MR_Loyale
Everything posted by MR_Loyale
  1. Not sure what that blob of metal is in the cam gear but I bet you could knock it out of there with a screw driver and hammer. Once you do that, pull the plugs and put a wrench on the crank bolt and see if you can turn it by hand. Disconnect the battery for safety. On second thought it looks deformed. I would go to jy and get a replacement.
  2. Post your pics to a free hosting site like postimage.org and then link to them.
  3. Bought my 1993 Loyale new in 1994. Had it ever since. If you want easy to maintain, reliable transportation, it is worth it. If you want formula one performance, look elsewhere.
  4. What? Didn't you get the built in engine oil rust prevention coating option?
  5. I guess I am a slacker here. Everyone else's run perfect.
  6. Shame. You forgot to include "Just EJ it."
  7. Having older cars as daily drivers means that some things don't always get fixed right away if they can be deferred. Let me give an example. My little red sedan Ash has oddly operating heater controls. I need to press the heat button to get air to blow on the windshield. Also since the ac compressor is also used as a dehumidifier, it will engage when the heater is on and it is humid. The belt makes a high pitch screeching sound that can be heard for blocks. It startles pedestrians sometimes. What quirks does your car have?
  8. It was in 2006 I think. I had the ea82 out to do a reseal and timing belts. I also replaced the water pump while I was there. The Haynes manual said 40ft lb on the torque. This of course snapped the bolt. That day I learned to not trust Haynes torque figures. Luckily the broken bolt was proud of the block and I was able to get it out with vise grips.
  9. If you need seals, Oreilys sells a grab bag of these for about five bucks.
  10. A screw to hold the rotor???? REALLY??
  11. Pictures are good too. Great way to capture how things are before you take them off.
  12. You could just keep it as a show car. Drive it a few miles a month. At least in WA, antique cars get a reduced rrgis ration fee after we 25 years.
  13. I gently squeeze the hose to help force the air out.
  14. My only advice is take it slow and steady. It is costlier to do it over again than it is doing it right he first time. Also ask many questions and take picture for us as well. I have discovered that if you use something like masking tape such that when you disconnect a hose or electrical connector, write down the step number of the dis-assembly. Then putting it back together is simply a matter of counting the steps in reverse.
  15. That is the way to pull yourself up by your boot straps! In your dining room no less! I feel like such a wimp using an engine crane and stand. What engine was it?
  16. They stopped making the Tribeca a while ago. It had a reputation for unreliability. They are supposed to be working on a replacement.
  17. You can post the link to the picassa pics.
  18. You confused me there, which damn roos are you talking about? The ones driving or the two legged ones getting hit with the ones being driven.
  19. Won't be going. Someone who I had hired to help with a job on my house bailed. I am doing that myself.
  20. You can remove the door panel, two screw in armrest, pop off lock latch housing and then the whole door panel pops off. The switch will be attached to the control arms that are moved when the key is turned. i do not remember exactly where it is mounted in the door, but if you follow the control rods, you will find it. While you are there it would be a good time to grease the window tracks too.
  21. You cannot prove a fuse is good by visual alone. However you can verify it with some deduction and fuse swapping. Your washer/ wiper uses a 20 A fuse. If your washer/wipers works, then swap the door lock fuse into the washer wiper and see if the washer wiper still works. If it does, the fuse is good, if not it is bad. Trust me a visual inspection alone doesn't prove it is good. Many hours may be wasted relying on the visual test of fuses. Ask me how I know.
  22. If it isn't the fuse, the it is either the switch or the wiring from the switch to the actuators. Have you looked at the switch?
