27
Everything posted by MR_Loyale
A year in review
MR_Loyale replied to Adam N.D.J.'s topic in BRZ and its Sister the Scion FRS/Toyota GT86
Adam- BRZ looks gorgeous. Have you experienced any of the fo9llowing with your BRZ? High Pressure Fuel Pump "Cricket" Noise. RPM Dips: This occurs in neutral before coming to a stop. The rpm will dip to 500 rpm and it will feel like the car is about to stall, but it never does. 4th Gear Grind: This happens at 6,000 RPM going from 3rd into 4th. Tail Light Condensation: Water condenses inside taillight. -
Yikes. I have yet to order mine but I am interested in the answer to this question.
BRZ Falling Out of Favor?
MR_Loyale replied to MR_Loyale's topic in BRZ and its Sister the Scion FRS/Toyota GT86
Found this on the Subaru global site: -
Oil Leaks, Smoke, UV Dye ...oh my
MR_Loyale replied to MR_Loyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
So I am looking at the engine out of the car under UV light, I can see definite oil leaks. The cam tower/head seam on the driver side: Top front driver side head/block seam: Front bottom of diver side head/block seam: Lower rear of driver side head/block seam: -
EA82 Removing Cam Tower
I am sure some cuss words will be necessary. Got real lucky on the crank bolt though. I forgot to bust it loose before I took the engine out. I was sure I'd use a week's worth of cussing getting it loose. Followed Mile's suggestion about using the air impact wrench and with once zip of air it was loosened. I did the happy dance on that one. -
Ok. Got the engine out and the timing covers off so. Note in the image below that the right HG seam is all oily and dirty. Contrast this with the HG seam on the left. I think on the passenger side (left in pic) most of the oil was due to the stupid oil filler neck gasket. Cam tower seam definitely leaking too. I will be doing some UV shots tonight when it is dark and post them. -
Actually that makes perfect sense. I will try that method. Probably going to do this tomorrow morning. I want to get at the HLA's and get em off to Mizpah. The motor is already out and currently hanging like a side of beef off the engine crane. -
Where can I buy another water pump outpipe?
Sold. IPA? Got any good tension pulleys ? -
I was going to title it "That Damn Pipe", but figured the thread would be deleted. I need to find the metal pipe that comes out of the water pump- I think we all know which one I am taking about. I cannot find it listed anywhere. Other than one from the junkyard (which will probably be as bad as mine), where can one get this pipe?
I pulled my EA282 yesterday. I took the opportunity to inspect the clutch, throwout bearing and pilot bearing I installed in 2006. The pilot bearing felt rough. Not sure how that happened. It was the one included in the clutch kit I bought at the time. I am wondering if I did something wrong in installing it. If so, now is the time to find out what I messed up and do it correctly. The only problem I can recall is that the new clutch would occasionally "chatter" when accelerating from a stop. I just figured it was seating. I did have the flywheel surfaced last time. So now I get to take off the pressure plate and dig the pilot bearing out. May just put another new clutch in. Is this a case of getting an original Subaru pilot bearing is the best option? Or should I see if they have a clutch kit?
Yes yes yes yes!!!! Please post a pic! -
Good advice. Yeah I will be getting the assembly lube. I also like to put it back the way it came so not having the fall out when I take it apart is a big step to insuring they don't get mixed up. Thanks. -
I knew I heard somewhere there was a neutral position on the cam towers. It was in the Miles Fox vid at 1:04 Is "Dot Up" the neutral point on the passenger side as well? -
OK, what engine stand? Last time I had this out, my brother had the one from harbor freight and it would not fit. Did you make your engine stand yourself? I sooooo want to be doing this on an engine stand. Yeah I am a wimp. -
Even if it goes along the HG seam on top of the block? The cam tower O-ring will definitely be replaced, and with the metal reinforced one. Subaru is the only place to get those metal reinforced ones? -
I haven't removed the cam towers yet. Just got the engine out of the car. It is hanging like a piece of meat off the engine hoist right now. I was hoping to avoid the rocker arms plinking on the floor when I did this. Sound like it is pretty much unavoidable. I will just lower the engine so it doesn't have far to bounce. Mile - any particular brand of the ultra grey sealant I should use? -
I seem to recall there was a special positioning one could set the camshaft to in order to ensure that no lobes were depressing any valves such that removing and installing the cam tower would be easier. Mainly I want to avoid the rocker arms falling to the floor and my cuss words that will follow. Hey I have been traumatized by Jesus Christ clips.
Well I will have the definitive answer tonight. My engine is pulled but Tuesday night during the last 50 miles before I parked it I put in two bottles of UV dye. Just got the engine out today and will e examining it tonight when it is dark and the bye will glow nicely under the UV light. I can take close up pics of any part of the engine if need be. -
Yesterday I prepped the patient for surgery with an exterior wash. Then i assembled the engine hoist I had sitting in two boxes for almost a year. It was lat by the time I got started on this, but this afternoon it concluded with this: I am on the hunt for the elusive oil leak. It has been hitting my exhaust and making a cloud of smoke and leaving the engine bay looking filthy:
For Subaru are you talking a complete gasket set or just the HG?
1992 Loyale Engine Compartment Smoke
MR_Loyale replied to zach123's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If it is a white cloud like steam, check the plastic tank to see if the coolant level is low. There is a small bypass hose that comes out of the thermostat housing into the block, about a 1/4" dia hose. That is notorious for leaking coolant. The thing is if you run the engine and look under the hood you may not see if leaking. I had to grab the throttle and goose it before the the slit opened up and I could find the leak. When idling, the slit was closed and no leak. However as soon as power was applied, ir sprayed like a hose. If it smells like oil, the you have oil leaking and hitting the exhaust. Check your oil level to see if it is going down. -
"Just EJ it" a different look at this
MR_Loyale replied to tweety's topic in Old Gen.: 80's GL/DL/XT/Loyales...
For me it hasn't really been an issue. I accept the car for what it is, a small economical, reliable, easy to repair bit of transportation. That was exactly how it was engineered and since from new that is exactly the service it has provided me. Subaru did offer a turbo for the EA engine, it made all of 10 extra horsepower and a virtual guarantee of premature HG failure. Do folks think the engineers at Subaru are stupid and left some "extra" in the EA series that hasn't been exploited? There have been numerous threads and discussions as to why the EA is pretty much at its max. You argued that Ej'ing a Brat requires chassis mods and an engineers report. Modifying an EA with non-stock turbos and such would not require an engineering report? Personally, I don't want an EJ in my Loyale, I am perfectly happy with the stock EA82. If I want to haul and tow, I got my Ram for that. If I want to win races, I will get a WRX. God bless the folks that go to all the trouble of putting in an EJ though. So if you come here asking how to increase the power on an EA series engine, please don't get disappointed if those that have treaded down that very same path, asked the same questions and concluded EJ is the way to go, offer you their wisdom. It may not be what you wish to hear, but if there was a magical way to increase the EA doesn't it stand to reason that after 25 years someone would have found out about it?
