at all with those wheels?
hey looking at a 1980 GL wagon...
Phizinza replied to kodiak1232003's topic in Old Gen.: 80's GL/DL/XT/Loyales...
... So EA81's started in 81? but the body style started in 80? (sorry to hijack) -
No, no, no... you NEED them so you can see over the top of the other truck that is lifted 2ft high.. What you need down there is a VW Baja bug/dune buggy with a EJ20t (I should really be saying up there, huh?)
I like that green on that wagon.....
The offset on my EA82 stock wheels is about 58mm. Hope that helps.
Is that because it is too hard to get a 80's car to pass emissions? Sad.. becuase you'd think a Hummer would suck more juice and create more pollution, but I guess not on a percentage basis?... :-\
can I hook up the torbo
Phizinza replied to Mike Moore's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You might want to try the Classifieds Section on this forum. In the listing use the spelling Turbo, that way more people will find it if they search. -
... Speachless ...
