Everything posted by ericem
Just wondering about ride height...
Ok, on my 93 legacy wagon, why do i feel so low to the ground but when i steep in a new impreza it feels higher? It sits lower though! and the seats are at the same height. Now i was wondering if u put outback shock on my legacy will it be a bolt up setup? ANd will it sit higher? THanks.
harmonic balancer :(
ericem replied to dj3stripes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgo for it. Everything should be alright!
ericem replied to dj3stripes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf its not there its a bad thing right? Because the alumium ones on ebay look like there is no rubber.
ericem replied to dj3stripes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf ur used one has a good keyway, its a good pulley. That one on ebay might be ok, but i dont know. I have seen alum ones for that same price, but they seems cheap, like there going to crack, and why is there rubber in bettween the two metals?
Changes with elevation?
ericem replied to BSOD2600's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOh ya i remember that thread. I checked the tranny by driving in the city, for about 10-15mins then i stopped left the car running(dont turn off the engine) then i made sure the car was on level ground, pulled the dipstick, wiped it, then reinserted, it should be around half way on the hot side, of the dipstick.
AWD Legacy transmission (slipping & stiff) baffled
ericem replied to docrw's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTHis is a totally different situation! you towed the car with all 4 wheels on the ground, has nothing to do with a trans cooler.
ericem replied to BSOD2600's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust wondering, u try premium fuel or do u run premium fuel all together? Becasue these engines run way better one premium, its even noticeable with my 93 leg wagon non turbo. Like i got my REAR wheels spinning!! THATS incredible, and on the highway, its definitly more quick. Then i went back to 87 octane, and things just dont feel the same. But if u say there is a buzzing or humming from the engine, well, its hesitating, mine did the same sort of thing, dumped the seafoam through the pcv valve and no more humming and buzzing. ANd dumped some seafoam in the gas tank.
ericem replied to BSOD2600's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell i see mine come on every so often at lower gears, but usually when im on the highway it lights up. If the fluid is a little bit low, it can casue the clutches to slip and therefore its screwed on that part, but the turbo should help u out a bit. Hmm never thought about height on earth. Hmm, well is it like a super noticeable problem? THe power light i believe indicates to hold the gear, and downshift.
spark plug seals
ericem replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXExactly what i was thinking.
Engine Overheating
ericem replied to rgibson4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSee you there nipper! No j/k, have a good trip and a safe one, we all need you here.
ericem replied to dj3stripes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNOO!!! are u crazy i payed 200 CDN!!!! LOLL needs to be much cheaper.
Rad question......
ericem replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk, guys i feel much better, subaru did my oil change, retorqued my bolt on the harmonic pulley, and i didnt hit 140ft-lbs but now it is at 140ft-lbs, we talked, learned, and cars runs great. CHecked everything, diagnoised the temp sensor, needed to be replaced, and all is well. Car runs better for some reason, as always, whenever we go to subaru i always feel better, and they always make my car run way better. The subaru God must have blessed my subaru:burnout:......
Ridiculously high mileage on one engine, with no head gasket change
ericem replied to Green96GT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIm sure the 1.8 will last as long as a 2.2l. I have never heard of a issue with the 1.8 so it should be fine.
Rad question......
ericem replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOK, it does move but only 1/4 the way up and no more after that. Is it a good chance its the rad cap. It does move though.
Rad question......
ericem replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTook it for a spin, doesnt want to come up to temperature WHY! &^&%&$^*)*(^*(^&^(* (swearing alot). One thing after another!! WHY WONT U GET UP TO TEMP!!!!!!! WHY!!!
Rad question......
Hey, well my thermo stat died. Hmm, now it didnt want to come up to temperature the engine. Now i changed the thermostat and i refilled the fluid in the rad, but i just need to take it for a test drive. Now to air out the system u turn on the car and keep pouring into the rad until full right? Then cap? Is there a special proccedure i should follow? I find subaru complicated vehicles:-\. Thanks.
ericem replied to dj3stripes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXALl i did was remove the harmonic pulley, didnt move the rad or the engine. And the key slides out.
ericem replied to dj3stripes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi have a thread divoted to ur issue. I have 6 pages worth. lol. Now its very simple, take off the bolt, take off the pulley, pull off all the belts. THEN buy the new harmonic pulley, and usually u will also need a new key( 5 bucks CDN) harmonic pulley(200CDN) and then i used a pulley holder, its like a belt that goes around the pulley, and then u use a torque wrench and torque it to 100ft-lbs, but me myself i did 140ft-lbs with blue locktite. Subaru Canada said 140ft-lbs but everyone here thinks im dum for doing that. Oh well the pulley is still there. And when u put back on the belts ur going to needs to lossen the little bolt that adjusts the tension on the belts, and the idler then put on ur belts after u have the bolt on nice and tight. Now this pull holder, my dad helped me out here, he holded it from the bottom while i used the torque wrench and tightened the crap out of it. ANd then we put on the new belts we bought. We made the belts not TO TIGHT, and not TO LOOSE. And u should be set to go. Except in my situation i wasnt set to go, my alternator died, doh. But its running great now, been 5,000km i put on the car since last week or so, and no problems, just my dam thermoter is stuck, and the engine wont warm up, no biggie, 15bucks CDN all is well. Hope this helps. Edit: here my thread by the way. http://www.ultimatesubaru.org/forum/showthread.php?t=64710
Not driver for a year can cause TB???
ericem replied to allantico's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, that would make sense, because tranny fluid was sitting in there, but a few more tranny oil changes odd to fix the torque bind problem.
ericem replied to docrw's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYa i doubt the tranny cooler is neccessary, unless u plan on towing anything. ANd Manarius thanks for reminding me of the edit button, hehe.
no power after 4000rpm
i think there is a sensor problem here. Lets wait for people better educated with sensors.
ericem replied to docrw's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXacually, u know what I think u are going to need a new clutch and solenoid for the awd unit. sorry to say this, but I think ur better off with a used tranny.
ericem replied to docrw's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think u messed up ur awd system. You not suppost to tow a subaru unless all 4 wheels are off the ground. Now it to see if electronics work, with the FWD fuse in, does the car bind? ANd with mine it did the exact same thing when the drive solenoid and clutch packs for the awd unit where shot.
well lets ask a question, do u see a check engine light? And try unpluggging the battery to reset the ECU then see if a light turns on.
high speed braking shimmy
ericem replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTime u get some tires from ebay my man nip! From the streets of toronto hommy! Im joking. From the streets of NYC if u make it there. :lol:
